HP82161A Digital Cassette Drive
02-14-2024, 12:19 AM
I am having trouble getting the Drive to be recognized by the HPIL Loop. The cables are good and it sees my printer which works fine. The drive worked a couple of months ago, so not sure what the problem is.
I tried running the DIR, STOPIO, and AUTOIO commands and the drive does nothing. Cleaned the connectors just in case. When a tape is inserted the drive rewinds the tape to the beginning.
Any help would be appreciated.
Randy
02-14-2024, 01:44 PM (This post was last modified: 02-14-2024 06:48 PM by floppy.)
RE: HP82161A Digital Cassette Drive
If your drive is dead, I would like to buy it (few money). Why buying a dead cassette player? Hide that stuff in the picture in it (for fun; no 100% necessity).
And: if your cassette recorder is dead, just use a PI2 with USB Stick on it instead of buying another on eBay (like in the picture; hopefully you have a pilbox and an HP-IL module).
Update: see link https://www.hpmuseum.org/forum/thread-19053.html
Attached File(s) Thumbnail(s)
HP71 4TH/ASM & Multimod, HP41CV/X & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X, HP75D
02-14-2024, 05:22 PM
What’s a ‘P12 with USB attached please?
Denny Tuckerman
02-14-2024, 05:52 PM
(02-14-2024 05:22 PM)Leviset Wrote:  What’s a ‘P12 with USB attached please?
A Raspberry Pi 2, which runs an emulation of HP-IL, and you could then use a USB disk as a cassette drive.
See i.e. here for more info:
Cheers,
[35/45/55/65/67/97/80 21/25/29C 31E/32E/33E|C/34C/38E 41C|CV|CX 71B 10C/11C/12C/15C|CE/16C 32S|SII/42S 28C|S 48GX/49G/50G 35S 41X]
02-14-2024, 10:03 PM
Don't think I'm ready to give up the ghost yet, cuz I have a perfectly good "PPC Journl PGMS V9&10 1984, cassette" that I would like to use (Along with a bunch of others). Hopefully I won't have to buy a new drive. I will look into the P12.
PS: It's nice to have folks you can ask questions!
RH
02-15-2024, 01:50 AM
There's one for sale in the Classified section.
02-15-2024, 01:56 AM
(02-14-2024 10:03 PM)knife31 Wrote:  Don't think I'm ready to give up the ghost yet, cuz I have a perfectly good "PPC Journl PGMS V9&10 1984, cassette" that I would like to use (Along with a bunch of others). Hopefully I won't have to buy a new drive. I will look into the P12.
RH
If you can't get it working, I'd be happy to extract the files from the tape and copy them to a LIF volume file you can access via ILPer/PIL-Box. I'd probably be willing to do several, but that depends on how many "a bunch" means.
Contact me by email to follow-up if interested.
02-15-2024, 04:23 AM
I think that one was for parts but will look again. Going to do a bit of research. The machine worked not too long ago so can't think of why it would not work now. May be that for some reason the HP-IL has been told to ignore it.
Weird I used the Cat 7 function of the CCD Mod and it worked. Tried the DIR function of the HP-IL and it does nothing. This is going to be a deep Rabbit-Hole.
02-15-2024, 04:36 AM
Stranger still now it works with the DIR command and either works correctly or shows "Drive Error or Medm Err" depending on the tape (Randomly it seems). I guess I will have to check out the tapes using the stuff I read in the forums. I did have to fix the PPC Tapes felt and it read it, once at least.
02-15-2024, 04:39 AM
Oh
Mr Prosperi thanks for the offer.
Randy
02-16-2024, 01:14 AM
Have you cleaned the tape head itself?
02-16-2024, 05:23 AM
I did clean the heads
It reads other tapes so it must be just this tape. Of course it would be the PPC Module Tape. I saw a wrinkle in the tape, not sure how to get it out.
Randy
