Transpose symbol
11-20-2017, 08:48 PM
(This post was last modified: 11-20-2017 09:16 PM by salvomic.)
Transpose symbol
hi,
in this new version there will be too many irons in the fire (well!), but in a next release I hope to have a "transpose symbol", a facility symbol for matrix traspose, a synonym for TRN() command: \( A^{T} \) or Aͭ A⊤ or similar writings... Maybe only an affectation (however with a lot of matrices it would be simpler to use), but... is it possible? Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
11-20-2017, 10:46 PM
RE: Transpose symbol
As a matter of fact there are two commands: TRN, and transpose of which the first conjugates, too, if complex is on, which one should be available shorthanded? So I think that would result in a bit more confusion.
Arno |
11-20-2017, 10:59 PM
(11-20-2017 10:46 PM)Arno K Wrote: As a matter of fact there are two commands: TRN, and transpose of which the first conjugates, too, if complex is on, which one should be available shorthanded? So I think that would result in a bit more confusion. yes, I know; however to avoid confusion maybe distinguish between T (transpose) and H (conjugate traspose, Hermitian) could help... But in this case we need two symbols. No, too many ![]() ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
11-21-2017, 05:28 AM
Unlikely. Such symbols would be postfix operators and they are a pain due to operator priority issues. Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
11-21-2017, 06:49 AM
Inside Xcas you can use A^* for the transconjugate of A, it could be the same in the CAS.
11-21-2017, 07:37 AM
(11-21-2017 06:49 AM)parisse Wrote: Inside Xcas you can use A^* for the transconjugate of A, it could be the same in the CAS. It seems that it is not working Viga C | TD | FB |
11-21-2017, 08:13 AM
(This post was last modified: 11-21-2017 08:31 AM by salvomic.)
(11-21-2017 05:28 AM)cyrille de brébisson Wrote: Unlikely. hi Cyrille, I fancy it is tricky to implement and a real pain. My idea was inspired by the books, that have the "postfix" symbols T and H for matrix transpose (like them were postfix), so we have this "forma mentis" and habit and sometimes a reluctance to think that operation prefix... Like we do with the inverse, ^-1, is easy to think "now I put ^T to traspose..." (11-21-2017 06:49 AM)parisse Wrote: Inside Xcas you can use A^* for the transconjugate of A, it could be the same in the CAS. (11-21-2017 07:37 AM)Carlos295pz Wrote: It seems that it is not working Yes, it doesn't work in CAS in the Prime. It could be an half solution, or *the* solution, however... Cyrille, do you think it could, in the future, activated in the Prime CAS? Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
11-21-2017, 11:08 AM
I would appreciate that functionality too.
And although "H" probably only makes sense for square matrices, the transpose would be useful for any rectangle matrix, i.e. including vectors. I often transpose the solutions of an equation to make them more readable... |
