New [Set] menu
12-17-2018, 03:13 AM (This post was last modified: 12-18-2019 03:26 PM by compsystems.)
New [Set] menu
Hello
The concept of set is almost the first thing taught in mathematics, for this reason, I think you should add a submenu in [TOOLS] [Math] [Set] with the following eight instructions, with symbols as tags
1:∪
2: ∩
3: \
4: ×
5: ∈
6: ⊂
7: Δ
8: '
1: ∪
example set[ "b", "a", "c", "a" ] union set[ "a", "d" ] //[↵] set["b","a","c","d"]
2: ∩
set[ "b", "a", "c", "a" ] intersect set[ "a", "d" ] //[[↵] set["a"]
3: \ (minus)
set[ "b", "a", "c", "a" ] minus set[ "a", "d" ] //[[↵] set["b","c"]
4: × (cartesian product)
set[ "b", "a", "c", "a" ] * set[ "a", "d" ] //[ [↵]
[["b","a"],
["b","d"],
["a","a"],
["a","d"],
["c","a"],
["c","d"]]
5: ∈ (is_element)
evalb(is_element("a",set["b","a","c","a"])) [↵]true // For a more intuitive output the numeric value [>0]/0 should be symbolix true/false, in this way the use of the EVALB() command is avoided.
6: ⊂ (is_included) this function is not yet visible in the hp-prime catalog =(
evalb(is_included(set[ "a", "d" ], set[ "b", "a", "c", "a" ])) [↵] false
7: Δ (Symmetric difference )
M_:= set[ "A", "B", "C"];
N_:= set[ "B", "G", "L", "E"];
U_:= set[ "A", "B", "C", "G", "L", "E", "I", "J", "F", "H"]
M_ union N_ //[[↵] set["A","B","C","G","L","E"]
M_ intersect N_ //[[↵] set["B"]
M_ minus N_ //[[↵] set["A","C"]
M_ Δ N_ //[[↵] set["G","L","E","A","C"] // Code:
PHP Code:
(N_ minus M_union (M_ minus N_
8: ' (Complement )
M' U //[[↵] set["G","L","E","I","J","F","H"] // Code: U_ minus M_
N' U //[[↵] set["A","C","I","J","F","H"] // Code: U_ minus N_
The only formal languages are those that use mathematics and computing, the rest are ambiguous.
12-18-2018, 12:48 PM
RE: New [Set] menu
This is awesome. Great suggestion compsystems!
12-18-2018, 09:33 PM
RE: New [Set] menu
It would be interesting a separate application for this task, I think it would be colorful
Viga C | TD | FB
12-19-2018, 02:16 AM
RE: New [Set] menu
I notice that in the LIST menu, it has three set commands, but the list type is not always equal to a set
test
index:=1:; E_ := [ "H", "E", "L", "L", "O" ]:;
find( "L", E_ ) [enter]
[3,4] // "L" is in two positions
index(E_,"L") [enter]
3
F_ := set[ "H", "E", "L", "L", "O" ] [enter] set[ "H", "E", "L", "O" ]
find( "L", F_ ) [enter]
[3] // "L" is in one positions
index(F_,"L") [enter]
3
E_ == F_ [enter] false
also diference cmd does not work on a set
DIFFERENCE(set["b","a","c","a"],set["a","d"]) [enter]
{"b","c","d"}
set[ "b", "a", "c", "a" ] minus set[ "a", "d" ] [↵] set["b","c"]
