HP 50g Programming Competition: How Many Partitions of an Integer in 4 Squares
04-13-2018, 11:35 AM (This post was last modified: 04-13-2018 11:35 AM by Gerald H.)
As is well-known, every integer can be represented as sum of max 4 squares
https://en.wikipedia.org/wiki/Lagrange%2...re_theorem
& that the number of such representations can be calculated as
https://en.wikipedia.org/wiki/Jacobi%27s...re_theorem
respecting order & sign.
The task is to write a User RPL programme to calculate the number of representations of any natural number exactly & swiftly.
Winner will be programme with lowest value of time*cuberoot(size).
I have a programme that processes 720^20 in 5.6 sec.
04-13-2018, 01:12 PM (This post was last modified: 04-13-2018 01:12 PM by pier4r.)
RE: HP 50g Programming Competition: How Many Partitions of an Integer in 4 Squares
Gerald thanks for the programming challenge.
What I find interesting is the metric.
(04-13-2018 11:35 AM)Gerald H Wrote:  Winner will be programme with lowest value of time*cuberoot(size).
My perspective is that size is often paramount (likely due to the limited memory of older models). Weighting the speed with the size is also done, but with the size being as important as the speed well.
Applying a sort of a filter to the size, the cube root, so to make two programs that have similar size not too different (well aside from the speed factor) is pretty neat. I'd like to add maintainability as well, but that is hard to define. One should set like a commitee for it.
04-14-2018, 05:10 PM (This post was last modified: 04-14-2018 05:39 PM by Thomas Ritschel.)
I have a solution based on Joe Horn's \Gs (sum of divisors) routine:
%%HP: T(3)A(R)F(.);
@ \Gs, by Joe Horn
@ Sum of ALL the divisors of X
\<< \-> n
\<< n XQ FACTORS R\->I 1 + OBJ\-> 1. SWAP 2. / IP
START PICK3 ROT 1 + ^ 1 - ROT 1 - / *
NEXT
%%HP: T(3)A(R)F(.);
@ Jacobi, by Thomas Ritschel
@ number of representations
@ Jacobi's four-square theorem
\<< DUP 4 MOD
IF 0 ==
THEN DUP 4 / \Gs 32 * NEG
ELSE 0
END SWAP \Gs 8 * +
For 720^20 it computed the result 42050501860687733694307540234728644161563553655537254442648 in less than 2 seconds (Edit: actually 0.8 sec).
However, it has a flaw: It doesn't work for the inputs 1 and 4 (\Gs fails if n==1).
Open for improvements...
04-14-2018, 06:17 PM
I have copied your programmes, Thomas, & for input
720^20
the programme returned
52175039830928864354013492999359544
in
1.42 sec.
04-14-2018, 08:18 PM (This post was last modified: 04-14-2018 08:36 PM by Thomas Ritschel.)
(04-14-2018 06:17 PM)Gerald H Wrote:  I have copied your programmes, Thomas, & for input
720^20
in
1.42 sec.
In my test I had 720^20 as an algebraic object on stack level 1, e.g. entered as '720^20'.
However, when 720^20 is evaluated to 1401683395356260729391818575873415577600000000000000000000 first, and then the Jacobi program is called, I also get 52175039830928864354013492999359544 in about 1.4 sec.
It turns out, that it fails for some kind of algebraic terms like 'a^b' or 'a*b', but not all of them (e.g. '3*11' seems to work well).
To make it save, an 'EVAL' should be added to the Jacobi program:
%%HP: T(3)A(R)F(.);
\<< EVAL DUP 4 MOD
IF 0 ==
ELSE 0
END SWAP \Gs 8 * +
04-15-2018, 12:08 AM
Hi, Gerald H:
(04-13-2018 11:35 AM)Gerald H Wrote:  The task is to write a User RPL programme to calculate the number of representations of any natural number exactly & swiftly.
Nice challenge, regrettably I can't take part in it because it asks for an RPL solution, which I can't provide. However, you say that your program processes 720^20 in 5.6 sec and that's *amazing* speed indeed for such a big number, so I'd like to ask the following:
How long does your program take to process the vey slightly smaller number 720^20-3 ? And how long for the even smaller 720^20-18 ?
Thanks in advance and have a nice weekend.
V.
04-15-2018, 04:58 AM
Yes, Valentin,
5.6 sec
is amazing for
720^20
, but the value was craftily chosen to only contain small factors each to a high power, as part of the algorithm my programme implements requires factorization of the input.
Similarly,
720^20-3
is craftily chosen to have large factors, thus practically rendering the calculation impossible on the 50g using my algorithm.
However, a more crafty algorithm obviating the need to factorize could enable the calculation on the 50g & I'm hopeful one may be found by a Forum member.
04-15-2018, 08:36 AM
Nice observations Valentin and Gerald! (And Thomas of course).
I for one, when a challenge is about the "context X" , wouldn't mind to see solutions "out of the box".
Can someone get 720^20-3 factorized at all (in a calculator context), and only after that factorized quickly? (Same for 720^20-18 and all the others hard variants)
04-15-2018, 11:42 AM (This post was last modified: 04-15-2018 11:44 AM by Thomas Ritschel.)
Here is an improved version of my earlier program.
It is still using the idea from Joe's \Gs routine, but omits the even divisors:
%%HP: T(3)A(R)F(.);
@ idea based on Joe Horn's \Gs
\<< EVAL DUP 2 MOD 1 == 8 24 IFTE SWAP FACTORS DUP SIZE
  IF 0 >
  THEN R\->I OBJ\-> PICK3
    IF 2 ==
    THEN UNROT DROP2 2. -
    END 1 SWAP 1. SWAP 2. / DUP
    IF 0 >
    THEN
      NEXT *
    ELSE DROP2 DROP
    END
  ELSE DROP
  END
Now it properly treats trivial inputs like 1 or 4 and works for algebraic inputs (like '720^20') as well.
The runtime has also improved:
0.66 sec for 720^20 entered as 1401683395356260729391818575873415577600000000000000000000
0.69 sec for 720^20 entered as '720^20'
04-15-2018, 02:07 PM
I've got it further improved and significantly smaller:
%%HP: T(3)A(R)F(.);
\<< FACTORS DUP SIZE
  IF 0 >
  THEN R\->I OBJ\-> 1 SWAP 1. SWAP 2. /
    START PICK3 DUP
      IF 2 ==
      THEN ROT DROP 1 UNROT
      END ROT 1 + ^ 1 - ROT 1 - / *
    NEXT
  ELSE DROP 1
  END 8 *
Runtime for 720^20 and '720^20' is slightly slower: 0.69 and 0.72 secs, respectively.
04-15-2018, 03:09 PM
Very good, Thomas, for your latest version I have 720^20 returning correct value in .78 sec.
Programme returns wrong values for input 0 & 1.
04-15-2018, 03:34 PM (This post was last modified: 04-15-2018 03:35 PM by Thomas Ritschel.)
(04-15-2018 03:09 PM)Gerald H Wrote:  Programme returns wrong values for input 0 & 1.
For input 1 it returns 8, which should be correct (= 2*4 possibilities).
But you're right, for 0 it should return 1 (not 8).
The following version of the program also treats 0 correctly:
%%HP: T(3)A(R)F(.);
\<< DUP
  IF 0 ==
  THEN DROP 1
  ELSE FACTORS DUP SIZE
    IF 0 >
      START PICK3 DUP
        IF 2 ==
      NEXT
    ELSE DROP 1
    END 8 *
  END
04-15-2018, 04:38 PM
Below my programme.
For 107 random 12 digit integers the ratio of
My Prog Time : Your Prog Time
is .84.
Your programme returns
for input
1.
CKSUM: # 4015d
« DUP
  IF
  THEN DUP 2 MOD
    IF
    THEN 8
    ELSE
      DO 2 IDIV2
      UNTIL
      END 2 * 1 + 24
    END SWAP DUP 1 SAME
    IF
    THEN DROP
    ELSE FACTORS OBJ→ DUP 2. + ROLL 1. ROT 2. /
      START ROT 1 1 1. 6. ROLL
        START SWAP PICK3 * DUP UNROT +
        NEXT UNROT DROP2 *
      NEXT
    END
  ELSE NOT
  END
04-15-2018, 06:54 PM (This post was last modified: 04-15-2018 06:55 PM by Thomas Ritschel.)
(04-15-2018 04:38 PM)Gerald H Wrote:  Your programme returns
for input
1.
Well, by "any natural number" (quoting your initial post) I assumed positive integers (e.g. without a decimal dot).
By putting a R\->I in front of my program, it also works for numbers like 1. or 2.
%%HP: T(3)A(R)F(.);
\<< R\->I DUP
  IF 0 ==
  THEN DROP 1
    IF 0 >
      START PICK3 DUP
        IF 2 ==
      NEXT
    ELSE DROP 1
    END 8 *
  END
04-15-2018, 07:06 PM
Sorry, Thomas, my text was not clear - for input
1
the programme returns
04-15-2018, 07:11 PM
(04-15-2018 07:06 PM)Gerald H Wrote:  Sorry, Thomas, my text was not clear - for input
1
Sorry again, I created this problem by adjusting the programme FACTORS to return
{ 1 1. }
instead of
for input
1
Your programme works correctly.
04-16-2018, 01:19 PM
By dropping the ability to treat algebraic inputs and some minor changes I got my version slightly faster, but it still doesn't reach the speed of your program, Gerald, at the smaller inputs.
%%HP: T(3)A(R)F(.);
  DUP
  IF
  THEN 8 SWAP FACTORS DUP SIZE
    IF
      IF 2 ==
      THEN SWAP DROP 1 SWAP
      END
      1 1. ROT 2. / DUP
      IF
      THEN
        NEXT *
      ELSE DROP2 DROP
      END
    ELSE DROP
    END
  ELSE DROP 1
  END
04-16-2018, 11:31 PM
(04-15-2018 08:36 AM)pier4r Wrote:  Nice observations Valentin and Gerald! (And Thomas of course).
Thanks for your appreciation and kind comment.
Quote:Can someone get 720^20-3 factorized at all (in a calculator context), and only after that factorized quickly? (Same for 720^20-18 and all the others hard variants)
I very much doubt it's doable on any 2018-era calculator (let alone "quickly") as 720^20-3 has two 23-digit prime factors and 720^20-18 has a 22-digit prime factor and a 35-digit one. In similar fashion, 720^20-19 and 720^20+19 are both prime.
Regards.
V.
04-17-2018, 12:10 AM
Regards.
V.
No surprises here just tried factorising 720^20-3 on an HP Prime and it throws a quadratic sieve failure
04-17-2018, 05:03 AM
On a Samsung S4 Android mobile phone
720^20-3
is completely factorized in seconds using
factorint
function in PariDroid
https://play.google.com/store/apps/detai....paridroid
