Video MC00701A or HP92198
09-17-2022, 12:45 AM
Hi
This is a 80 column video interface question Running from : HP75C on HPIL loop Monitor : LG 4:3 Generic Connection: CGI to VGA convertor ( see jpg) Condition: works well Problem: running from keyboard I get 80 characters displayed. Small program in Basic wraps screen around 32/40 characters. Question: How do I get full 80 Characters to display when running from program? https://photos.google.com/search/_tra_/p...un7G4z7m8j https://photos.google.com/search/_tra_/p...VPMMAFLwI9 //Nick |
09-17-2022, 03:24 AM
RE: Video MC00701A or HP92198
FYI, your pictures are not showing and the links are not working.
If your program(s) use DISP then try the following ... DISPLAY IS ":d1" WIDTH 80 DISP "12345678901234567890123456789012345678901234567890123456789012345678901234567890" LIST "PROGRAM_NAME" RUN "PROGRAM_NAME" DISPLAY IS * Verify that your program(s) does not change the WIDTH value. If your program(s) use PRINT then try the following ... PRINTER IS ":d1" PWIDTH 80 PRINT "12345678901234567890123456789012345678901234567890123456789012345678901234567890" PLIST "PROGRAM_NAME" RUN "PROGRAM_NAME" PRINTER IS * Verify that your program(s) does not change the PWIDTH value. HP-75 manuals are available here → HP-75 Owner's Manual & HP-75 Reference Manual |
09-17-2022, 04:17 AM
Thank you;
I will use google drive to send pictures. Link https://drive.google.com/file/d/1-0bzAzi...aring[/url] Tell me if you see those.. |
