Bugged 'Define' - on android only [?]
10-14-2017, 07:58 AM (This post was last modified: 10-14-2017 08:03 AM by chromos.)
Let's assume this defined function:
It works as expected:
But if you make one of the next steps (and it doesn't matter if you first switch calculator off by [Shift]+[On] or not):
  • tapping on triangle system button on phone;
  • tapping on circle system button and then wipe HP Prime from running apps (square system button);
... and if you launch the HP Prime then defined function no longer works:
It's because variable became unchecked:
I'm running version 11586 from 2017-04-20 on Nexus 6:
Prime G2, 15C CE
10-14-2017, 08:25 AM (This post was last modified: 10-14-2017 08:26 AM by webmasterpdx.)
RE: Bugged 'Define' - on android only [?]
what do you mean by triangle, square and circle system button?
Are these android buttons or HP Prime buttons?
10-14-2017, 08:34 AM
As I wrote:
"triangle system button on phone". In most cases, it means virtual at-bottom-of-screen buttons on current android smartphones.
Prime G2, 15C CE
10-14-2017, 08:49 AM
I haven't seen an android phone with those symbols on them for about 10 years...:-)
I just call them the home button and the right and left buttons.
If it were a prime button, anyone could help you, but I think since it's an android thing, you are going to need the help from someone from HP that worked on the emulator for android.
10-14-2017, 09:11 AM
(10-14-2017 08:49 AM)webmasterpdx Wrote:  I haven't seen an android phone with those symbols on them for about 10 years...:-)
Now back on topic, please.
Prime G2, 15C CE
