Requesting ELSEIF
03-24-2017, 05:30 PM
Requesting ELSEIF
If you're taking suggestions for additions to HPPL, I'd like to propose the addition of ELSEIF (or ELIF). With lengthy IF-THEN structures, it can tighten up the code considerably.
Tom L
Current way (greatly trivialized example):
IF x>7 THEN
  PRINT("TOO HIGH");
ELSE
  IF X<4 THEN
    PRINT("TOO LOW");
  ELSE
    PRINT("JUST RIGHT");
  END;
END;
Now improved with ELSEIF
IF x>7 THEN
  PRINT("TOO HIGH");
ELSEIF X<4 THEN
  PRINT("TOO LOW");
ELSE
END;
Tom L
I don't care for whom you voted. If you put ice in your beer, you're crazy.
03-24-2017, 05:38 PM
RE: Requesting ELSEIF
(03-24-2017 05:30 PM)toml_12953 Wrote:
IF x>7 THEN
  PRINT("TOO HIGH");
ELSE
  IF X<4 THEN
    PRINT("TOO LOW");
  ELSE
  END;
END;
IF x>7 THEN
  PRINT("TOO HIGH");
ELSEIF X<4 THEN
  PRINT("TOO LOW");
ELSE
END;
CASE blocks have similar logic to nested ELSE-IF blocks (exiting the block once a condition is met and relevant actions are executed). It doesn't make your code any shorter but can provide improved legibility.
CASE
  IF x>7 THEN PRINT("TOO HIGH"); END;
  IF x<4 THEN PRINT("TOO LOW"); END;
END;
Graph 3D | QPI | SolveSys
03-24-2017, 06:21 PM (This post was last modified: 03-24-2017 07:17 PM by compsystems.)
I like the version ELSEIF. instead of using CASE
now with IFTE functional command version
PHP Code:
EXPORT elif(x)
BEGIN
  IFTE
(x>7,print("TOO HIGH"),IFTE(x<4,print("TOO LOW"),print("JUST RIGHT")));
END
A small survey.
you need an IFT() functional command? (without ELSE block)
PHP Code:
EXPORT ift(x)
BEGIN
  IFTE
(x>7,print("TOO HIGH"),IFT(x<4,print("TOO LOW")));
END
03-24-2017, 06:52 PM
(03-24-2017 06:21 PM)compsystems Wrote:  I like the version ELSEIF. instead of using CASE
A small survey.
I'm all for anything that makes my job easier. I actually make a living converting old programs (mostly BASIC) to run on Prime. I'd share them with the group but my employer owns everything I write relating to their business (even after hours!) I'd like both ELSEIF and IFTE. I'd also like user-defined datatypes (like records), printing and a whole bunch more. We can dream, can't we? Smile
Tom L
Tom L
03-24-2017, 07:16 PM
What kind toml_12953 of programs are you converting and where can you test them?
03-24-2017, 07:33 PM
(03-24-2017 07:16 PM)compsystems Wrote:  What kind toml_12953 of programs are you converting and where can you test them?
I convert environmental programs. These were used for by our field workers for years on laptops and even some BASIC handhelds. We're equipping them with Primes now and I convert programs that monitor and analyze climate data (yes it really IS changing!) and do things like calculate how fast the liquid level in different shaped tanks such as underground tanks used by abandoned gas stations will go up or down based on the input or leakage (a lot of differential equations there). We also keep track of changing migratory patterns of birds and other animals. It's a lot of fun at times but sometimes converting the spaghetti code makes me want to hit the sauce! Smile Gee, C, Pascal and other languages have GOTO. Why can't Prime?
Tom L
Tom L
03-24-2017, 07:45 PM
(03-24-2017 06:21 PM)compsystems Wrote:  you need an IFT() functional command? (without ELSE block)
IFTE can be defined without ELSE
Viga C | TD | FB
03-24-2017, 08:16 PM
but only HOME PRG, for CAS fails
PHP Code:
EXPORT iftHOME(x)
BEGIN
 IFTE
(x>7,print("true"));
 return
"Done";
END;
#cas
iftCAS(x):=
BEGIN
 IFTE
 return
"Done";
END;
#end
iftHOME(8); returns "Done"
iftCAS(8); returns
"when(x>7,print(""true"")) in iftCAS(5) instruction #1 error, try debug(iftCAS(5))
Error: Bad Argument Type"
03-25-2017, 11:43 AM
(03-24-2017 05:38 PM)Han Wrote:  CASE blocks have similar logic to nested ELSE-IF blocks (exiting the block once a condition is met and relevant actions are executed). It doesn't make your code any shorter but can provide improved legibility.
Just to show you, here's the actual ANSI/ISO BASIC statement statement I'm converting:
PHP Code:
IF (1) OR (2) OR (3THEN
circleellipse, or hyperbola
   LET Xo
= -Dr/(2*Ar)
LET Yo = -Er/(2*Cr)
   PRINT
"translation = {"USING$("-%.####",Xo); ", "USING$("-%.####",Yo); "}"
LET r(1) = Ar/(Ar*Xo*Xo Cr*Yo*Yo Fr)
LET r(3) = Cr/(Ar*Xo*Xo Cr*Yo*Yo Fr)
LET r(6) = -1.0
IF ABS(r(1)) < ABS(r(3)) THEN    foci on x-axis
      LET a2
ABS(r(1))
LET b2 ABS(r(3))
      IF
2 THEN                 ellipse
         LET c1
SQRa2 b2 )
         PRINT
"foci = {±"USING$("-%.####",c1); ", 0.0000}"
PRINT "eccentricity ="USING$("-%.#####",c1 SQR(a2))
      ELSEIF
3 THEN            hyperbola
         LET c1
SQRa2 b2 )
         PRINT
END IF
   ELSE                             !
foci on y-axis
      LET a2
ABS(r(3))
LET b2 ABS(r(1))
      IF
2 THEN                 ellipse
         LET c1
SQRa2 b2 )
         PRINT
"foci = {0.0000, ±"USING$("-%.####",c1); "}"
      ELSEIF
3 THEN            hyperbola
         LET c1
SQRa2 b2 )
         PRINT
END IF
END IF
ELSEIF
4 THEN                   parabola
IF ABS(Ar) > ABS(CrTHEN        formx² 4·p·y 0
      LET Xo
Dr/(2*Ar)
LET Yo = (Fr Dr*Dr/(4*Ar))/Er
PRINT "translation = {"USING$("-%.####",Xo); ", "USING$("-%.####",Yo); "}"
LET r(1) = 1
      LET r
(5) = Er Ar
      LET p
= -r(5)/4
PRINT "focus = {0, "USING$("-%.####",p); "}"
ELSE                            ! formy² 4·p·x 0
      LET Xo
= (Fr Er*Er/(4*Cr))/Dr
      LET Yo
Er/(2*Cr)
      PRINT
LET r(3) = 1
      LET r
(4) = Dr Cr
      LET p
= -r(4)/4
PRINT "focus = {"USING$("-%.####",p); ", 0}"
END IF
END IF
Tom L
