Integration failure
08-21-2016, 10:14 PM
Integration failure
Int (ln(tan(X)))/((sin(X))(cos(X))) returns the integral
TI NSpire returns ((ln(tan(X)))^2)/2
Both return same answer in approximate mode.
08-21-2016, 10:23 PM
RE: Integration failure
...that is, when made into a definite integral!
08-22-2016, 03:50 AM
(08-21-2016 10:14 PM)lrdheat Wrote:  Int (ln(tan(X)))/((sin(X))(cos(X))) returns the integral
Are you sure the parentheses in your input are correct? As shown, the integral ends before the division sign, which I suspect is not what you wanted.
<0|ɸ|0>
-Joe-
08-22-2016, 06:09 AM
If you derive (ln(tan(x)))^2, there should be a (1+tan(x)^2) term, but I don't see it in your input (which has strange parenthesis and missing * sign).
08-22-2016, 08:30 AM
Hello Bernard.
Using 1+tan^2 = 1/cos^2,
the derivative of ((ln(tan(x))^2)/2 is ln(tan(x))/(sin(x)*cos(x)),
which is what I think the original poster meant.
I have no Prime to verify though.
Cheers, Werner
08-22-2016, 10:20 AM
* is missing and parenthesis levels are "untidy" ;-)
Best,
Aries :-)
08-22-2016, 12:27 PM
Hi!
This is what I get (with 10077).
Irdheat is OK.
Marcel.
Attached File(s) Thumbnail(s)
08-22-2016, 04:07 PM
Xcas also behaves the same. Thanks!
TW
08-22-2016, 06:14 PM
Then you can solve it with trigtan
a:=int(ln(tan(x))/(sin(x)*cos(x))); trigtan(a)
08-24-2016, 08:30 PM
Don't know if this is related or not but ∫(ln(tan(x)),x) returns the following screen shot:
the denominator is +([TAN(x)^2 1]). The plus sign is located incorrectly but when you copy it onto the command line it is correct.
This is with 10077.
-road
08-25-2016, 05:58 AM
This is unrelated, but thanks for the bug report!
