How to enter a variable in an INPUT ?
12-06-2019, 09:31 PM
(This post was last modified: 12-07-2019 07:19 PM by What_Else.)
Hello, I bought an HP Prime there is very little time!
I wanted to test the HP Prime Basic language by doing a vector product calculation program. The problem is that I can not at all include variables in INPUT (I wish I could enter 4x for example instead of 4) Code: EXPORT Produit_Vectoriel() BEGIN LOCAL A,B,C,D,E,F; LOCAL X,Y,Z,N; INPUT({A,B,C},"Vecteur 1",{"X = ","Y = ","Z = "}); INPUT({D,E,F},"Vecteur 2",{"X' = ","Y' = ","Z' = "}); CAS("B*F*-C*E▶X"); C*D-A*F▶Y; A*E-B*D▶Z; CAS("sqrt(X^2+Y^2+Z^2)▶N"); PRINT(); PRINT(" "); PRINT(" Résultat :"); PRINT(" |"+X); PRINT(" |"+Y); PRINT(" |"+Z); PRINT(" "); PRINT(" Norme : "+N); END; Thank you ![]() |
12-07-2019, 10:14 PM
RE: How to enter a variable in an INPUT ?
If you do input as a string you can use the EXPR() command
EXPR("4*X"); |
12-07-2019, 10:48 PM
(This post was last modified: 12-07-2019 11:00 PM by What_Else.)
(12-07-2019 10:14 PM)Dougggg Wrote: If you do input as a string you can use the EXPR() command Have I to put that in the code of the program, or when I use it ? In fact, my program works, I would just like to know how to integrate variables into the calculation ![]() ![]() |
12-09-2019, 03:11 AM
here is an example that worked for me to input a formula with variables in the input command:
INPUT({X,{FF,[8]}}); Y:=EVAL(FF); If that is your question |
12-09-2019, 06:29 PM
RE: How to enter a variable in an INPUT ? | |||
12-10-2019, 04:06 AM
That was just example of how to do the input statement to accept a string, your variables maybe different
12-10-2019, 06:15 PM
12-10-2019, 06:40 PM
(12-10-2019 06:15 PM)CyberAngel Wrote:(12-09-2019 03:11 AM)Dougggg Wrote: here is an example that worked for me to input a formula with variables in the input command: Do you have any example, like a little program with these lines ? |
