Perimeter of Ellipse
01-23-2020, 01:40 PM
(This post was last modified: 01-24-2020 05:04 PM by Albert Chan.)
RE: Perimeter of Ellipse
(01-21-2020 05:16 PM)Albert Chan Wrote: \(\large p(a,b) = 2× \left( p({a+b \over 2}, \sqrt{ab}) - {\pi a b \over AGM(a,b)}\right)\) We could even do it in a novel way, from the *more* eccentric ellipse. Below, LHS is the more eccentric ellipse, with \({a_0 + b_0 \over 2} = a, \sqrt{a_0 b_0} = b\) \( p(a_0,b_0) = 2× \left( p(a,b) - {\pi b^2 \over AGM(a,b)}\right)\) Using my Casio FX-115MS, AGM2 method for Halley's comet, numbers from here A = 2667950000 B = 678281900 C = A² D = B² E = 0.5 F=B-A : C=C-EF² : B=√AB : A=A+F/2 : E=2E Quote:\(p(a,b) = {p(a_0,b_0) \over 2} + {\pi b^2 \over AGM(a,b)}\) Keep pressing "=" until F=0 (so that A,B,C all converged) \(\large\pi\)(C+D)/B → ellipse perimeter = 11,464,318,984.1 km This was similar to my lua code, with C=(A²+B²)/2, E=0.25, so that converged C/B = "radius". |
06-05-2020, 03:28 AM
(This post was last modified: 06-06-2020 11:33 AM by Albert Chan.)
From previous 2 posts, we can get some nice Elliptic Integral Identity:
Below, all Elliptic functions uses modulus argument. Eccentricity of ellipse, e^2 = 1 - (b/a)^2 We proved "next" ellipse (a' = (a+b)/2 , b' = sqrt(a*b)), has eccentrity of h = (a-b)/(a+b) K(e) = pi/2 / agm(1,b/a) = pi/2 / agm(1+e,1-e) K(h) = pi/2 / agm(1+h,1-h) = pi/2 / agm(1,b/a) / (1+h) → K(e) = (1+h) K(h) (01-21-2020 05:16 PM)Albert Chan Wrote: \(\large p(a,b) = 2× \left( p({a+b \over 2}, \sqrt{ab}) - {\pi a b \over AGM(a,b)}\right)\) With ellipse_perimeter = 4 a E(e), we have: 4 a E(e) = 4 (a+b) E(h) - 4 b K(e) = 4 (a+b) E(h) - 4 b (1+h) K(h) → E(e) = 2/(h+1) * E(h) - (1-h) * K(h) |
06-05-2020, 08:09 PM
(This post was last modified: 06-06-2020 05:14 PM by Albert Chan.)
We can get E(e),K(e) by recursively going for E(h),K(h), like this.
Note: code use parameter m, not modulus k, m = k^2 Note: code quit when m is small enough for taylor linear term estimate. E(m=ε) ≈ pi/2 - (pi/8)*ε , K(m=ε) ≈ pi/2 + (pi/8)*ε Code: from cmath import sqrt, pi >>> e, k = EK(0.96, verbal=True) m = (2.89332317725e-05+0j) E(m) = (1.57078496468+0j) K(m) = (1.57080768903+0j) m = (0.0212862362522+0j) E(m) = (1.56240357945+0j) K(m) = (1.57925700384+0j) m = (0.444444444444+0j) E(m) = (1.3781039379+0j) K(m) = (1.80966749549+0j) m = 0.96 E(m) = (1.05050222698+0j) K(m) = (3.01611249248+0j) >>> 4 * 50 * abs(e) # ellipse_perimeter(10,50), error = -3 ULP 210.10044539689011 >>> e, k = EK(2, verbal=True) # see https://www.hpmuseum.org/forum/thread-15...#pid132745 m = (5.57959210499e-05-0j) E(m) = (1.57077441556+0j) K(m) = (1.57081823849+0j) m = (0.0294372515229-0j) E(m) = (1.55917174457+0j) K(m) = (1.58255172722+0j) m = (-1-0j) E(m) = (1.91009889451+0j) K(m) = (1.31102877715+0j) m = 2 E(m) = (0.599070117368+0.599070117368j) K(m) = (1.31102877715-1.31102877715j) |
06-06-2020, 05:12 PM
(This post was last modified: 06-09-2020 12:55 AM by Albert Chan.)
Improvement to my previous EK(m)
When m is small, the term E(m) - K(m) is losing significant digits. Worse, catastrophic cancellation occurs at the base of recursion. EKmc(m) returns E(m)-c, K(m)-c, where c=pi/2, similarly to expm1(x) = exp(x) - 1 EK(m) is now a simple wrapper for EKmc(m), adding back the c's. Code: from cmath import sqrt, pi >>> e, k = EK(0.96) >>> 4 * 50 * abs(e) # ellipse_perimeter(10,50), error = 0 ULP 210.10044539689002 |
08-01-2020, 12:31 PM
(This post was last modified: 01-26-2023 08:37 PM by Albert Chan.)
(01-21-2020 05:16 PM)Albert Chan Wrote:(01-19-2020 11:00 PM)Albert Chan Wrote: \(\large p(a,b) = 2× \left( p({a+b \over 2}, \sqrt{ab}) - {\pi a b \over AGM(a,b)}\right)\) If we are at focus F2, and we let distance a0 = AF2, b0 = BF2, eccentricity of ellipse is also h0 ellipse major-axis a = OB = (a0+b0)/2 ellipse minor-axis b = OC = √((CF2)² - (OF2)²) = √(a² - (a-b0)²) = √((2a-b0)*b0) = √(a0*b0) This matched ellipse perimeter recursive AGM formula! Example, lets try the earth-moon orbit, average orbital distance 384748 km a0 = 406731 km b0 = 364397 km e = h0 = (a0-b0)/(a0+b0) = 42334/771128 ≈ 0.0549 Update, Jan 26, 2023 In 2 years, California State University, San Bernardino picture link is dead. It is ironic that CSUSB motto is "We Define The Future". Above picture were from WayBack Machine, Thanks! |
04-11-2023, 09:43 PM
My name is Hazem Albadry from Iraq born in 1956
Finally I discovered the exact formula of Perimeter of an Ellipse name (Hazem C-Ellipse) as following: C = a * ((π-2)/45 * arcsine(b/a) + 4) Where a is the major radius of ellipse Where b is the minor radius of ellipse When a=b then the formula will be C = 2aπ (As circle) And when b=0 then the formula will be C = 4a (As lines) I hope this help anyone who interested in Perimeter of an Ellipse. Best regards. Hazem Hameed Rashid Albadry Hazemhameed90@gmail.com Baghdad / Iraq |
04-12-2023, 01:53 AM
(04-11-2023 09:43 PM)hazem Wrote: My name is Hazem Albadry from Iraq born in 1956 Thank you for sharing this here. In the equations, what is "n" ? --Bob Prosperi |
04-12-2023, 05:43 AM
Look closely, Bob, that's not an 'n' ;-)
And I'm afraid to say that any mathematical formula that requires degrees mode for the arcsin is suspicious, to say the least. Let's try it with A=10 and B=50 (it requires B>=A), Albert's example from above. Then the result is 214.6.. So not even a very good approximation.. Cheers, Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
04-12-2023, 12:44 PM
(04-12-2023 05:43 AM)Werner Wrote: Look closely, Bob, that's not an 'n' ;-) Good eyes Werner, thanks. The ironic part is I paused and wondered why there was no Pi in the formula, which led me to notice the "n", which isn't an "n". You know the rest. --Bob Prosperi |
04-12-2023, 02:29 PM
(04-12-2023 05:43 AM)Werner Wrote: Look closely, Bob, [...] Correct. The proper way to unambiguously show Pi would be like this: \(\pi\) Quote:And I'm afraid to say that any mathematical formula that requires degrees mode for the arcsin is suspicious, to say the least. [...] So not even a very good approximation.. Indeed. The OP says his formula is exact but nothing could be further from the truth. Computing the perimeter of a generic ellipse exactly requires, well, elliptic functions, not elementary functions such as inverse trigonometric ones. V. All My Articles & other Materials here: Valentin Albillo's HP Collection |
04-12-2023, 07:22 PM
(This post was last modified: 04-16-2023 12:26 PM by floppy.)
Exact formula for ellipse perimeter calculation? "Yes".
Via division of 2 infinite iterated functions MAGM and AGM (I dont call them elliptic functions; other does). http://www.ams.org/notices/201208/rtx120801094p.pdf On your calc, you just stop the AGM and MAGM routines when the delta of the iteration result is good enough for you (I stop when it is E-8; one time I tried E-9 but it went undefinitively and suppose this is due to the HP41 calculation approximation making a convergence unstable. A 128bit PC would give an outstanding precision). Code for HP41 standard below (no SandMath ROM or other modules required) which can be overtaken for other computer. The documentation should make possible a full understanding of the "iterated" behaviour. Since everything can be improved.. any suggestion to improve the code is welcome. Use case: 10 ENTER 6 XEQ ALPHA ELPER ALPHA 51.05399775 Update1: - code revisited/simplified since the convergence is stable on HP41 and an exit criteria like E-8 not mandatory - file upload redone Code: ; Ellipse perimeter calculation according MAGM and AGM HP71 4TH/ASM & Multimod, HP41CV/X & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X, HP75D |
04-13-2023, 02:06 PM
(This post was last modified: 04-13-2023 02:10 PM by Dave Hicks.)
RE: Perimeter of Ellipse | |||
04-13-2023, 02:20 PM
(04-13-2023 02:06 PM)hazem Wrote:Can you give the result with a=10 and b=6? (I dont get it)(04-12-2023 01:53 AM)rprosperi Wrote: Thank you for sharing this here.It is Pi Then I will compare with approximations available here https://www.mathsisfun.com/geometry/elli...meter.html HP71 4TH/ASM & Multimod, HP41CV/X & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X, HP75D |
04-13-2023, 05:23 PM
(04-12-2023 07:22 PM)floppy Wrote: On your calc, you just stop the AGM and MAGM routines when the delta of the iteration result is good enough for you If you compare sucessive GM's or AM's (but not AM vs GM), it will not get into infinite loop. see https://www.hpmuseum.org/forum/thread-15...#pid134773 FNP(A,B) for perimeter of ellipse, by MAGM, until full convergence of GM's (06-04-2021 07:14 PM)Albert Chan Wrote: 10 DEF FNP(A,B) @ S=A*A+B*B @ T=1 >fnp(10, 6) 51.0539977270 Exact ellipse perimeter, rounded to 12 digits = 51.0539977268 |
04-15-2023, 06:21 PM
(This post was last modified: 04-19-2023 09:50 AM by floppy.)
+1.
Now leaving the "simplicity" of having MAGM divided by AGM, at the cost of calculation time, for calculating ellipse perimeter, and lets show what I call "GaussKummer-like" with "AGM functional turbo boosting". If I remember it was already posted in this forum for HP15c. Now for HP41. NO APPROXIMATION: only limitation to the available precision with HP41. Code: ; calcul ellipse perimeter GaussKummer like with AGM exact function for Just tested on an HP41CX. Printing w/o comment (in order to see the length). Code: 01*LBL "PERE12" Now latest shortest version on HP41 (no check of flat ellipse; no modules required) Code: 01*LBL "PERE12" HP71 4TH/ASM & Multimod, HP41CV/X & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X, HP75D |
