07-19-2023, 10:53 PM
greetings
I downloaded emulator for HP prime calculator from the site below
https://www.hpcalc.org/details/8917
However, after extracting the files and trying to run in Devuan chimera distro, I encountered the following error
I'm not sure what it means, and would like to know how to fix this? thanks
erdos@htpc-devuan:~/Downloads$ ./HP_Prime_Virtual_Calculator-x86_64.AppImage
QFileDevice::seek: IODevice is not open
QIODevice::read (QFile, "/tmp/HPCK_e5ced4fc-2d0e-4dd1-81d5-0e536c080b53.lock"): device not open
QXcbConnection: XCB error: 2 (BadValue), sequence: 219, resource id: 0, major code: 1 (CreateWindow), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 220, resource id: 62914564, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 221, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 222, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 223, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 225, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 226, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 227, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 231, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 232, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 233, resource id: 62914564, major code: 131 (Unknown), minor code: 46
QXcbConnection: XCB error: 3 (BadWindow), sequence: 234, resource id: 62914564, major code: 131 (Unknown), minor code: 46
QXcbConnection: XCB error: 3 (BadWindow), sequence: 235, resource id: 62914564, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 236, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 237, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 238, resource id: 62914564, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 239, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 240, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 242, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 243, resource id: 62914564, major code: 19 (DeleteProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 244, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 245, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 246, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 247, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 248, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 249, resource id: 62914564, major code: 12 (ConfigureWindow), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 251, resource id: 62914564, major code: 12 (ConfigureWindow), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 267, resource id: 62914564, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 268, resource id: 62914564, major code: 2 (ChangeWindowAttributes), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 269, resource id: 62914564, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 270, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 271, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 272, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 273, resource id: 62914564, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 274, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 275, resource id: 62914564, major code: 20 (GetProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 276, resource id: 62914564, major code: 18 (ChangeProperty), minor code: 0
QXcbConnection: XCB error: 3 (BadWindow), sequence: 277, resource id: 62914564, major code: 8 (MapWindow), minor code: 0
^C
