10-14-2017, 07:58 AM
Let's assume this defined function:
[attachment=5244]
It works as expected:
[attachment=5245]
But if you make one of the next steps (and it doesn't matter if you first switch calculator off by [Shift]+[On] or not):
... and if you launch the HP Prime then defined function no longer works:
[attachment=5246]
It's because variable became unchecked:
[attachment=5247]
I'm running version 11586 from 2017-04-20 on Nexus 6:
[attachment=5248]
[attachment=5244]
[attachment=5245]
- tapping on triangle system button on phone;
- tapping on circle system button and then wipe HP Prime from running apps (square system button);
[attachment=5246]
[attachment=5247]
[attachment=5248]
