HP 35s - How to write a for loop
02-11-2020, 05:35 PM
Hi!
I need to create a program to compute Euler's totient function but
i'm stuck in a for loop.
I have to write something like that:
for(i = 1; i < n; i++)
  // do stuff
I'm aware of the ISG operator and the loop-control number (i.e.
ccccccc.fffii
but i don't known how to integrate it with the i < n part. Is it possible? If so, can someone give
me an example of a for loop?
Thanks Smile
02-11-2020, 08:32 PM
RE: HP 35s - How to write a for loop
If you come from a high level programming language then programming loops and other control structures with calculators that rely on "keystroke programming" can be a very major PIA. But it is possible (to a degree).
(02-11-2020 05:35 PM)bxzj Wrote:  If so, can someone give me an example of a for loop?
This is an online version of the calculator manual: https://www.manualslib.com/manual/257003...228#manual
When you click forward two pages you can see a very simple example.
Have fun with it (so to say...)
Max
02-11-2020, 08:44 PM
(02-11-2020 08:32 PM)Maximilian Hohmann Wrote:  Hello!
Max
The problem with the example provided by the manual is that it works with a “fixed limit”(for instance from 0 to 10 or from 0 to 50), what I want to do is a “dynamic” loop: something like “from 1 to x” with x inserted by the user. But I don’t know if it’s possible.
02-11-2020, 10:39 PM
I think so.
Simply take the user input upper limit and construct the control word.
User keys 499
R/S
Have the program take the 499, divide by 1000, then add one.
The control word would be 1.499 and the ISG loop would repeat the steps with the variable changing from 1 to 499.
If the user entered 50 or 75 or ? the loop would run from 1 to that supplied number of times. Something like this.
LBL T
1E3
1
STO 00
LBL L
Do something in here
ISG 00
GTO L
STOP
Is this what you are thinking about ?
02-12-2020, 04:21 PM
(02-11-2020 10:39 PM)Gene Wrote:  I think so.
User keys 499
R/S
LBL T
1E3
1
STO 00
LBL L
ISG 00
GTO L
STOP
Exactly! thanks for your help.
btw, is there any advantages to use (I)(STO 0) or (J)(STO .) registers instead of A-Z one?
02-17-2020, 10:20 AM
Far better to use DSE instead of ISG, because
  • no need to prepare the loop (1000 / 1 + is not required)
  • not limited the loop end value to 999
LBL T
  STO A
  STO B
  LBL L
    RCL B
    RCL - A
    STOP
    DSE A
    GTO L
RTN
This is do the job also (counts from 0 to N-1). A is the counter register and B is for storing the user data to reverse the counting direction (or maybe it required later).
Csaba
User(s) browsing this thread:
