WP-34s Emulator v3.2
01-02-2014, 11:59 AM
Hi there. I used the Emulator for the first time today. Win 7 32bit. Version 3.2
I have used RPN Calcs before. Most basic input 3 ENTER; 2 ENTER; + The problem is that it sets Regsiters X and Y to the Number I entered before the ENTER, meaning that I get 4 as a result of the example above. looking like that, before I hit + x: 2 y: 2 z: 3 help appreciated, I am sure there is a setting for that, right? Regards |
01-02-2014, 12:10 PM
RE: WP-34s Emulator v3.2
3 ENTER 2 +
The second ENTER is causing your problem. - Pauli |
01-02-2014, 12:14 PM
So my RPN skills were a bit confused. Thanks!!!
01-02-2014, 06:10 PM
(01-02-2014 11:59 AM)Bernhard Wrote: I have used RPN Calcs before. Most basic input 3 ENTER; 2 ENTER; + Well, maybe you were used to RPL calcs... ![]() Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
01-02-2014, 09:45 PM
(This post was last modified: 01-02-2014 09:46 PM by Thomas Klemm.)
(01-02-2014 06:10 PM)Massimo Gnerucci Wrote:(01-02-2014 11:59 AM)Bernhard Wrote: I have used RPN Calcs before. Most basic input 3 ENTER; 2 ENTER; +Well, maybe you were used to RPL calcs... (12-18-2013 09:32 PM)eri Wrote: I'm finding it tough to break the habit of hitting enter after each entry.I'd never use that 2nd ENTER. It's like adding parentheses where they can be omitted. Never had a problem with that on the HP-48 but I was used to the HP-41. So maybe the transition into this direction is easier? What I don't understand is the use of RPN vs. RPL. Both HP-41 and HP-48 use RPN. It's a notation. Thus both are RPN calculators. RPL is a language. You can compare that to FOCAL if you want. Cheers Thomas |
01-02-2014, 11:54 PM
(This post was last modified: 01-02-2014 11:56 PM by Massimo Gnerucci.)
(01-02-2014 09:45 PM)Thomas Klemm Wrote: I'd never use that 2nd ENTER. It's like adding parentheses where they can be omitted. Neither would I (01-02-2014 09:45 PM)Thomas Klemm Wrote: Never had a problem with that on the HP-48 but I was used to the HP-41. So maybe the transition into this direction is easier? On a 28/48/49/50 you can input 3 ENTER 2 ENTER + and have 5 for an answer. Unlike on RPN machines where you have no input line and work on register X directly and the second ENTER copies X in Y. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
01-03-2014, 06:03 AM
Nope, the second ENTER is optional on RPL machines. RPL isn't as bad as you make out
![]() Pauli |
01-03-2014, 12:06 PM
(This post was last modified: 01-03-2014 06:34 PM by Marcus von Cube.)
I'm speaking of RPN and RPL both as languages here...
![]() In an RPL program, ENTER does not appear as a command as in classic RPN. If you press ENTER on an empty entry line, you'll get DUP. It's just a shortcut. If you put in 1 ENTER 2 ENTER + on an RPL machine the code executed is 1 2 +. ENTER just terminates the digit entry. The same input on the 34S (or a 35) yields 1 ENTER^ 2 +. ENTER^ is in fact the same as the DUP command in RPL. The equivalent of separating the two numbers 1 and 2 by a space in RPL is ENTER^ in RPN. In RPN, 10 ENTER^ * yields 100 (10^2). This makes some functions, such as x^2, expendable as keyboard functions for most manual calculations on the classic machines. To achieve the same in RPL, 10 DUP * is the correct way to go. This can be entered as 10 ENTER ENTER + in direct mode. In a program, you'll need the explicit stack manipulation command DUP. Marcus von Cube Wehrheim, Germany http://www.mvcsys.de http://wp34s.sf.net http://mvcsys.de/doc/basic-compare.html |
01-03-2014, 02:09 PM
(01-03-2014 12:06 PM)Marcus von Cube Wrote: In RPN, 10 ENTER^ * yields 100 (10^2). This makes some functions, such as x^2, expendable as keyboard functions for most manual calculations on the classic machines. To achieve the same in RPL, 10 DUP + is the correct way to go. This can be entered as 10 ENTER ENTER + in direct mode. In a program, you'll need the explicit stack manipulation command DUP.Why +? Typo? The equivalent of DUP in a FOCAL program is RCL X. But that takes 2 bytes and isn't available on all machines. So you use ENTER and hope the next command enables the stack lift. Otherwise a RCL 00 following directly the ENTER will just overwrite X instead of inserting the value. In this situation I often used some command like CLA that was needed somewhere else but didn't make much sense at that specific line: ENTER CLA RCL 00 This little hack makes it difficult to understand and maintain the code later. I often would have preferred to just use: DUP RCL 00 A similar thing is with CLX. In a program you generally don't want to disable the stack lift. I see that as the biggest drawbacks of ENTER in FOCAL programs. Cheers Thomas |
01-03-2014, 06:02 PM
(This post was last modified: 01-03-2014 07:39 PM by Massimo Gnerucci.)
(01-03-2014 02:09 PM)Thomas Klemm Wrote: The equivalent of DUP in a FOCAL program is RCL X. But that takes 2 bytes and isn't available on all machines. Sorry? FOCAL (as long as HP calculators are concerned) stands for Forty-One CAlculator Language. We can count in the 42s as well... How's that RCL X isn't available on all (41C-CV-CX,42) machines? Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
01-03-2014, 06:38 PM
(01-03-2014 02:09 PM)Thomas Klemm Wrote: Why +? Typo?Typo! Corrected. RCL X isn't exacly the same as ENTER^ because RPN has the concept of stack lift enable/disable which is alien to RPL. ENTER^ leaves stack lift disabled which makes it work as DUP in all cases except when followed by a number. RPN is not always easier then RPL. Marcus von Cube Wehrheim, Germany http://www.mvcsys.de http://wp34s.sf.net http://mvcsys.de/doc/basic-compare.html |
01-04-2014, 12:04 AM
(This post was last modified: 01-04-2014 05:57 AM by Thomas Klemm.)
RE: WP-34s Emulator v3.2 | |||
01-04-2014, 12:05 AM
01-04-2014, 12:27 AM
(01-03-2014 06:02 PM)Massimo Gnerucci Wrote: How's that RCL X isn't available on all (41C-CV-CX,42) machines?I consider the operations available in the HP-11C or HP-15C a subset of FOCAL. That isn't correct in all cases. The HP-41 doesn't provide RCL-arithmetic while the HP-15C or the HP-42S does. Nevertheless most of the programs can be translated without much effort from one model to another. Exceptions are RCL/STO stack-operations wich are missing in the voyagers. The best I come up with for an equivalent of DUP that works on all models is: ENTER X<>Y Cheers Thomas |
01-04-2014, 01:20 AM
(01-04-2014 12:05 AM)Didier Lachieze Wrote:(01-03-2014 06:02 PM)Massimo Gnerucci Wrote: How's that RCL X isn't available on all (41C-CV-CX,42) machines? Didier, I know it is, that was the point... Just a rhetorical question. ![]() Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
01-04-2014, 01:22 AM
(01-04-2014 12:27 AM)Thomas Klemm Wrote:(01-03-2014 06:02 PM)Massimo Gnerucci Wrote: How's that RCL X isn't available on all (41C-CV-CX,42) machines?I consider the operations available in the HP-11C or HP-15C a subset of FOCAL. That isn't correct in all cases. Ok but, in my opinion, FOCAL should be confined to the 41 (and 42) series. Ciao Thomas! Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
01-04-2014, 07:53 PM
(This post was last modified: 01-04-2014 07:54 PM by Marcus von Cube.)
(01-04-2014 12:04 AM)Thomas Klemm Wrote:Are you sure? RCL (and LastX) should leave stack lift enabled, not disabled. That's exactly the difference between RCL X and ENTER^.(01-03-2014 06:38 PM)Marcus von Cube Wrote: ENTER^ leaves stack lift disabled which makes it work as DUP in all cases except when followed by a number.The same happens with RCL nn and LASTX. Marcus von Cube Wehrheim, Germany http://www.mvcsys.de http://wp34s.sf.net http://mvcsys.de/doc/basic-compare.html |
01-04-2014, 10:04 PM
(01-04-2014 07:53 PM)Marcus von Cube Wrote:Sorry, I meant that the same happens when ENTER is followed by RCL nn or LASTX.(01-04-2014 12:04 AM)Thomas Klemm Wrote: The same happens with RCL nn and LASTX.Are you sure? RCL (and LastX) should leave stack lift enabled, not disabled. That's exactly the difference between RCL X and ENTER^. So you can add these two to the list of exceptions. |
