Perimeter of Ellipse
03-05-2016, 04:19 PM
Although simple formulae for the perimeter of an ellipse exist, they are only approximations. Exact formulae are complicated. The following program uses a converging iteration technique instead. Ported from a QBASIC program by Gérard P. Michon.
Syntax: EllipsePerimeter(a,b), where a & b are the lengths of the axes (order doesn't matter)
Output: perimeter of ellipse
Examples:
EllipsePerimeter(0.5, 0.5) --> 3.14159265359
EllipsePerimeter(3, 4) --> 22.1034921607
gk(h);
cayley(x);
EXPORT EllipsePerimeter(a,b)
LOCAL x,h,P;
a:=ABS(a);
b:=ABS(b);
IF a < b THEN x:=a; a:=b; b:=x; END;
IF b < 0.28*a THEN
 P := 4*a*cayley((b/a)^2);
ELSE
 h := ((a-b)/(a+b))^2;
 P := pI*(a+b)*gk(h);
RETURN P;
END
gk(h)
LOCAL z,x,n;
z := 0; x := 1; n := 0;
WHILE z + x <> z
 DO
 n := n + 1;
 x := h * x * ((n-1.5)/n)^2;
 z := z + x;
RETURN 1 + z;
cayley(x)
LOCAL y,t,n,z,u,v,w;
y := LOG(16 / x) - 1;
t := x / 4;
n := 1;
z := 0;
u := t * y;
v := (n - .5) / n;
w := .5 / ((n - .5) * n);
WHILE z <> z + u
 DO
 z := z + u;
 n := n + 1;
 t := x * t * v;
 v := (n - .5) / n;
 t := t * v;
 y := y - w;
 y := y - w;
 u := t * y;
RETURN 1 + z;
<0|ɸ|0>
-Joe-
03-06-2016, 11:55 AM
RE: Perimeter of Ellipse
I was going to suggest the following:
 RETURN ∫(√(((a*COS(T))^2+(b*SIN(T))^2)),T,0,2*π);
but it seems that PPL doesn't like local variables inside of an integral.
Here's a work-around:
 A:=a;
 B:=b;
 RETURN ∫(√(((A*COS(T))^2+(B*SIN(T))^2)),T,0,2*π);
03-06-2016, 02:16 PM
or this work-around:
 RETURN approx(int(√(((a*COS(T))^2+(b*SIN(T))^2)),T,0,2*π));
03-06-2016, 02:40 PM
Did not know that about perimeters of ellipses.
Learn something here everyday.
2speed HP41CX,int2XMEM+ZEN, HPIL+DEVEL, HPIL+X/IO, I/R, 82143, 82163, 82162 -25,35,45,55,65,67,70,80
03-06-2016, 06:42 PM
I guess the perimeter is computed using the arithmetic geometric mean, correct?
03-07-2016, 01:16 PM (This post was last modified: 03-07-2016 01:16 PM by SlideRule.)
(03-05-2016 04:19 PM)Joe Horn Wrote:  Although simple formulae for the perimeter of an ellipse exist, they are only approximations. Exact formulae are complicated. The following program uses a converging iteration technique instead.
When I was employed by an Engineering firm specializing in Bridge Design, we used elliptical substructure rather than rectangular. The design was easy enough BUT the insitu replication of that design was elusive, so we substituted cirular arcs (tangent) for the desired elipse. The desired substitute was reflective about both inplane axis, so only 1/4 of the form need be designed. Seldom were more the 5 contiguous arcs needed while 3 arcs satisfied most requirements. The circle(s) approximations functioned well within the desired strutural requirements while easing the construction layout.
BEST!
SlideRule
03-07-2016, 03:34 PM
(03-06-2016 02:16 PM)Wes Loewer Wrote:  or this work-around:
Your program above (unlike mine) always agrees with Wolfram Alpha's perimeter of an ellipse, even for very eccentric ellipses. Congratulations! [Image: notworthy.gif]
<0|ɸ|0>
-Joe-
03-09-2016, 08:39 AM (This post was last modified: 03-09-2016 08:42 AM by parisse.)
I can add this functionnality to perimeter, using the approximate value of the integral
http://www-fourier.ujf-grenoble.fr/%7epa...(-1,1,2))&
(make sure to clear your browser cache if you have already tried Xcas offline).
03-24-2019, 12:42 PM
From HP Forum Archive 21, message 5, and some optimizations, I get:
Quote:local sqrt, pi = math.sqrt, math.pi
function ellipsePerimeter(a, b) -- agm2 method
    local s = 0.5 * (a*a+b*b)
    local t = 0.25
    while true do
        local k = b - a
        local s1 = s - t*k*k
        if s == s1 then return 2*pi*s/(a+0.5*k) end
        b = sqrt(a*b)
        a = a + 0.5*k
        s = s1
        t = t + t
    end
end
Example:
lua> ellipsePerimeter(1, 2) --> 9.688448220547675
lua> ellipsePerimeter(2, 3) --> 15.86543958929059
lua> ellipsePerimeter(3, 4) --> 22.103492160709504
