example python ppl with subroutines hp prime
06-08-2021, 01:53 AM (This post was last modified: 06-08-2021 02:42 AM by Liamtoh Resu.)
The following demonstrate the useage of subroutines in python and ppl.
A simple pi approximation was used.
edit: fixed ppl code, was missing predeclaration for cls().
python:
#PYTHON name
# aprxpi02
import math
def pintro():
  print ("aprxpi02 pi approximation")
  return
def api():
  return 355/113
def pout():
  q1 = api()
  print ("pi = ", q1)
pintro()
pout()
#end
EXPORT aprxpi02()
BEGIN
  PRINT;
  PYTHON(name);
END;
ppl
// aprxpi01
// predeclare subroutines
cls();
pintro();
api();
pout();
// main program
EXPORT aprxpi01()
BEGIN
cls();
pintro();
pout();
end;
// clear screen
cls()
begin
print();
end;
// print intro
pintro()
begin
print("aprxpi01: pi approximation");
end;
// pi approximation
api()
begin
return 355/113;
end;
// print output
local q1;
pout()
begin
q1 := api();
print("pi = " + q1);
end;
// end of source code
This is for those who are looking for a starting point.
Thanks/
06-08-2021, 05:28 AM (This post was last modified: 06-08-2021 05:54 AM by toml_12953.)
RE: example python ppl with subroutines hp prime
(06-08-2021 01:53 AM)Liamtoh Resu Wrote:  edit: fixed ppl code, was missing predeclaration for cls().
You don't need to pre-declare functions anymore. The below still works.
// aprxpi01
// main program
EXPORT aprxpi01()
BEGIN
cls();
pintro();
pout();
end;
// clear screen
cls()
begin
print();
end;
// print intro
pintro()
begin
end;
// pi approximation
api()
begin
return 355/113;
end;
// print output
local q1;
pout()
begin
q1 := api();
end;
Tom L
Cui bono?
06-08-2021, 05:58 AM (This post was last modified: 06-08-2021 06:03 AM by Liamtoh Resu.)
Ok Tom,
Thanks for the quick late night response about the pre-declaration entries.
The omission of the predeclarations did not seem to work on the emulator
--will check it out on the real hp prime.
06-08-2021, 12:34 PM
(06-08-2021 05:58 AM)Liamtoh Resu Wrote:  Ok Tom,
Are you sure you have the latest beta emulator? It works on mine without the pre-declarations.
Tom L
Cui bono?
06-08-2021, 03:45 PM (This post was last modified: 06-08-2021 04:22 PM by Liamtoh Resu.)
I had problems trying to get the 20210428 emulator to run so I reverted back to the
2020 emulator.
The 20210428 CK is running fine.
I have the 20210505 firmware on the real hp prime.
I have not sent the updated version to the prime yet.
PPL and python are relatively new to me -- I am thinking about
backward compatibility.
Thanks.
edit: The program without the pre-declarations worked ok on the real hp prime.
