StreamSmart 400, missing wire
05-06-2014, 01:00 PM
Hi.
I have opened a StreamSmart 400 to see what is inside. To my surprise one of the cables coming in from the "serial" cable is not connected to anything. There are four cables: green, white, red and black. The former three have a labeled position in the board (G,W,R) but the black one is floating around. Probably it was soldered to some part, but I cannot find a clear pad where it should be soldered. Please, anyone having this device would take a look where the black cable is connected?. :-) Inakiz. |
05-06-2014, 04:00 PM
(This post was last modified: 05-06-2014 04:06 PM by Gerson W. Barbosa.)
RE: StreamSmart 400, missing wire | |||
05-06-2014, 06:15 PM
A picture is worth a thousand words...
Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
05-06-2014, 06:40 PM
(This post was last modified: 05-06-2014 06:41 PM by Tim Wessman.)
It's a magic black wire!
05-06-2014, 08:04 PM
It's just prepared for radio data transmission ...
05-06-2014, 09:13 PM
(05-06-2014 06:40 PM)Tim Wessman Wrote: It's a magic black wire!But it's missing the 'more magic' switch;-) -- Ray |
05-06-2014, 09:30 PM
05-07-2014, 07:11 AM
Looks like it could cause a shortcut with some bad luck. I'd apply insulating tape.
05-07-2014, 07:06 PM
(05-06-2014 04:00 PM)Gerson W. Barbosa Wrote:(05-06-2014 01:00 PM)inakiz Wrote: Please, anyone having this device would take a look where the black cable is connected?. :-) What does the main chip says? My website: erwin.ried.cl |
05-08-2014, 12:30 AM
(This post was last modified: 05-08-2014 12:38 AM by Gerson W. Barbosa.)
(05-07-2014 07:06 PM)eried Wrote: What does the main chip says? AT918AM7S64 (not sure about the first letter). https://www.dropbox.com/s/bz0z2nkr3afu5q...AM7S64.JPG |
