Displaying ∂u/∂t but only get ∂u() and displaying 2nd order ode
09-13-2023, 05:14 AM
Thank you for your time.
Background information
Using the top row button, 3rd from the left one can select a set of templates such as:numerator/denominator a number raised to a power, as well as ∂u/∂t - the u and t are squares you inset in the squares.
Before I have been able to display in the home screen ∂u/∂t
I want to display
∂u/∂t
BUT now only able to display
How do I display ∂u/∂t?
How do I display ∂²u/∂x²
Thank you
Anthony, Sydney
09-13-2023, 12:48 PM
RE: Displaying ∂u/∂t but only get ∂u() and displaying 2nd order ode
Your 'Entry' has changed to Algebraic.
So set Entry:=0, or use the Home Settings to change to 'Textbook' or RPN
09-13-2023, 01:10 PM (This post was last modified: 09-13-2023 01:12 PM by Anthony The Koala.)
It is inexplicable but I managed to be able to express the numerator and demominator of a partial derivative.
Nevertheless, if there is a method to get a numerator and denominator such as
∂u/∂x instead of ∂() I would be happy.
I managed to get a double derivative such as ∂²u/∂x²
Example
Suppose we have a 2nd order ode of
y"+3*y'=0
A solution is:
y = C1 + C2*e^(-3x)
In the prime:
desolve(∂(∂u/∂x)∂x+3*∂u/∂x=0,x,y)
G_0*e^(-3x) + G_1
To achieve ∂(∂u/∂x)∂x
1. Press the top row, third button from the left select ∂ /∂.
2. On the numerator of ∂ /∂ place ∂u/∂x. On the denominator of ∂ /∂ place an x to finally make it
∂(∂u/∂x)∂x
Thank you
Anthony, Sydney
