issue with HP prime emulator on linux
07-19-2023, 10:53 PM
greetings
I downloaded emulator for HP prime calculator from the site below
https://www.hpcalc.org/details/8917
However, after extracting the files and trying to run in Devuan chimera distro, I encountered the following error
I'm not sure what it means, and would like to know how to fix this? thanks
erdos@htpc-devuan:~/Downloads$ ./HP_Prime_Virtual_Calculator-x86_64.AppImage
QFileDevice::seek: IODevice is not open
QIODevice::read (QFile, "/tmp/HPCK_e5ced4fc-2d0e-4dd1-81d5-0e536c080b53.lock"): device not open
QXcbConnection: XCB error: 2 (BadValue), sequence: 219, resource id: 0, major code: 1 (CreateWindow), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 220, resource id: 62914564, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 221, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 222, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 223, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 225, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 226, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 227, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 231, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 232, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 233, resource id: 62914564, major code: 131 (Unknown), minor code: 46
QXcbConnection: XCB error: 3 (BadWindow), sequence: 234, resource id: 62914564, major code: 131 (Unknown), minor code: 46
QXcbConnection: XCB error: 3 (BadWindow), sequence: 235, resource id: 62914564, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 236, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 237, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 238, resource id: 62914564, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 239, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 240, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 242, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 243, resource id: 62914564, major code: 19 (DeleteProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 244, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 245, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 246, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 247, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 248, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 249, resource id: 62914564, major code: 12 (ConfigureWindow), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 251, resource id: 62914564, major code: 12 (ConfigureWindow), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 267, resource id: 62914564, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 268, resource id: 62914564, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 269, resource id: 62914564, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 270, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 271, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 272, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 273, resource id: 62914564, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 274, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 275, resource id: 62914564, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 276, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 277, resource id: 62914564, major code: 8 (MapWindow), minor code: 0
^C
07-21-2023, 06:00 AM
RE: issue with HP prime emulator on linux
(07-19-2023 10:53 PM)erdos Wrote:  greetings
^C
Wow, first time I see there is an appimage for prime. I have installed the windows version with wine.
07-22-2023, 12:46 PM
There's no easy answer (except perhaps to install Ubuntu 14.04 and even then it might not work.)
See https://www.hpmuseum.org/forum/archive/i...14351.html
07-22-2023, 03:52 PM
Go to linuxquestions.org for posting.
Or look in the web: the error "QXcbConnection: XCB error:" seems widely spreaded. One solving is there..
https://forum.manjaro.org/t/getting-a-qx...isub/62818
HP71 4TH/ASM & Multimod, HP41CV/X & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X, HP75D
