[SOLVED] Cannot solve limit (1+x/n)^n; n=>infinity
06-30-2015, 03:55 AM (This post was last modified: 06-30-2015 12:19 PM by chromos.)
I haven't real calculator, but both my android app (2015 04 20) and HP Prime PC (Rev:8151) solve limit (1+x/n)^n; n=>infinity as 1, but proper result is e^x. Am I doing something wrong or is it bug?
Geocaching Coords Solver, Number of triangles Puzzle
06-30-2015, 05:28 AM
RE: Cannot solve limit (1+x/n)^n; n=>infinity
I just checked, I get exp(x), maybe you have x assigned to 0?
06-30-2015, 05:41 AM
Its a matter of parentheses: the way you've written it the nth power is applied to the result of limit(1+x/n).
06-30-2015, 05:54 AM
Two things:
1. The parenthesis supplied for the limit function is intended to hold the entire argument. You put the power of "n" outside the function.
Instead of lim(1+x/n)^n use lim((1+x/n)^n).
2. Put the calculator in radians mode. (Sorry, I have no idea why this is so, but it applies to many non-trig functions. It's best to keep the calculator in radians mode until you need to use degrees.)
06-30-2015, 12:13 PM
Thank you all. I didn't think I am so stupid. :-)
