Gallery: The HP Prime PNG/JPG Image Viewer [UPDATED V2.3.0 07-08-17]
06-29-2015, 09:57 PM (This post was last modified: 06-29-2015 09:58 PM by mandresve.)
Post: #61
RE: Gallery: The HP Prime PNG Image Viewer [UPDATED V2.0.0 29-06-15]
ATUALIZAÇÕES (29-06-15):
Gallery V2.0.0 agora disponível em Português. Muito obrigado a João Leonardo Rozsas (jrozsas) pelos seus esforços nesta tradução, todos os elogios para esta versão ir para ele.
Baixar Gallery v.2.0.0 em Português agora!
Se você gosta do meu trabalho, deixe-me saber e compartilhar a informação. Obrigado.
Success is the ability to go from one failure to the next without any loss of enthusiasm.
View PNG/JPG in your Prime
06-30-2015, 12:24 PM
Post: #62
[/quote]
Hi jrozsas,
These functions are ok because it's how I designed the app, i.e the panic mode is intended to momentary hide the image, or the HOME that is a fast close function that allow close Galley Viewer and display the home in the calc. However, if it's wanted, I can change the orientation for the Left and right, up and down keys to produce a "natural" movement.
Thanks for the comment.
[/quote]
In the version translated into Portuguese I sent I made the corrections of up / down / left / righ.
I like Gallery and I have two suggestions:
1) Include a slide show function, which is alternating images automatically
2) Include the "Thumbnails" feature to view multiple images on the screen, and touch a picture, zoom
Leo
06-30-2015, 01:54 PM
Post: #63
(06-30-2015 12:24 PM)jrozsas Wrote:  [...]
Hi Jrozsas,
Many thanks for the suggestions, I'll include that on the next version of Gallery.
07-11-2015, 05:05 PM
Post: #64
hi!
A new Gallery-PTB, now with the [HOME] function functioning as in previous versions (1.xx)
Just missed the KILL in KB FUNCTION
IF THEN K == 5
STARTVIEW (-1.1);
KILL;
END;
Well, I made this correction because we often need to clear the screen quickly Smile
Attached File(s)
.zip  Gallery.hpappdir.zip (Size: 78.48 KB / Downloads: 8)
Leo
07-28-2015, 02:27 PM (This post was last modified: 07-28-2015 02:28 PM by jrozsas.)
Post: #65
Hello friends,
I am making some changes in the program.
This BETA version, Gallery is Touchscreen, multi-languages.
The language that appears on the screen is the same as the language you selected in the calculator (setup).
So far you can test in English, Portuguese and Spanish.
The Home key back to the original menu. ESC exits the program
If you have found an error in the translation let me know.
Attached File(s)
.zip  Gallery.hpappdir.zip (Size: 559.01 KB / Downloads: 21)
Leo
07-28-2015, 05:05 PM (This post was last modified: 07-29-2015 01:53 PM by jrozsas.)
Post: #66
Ops! This file is smaller.
.zip  Gallery.hpappdir.zip (Size: 147.95 KB / Downloads: 19)
Leo
07-28-2015, 05:20 PM (This post was last modified: 07-28-2015 05:25 PM by mandresve.)
Post: #67
(07-28-2015 02:27 PM)jrozsas Wrote:  Hello friends,
Hi Jrozsas,
Thanks for your effort in the improvement of Gallery. I detected some flaws/bugs that I would like to correct. If you consider appropriate, we could work together for the next version of Gallery. Write me an email to manuel.velez@uptc.edu.co and we'll talk about it. I would like the beta/on working versions published here are sent to my mail and make public only the final versions for the users.
Thank you very much for the interest shown in the application. A special greeting.
11-23-2015, 02:59 AM
Post: #68
Hi, I tryed to use the program, old versions too,never worked, Just the photos that already have in programa works. I tryed to use differents png images (exported from pdf and compressed in tinypng), never works.
Do you know why that happen? Images don't open, the program back to start. Maybe the resolution.. dont know..
in emulator works fine! thanks
11-24-2015, 02:54 PM
Post: #69
(11-23-2015 02:59 AM)allan.amaro Wrote:  Hi, I tryed to use the program, old versions too,never worked, Just the photos that already have in programa works. I tryed to use differents png images (exported from pdf and compressed in tinypng), never works.
Hi Allan,
Can you send to me the images that you have tried to load on the calculator, please? My email is in the program help, write to me. Maybe there's something wrong with the PNG files, if not, we'll figure it out Smile
Thanks.
12-12-2015, 08:14 PM
Post: #70
Hi mandresve,
In your next release, you may want to correct "CPrompt()":
// CPrompt FUNCTION
CPrompt()
BEGIN
CHOOSE(PROMPT2, "Are You Sure to Delete?", "Yes", "No");
IF PROMPT2==1 THEN
DFC();
END;
IF PROMPT2=2 THEN
NFD();
END;
END;
The second "IF" condition should be " IF PROMPT2==2 THEN".
12-13-2015, 02:51 AM
Post: #71
(12-12-2015 08:14 PM)daryl178 Wrote:  Hi mandresve,
Many Thanks Daryl178. Bug Solved.
12-13-2015, 04:11 PM
Post: #72
Just a reminder, in PPL (at least for now, dunno if will change anytime in the future) == and = will act identically upon evaluation. So while == is probably the clearest of intent, there actually will be no difference in behavior in that line of code.
TW
Although I work for the HP calculator group, the views and opinions I post here are my own.
12-14-2015, 05:46 AM
Post: #73
(12-13-2015 04:11 PM)Tim Wessman Wrote:  Just a reminder, in PPL (at least for now, dunno if will change anytime in the future) == and = will act identically upon evaluation. So while == is probably the clearest of intent, there actually will be no difference in behavior in that line of code.
That's true, but I remember that sometimes I get in troubles when using only one equal sign. Anyway is rectified. Thanks Tim.
04-21-2016, 08:11 AM
Post: #74
RE: Gallery: The HP Prime PNG/JPG Image Viewer [UPDATED V2.1.0 21-04-16]
UPDATES (21-04-16):
  • JPG/PNG File support under 10077 Firmware!
  • Capable to run in 10077 Firmware
  • Improved App Size and Stability
  • Improved App Speed
  • New Icon and Samples
Download Gallery v.2.1.0 NOW!
If you like my work, let me know and share the app!. Many thanks.
You can email me at: mandresve@hotmail.com
05-18-2016, 02:58 AM
Post: #75
Excelente, muchisimas gracias por el aporte, en verdad es fantastico.
06-16-2016, 03:34 PM
Post: #76
Good Morning!
Already updated the HP connectivity kit, updated the firmware to HP_Prime_Calculator_Firmware_20150617. But when I try to install Gallery appears saying that I need to update the firmware, which has been updated. Do you have any more current version of this 20150617? Congratulations on application development, very good. Grateful!
06-16-2016, 06:21 PM
Post: #77
(06-16-2016 03:34 PM)Globrother Wrote:  Good Morning!
Hi Globrother.
Thanks for the support. Recently, HP has made a rollback in the firmware updates for internal reasons, the version 10077 was taked out. I attach the previous version of gallery that is fully compatible with 20150617 FW.
Attached File(s)
.zip  Gallery V2.0.0.zip (Size: 68.57 KB / Downloads: 19)
06-16-2016, 09:53 PM
Post: #78
Hi Globrother.
Thank you for mandresve attention. I will use the version displayed on my calculator then!
06-17-2016, 12:05 AM
Post: #79
(06-16-2016 09:53 PM)Globrother Wrote:
(06-16-2016 06:21 PM)mandresve Wrote:  Hi Globrother.
You are welcome. Smile
08-07-2017, 07:31 PM
Post: #80
RE: Gallery: The HP Prime PNG/JPG Image Viewer [UPDATED V2.3.0 07-08-17]
UPDATES (07-08-17) Gallery v2.3.0:
  • JPG/PNG File support under 10077 or newer Firmware!
  • Improved App size and stability
  • Less loading time and no flickering
  • New Functions like "Go To Page" and display the file name.
Download Gallery v.2.3.0 NOW!
