Full Version: Video MC00701A or HP92198
Hi
This is a 80 column video interface question
Running from : HP75C on HPIL loop
Monitor : LG 4:3 Generic
Connection: CGI to VGA convertor ( see jpg)
Condition: works well
Problem: running from keyboard I get 80 characters displayed.
Small program in Basic wraps screen around 32/40 characters.
Question: How do I get full 80 Characters to display when running from program?
[Image: AF1QipPTDzt9lgmRvAwAM7v72znxJVxetqun7G4z7m8j]
[Image: AF1QipOu3qa_zVUnwU16iGnqrfNImqhHs0VPMMAFLwI9]
https://photos.google.com/search/_tra_/p...un7G4z7m8j
https://photos.google.com/search/_tra_/p...VPMMAFLwI9
//Nick
FYI, your pictures are not showing and the links are not working.
If your program(s) use DISP then try the following ...
DISPLAY IS ":d1"
WIDTH 80
DISP "12345678901234567890123456789012345678901234567890123456789012345678901234567890​"
LIST "PROGRAM_NAME"
RUN "PROGRAM_NAME"
DISPLAY IS *
Verify that your program(s) does not change the WIDTH value.
If your program(s) use PRINT then try the following ...
PRINTER IS ":d1"
PWIDTH 80
PRINT "12345678901234567890123456789012345678901234567890123456789012345678901234567890​"
PLIST "PROGRAM_NAME"
RUN "PROGRAM_NAME"
PRINTER IS *
Verify that your program(s) does not change the PWIDTH value.
HP-75 manuals are available here → HP-75 Owner's Manual & HP-75 Reference Manual
Thank you;
I will use google drive to send pictures.
[Image: view?usp=sharing][url]
Link
https://drive.google.com/file/d/1-0bzAzi...aring[/url]
Tell me if you see those..
