Benchmarks 71B versus 48GX
06-17-2020, 08:44 PM
RE: Benchmarks 71B versus 48GX
(06-17-2020 12:36 PM)J-F Garnier Wrote: If it's really a 1LK7 then it's the same than used in the 28C and it supports the PC=(A) opcode. It may be a way to detect the CPU version by software. I may try. Ok, I had to do it... Here is the CPUV function that returns 1 if the CPU executes PC=(A), otherwise 0. I got 0 on my oldest HP71s, but 1 on my 2842Axxx machine. Note that both Emu71/Win and Emu71/DOS return 1 since they support the new opcodes. Forth/assembler needed to enter and assemble the CPUV keyword. Code: LEX 'CPUVER' J-F |
06-17-2020, 10:23 PM
I struggled for a moment getting this to work, forgetting to power-off/on to add the new LEX file into the chain. It's been too long... ahem...
I also thought it may be interesting to include the result in the VER$ poll, "CPU: 0" or "CPU: 1"... Homework for later... into the large, but still growing, list of things to try. Thanks J-F ! I knew you would have to do this ![]() --Bob Prosperi |
06-18-2020, 06:09 AM
This is so cool, thanks J-F
(06-17-2020 08:44 PM)J-F Garnier Wrote: Forth/assembler needed to enter and assemble the CPUV keyword. |
06-18-2020, 07:08 AM
06-18-2020, 08:00 PM
(This post was last modified: 06-19-2020 11:40 AM by Christoph Giesselink.)
(06-17-2020 08:44 PM)J-F Garnier Wrote:(06-17-2020 12:36 PM)J-F Garnier Wrote: If it's really a 1LK7 then it's the same than used in the 28C and it supports the PC=(A) opcode. It may be a way to detect the CPU version by software. I may try. When you don't like to fiddle around with the Forth/Assembler module like me, I added the original sources, sources which can be compiled with the HPTOOLs package and a compiled L71 file for importing with the DOSLINK interface. |
06-19-2020, 08:05 AM
(06-18-2020 08:00 PM)Christoph Giesselink Wrote: ... I added the original sources, sources which can be compiled with the HPTOOLs package and a compiled DAT file for importing with the DOSLINK interface. Thanks, Christoph. It may be better to name the assembled file CPUVER.L71 to reflect its true nature. To load it in the HP-71B, you will need the PIL-Box and ILPer. Make the DOSLINK "in file" point to the assembled CPUVER file and do "COPY :DOSLINK". Now, we can build stats on the presence of the 1LK7 in the latest HP-71B? J-F |
06-19-2020, 03:40 PM
(06-17-2020 08:44 PM)J-F Garnier Wrote: Forth/assembler needed to enter and assemble the CPUV keyword. Not really. Would you please post the hex dump so that we may create the LEX file just by entering the hex codes using MAKELEX ? This will take less time than using the Assembler, the compiled LEX file is quite short. Thanks and have a nice finde. V. All My Articles & other Materials here: Valentin Albillo's HP Collection |
06-19-2020, 04:40 PM
Maybe this should be turned into an article, it's valuable information for the 71B fans.
I can try to do this next time it rains.... I have gone through all my 71's (Thanks a lot J-F!!). My stats tells me that the earliest I have with 1LK7 CPU is 2630A and according to legend, they started with 2623A. All are 2CCCC or newer All of them are Plastic Backs, none of my Metal Backs are 1LK7 - the latest I have is 2552A - 1BBBB. Hope this is helpful. /KimH (06-19-2020 08:05 AM)J-F Garnier Wrote:(06-18-2020 08:00 PM)Christoph Giesselink Wrote: ... I added the original sources, sources which can be compiled with the HPTOOLs package and a compiled DAT file for importing with the DOSLINK interface. |
06-19-2020, 05:08 PM
(06-19-2020 03:40 PM)Valentin Albillo Wrote: Would you please post the hex dump so that we may create the LEX file just by entering the hex codes using MAKELEX ? It's decades since I used MAKELEX. I vaguely remember that the LEX is entered as strings of hex characters with a checksum for each entered line. Can someone can point to the right tool to generate the hex strings and checksum? In the meantime, here is the assembly listing, if this can help. Code: 0001 00000 LEX 'CPUVER' |
06-19-2020, 06:02 PM
RE: Benchmarks 71B versus 48GX | |||
06-19-2020, 06:20 PM
06-19-2020, 06:42 PM
Here is the BASIC listing for both DUMPLEX and MAKELEX from the Old HP Forum Archives
06-19-2020, 06:50 PM
(06-19-2020 06:20 PM)J-F Garnier Wrote:(06-19-2020 06:02 PM)Dave Frederickson Wrote: HP-71 BASIC Made Easy, p133. Sorry, I didn't read it all. DUMPLEX is on SWAP\CHHU01. Code: CPUVER ID#5C 54 bytes |
06-20-2020, 07:51 AM
Thanks Dave for the hex dump.
Now, one question remains : what does the 1LF2 do when it executes the 808C PC=(A) opcode? Is it a nop or something else? The 808C opcode is part of the 808x group, in the 1LF2 only the 8080 INTON and 808F INTOFF are defined. So it depends on how the opcode decoding is done in the 1LF2, but I would expect the 808C opcode to be executed as INTOFF. It may be possible to prove it, but probably not worth the effort. J-F |
06-21-2020, 04:45 PM
(This post was last modified: 06-23-2020 06:23 PM by Jonathan Busby.)
(05-04-2014 10:56 PM)Christoph Giesselink Wrote:(05-03-2014 01:57 AM)Mark Hardman Wrote: HP-28C If the value present at =CSPEED is generated in a similar fashion to how the value for the entry of the same name on the HP48 is generated, then some corrections are in order. First, on the HP48 series, =CSPEED is generated using the =clkspd routine ( which of course attempts to measure the CPU clock speed ) which is not very accurate, even if display refresh and keyboard scanning are turned off. Secondly, the HP48 series calculators' 32768Hz crystal oscillator seems to vary frequently and the LC circuit that's part of the PLL ( and which uses the crystal oscillator as a reference ) that generates the HFO ( High Frequency Oscillator, which on the HP48G/G+/GX is around ~7.34MHz to ~7.86MHz ) is also subject to frequent variation. So, although the nominal clock speed of the HP-28C may be 640kHz, it may possibly be higher or lower by a non-negligible amount probably due to similar variations in frequency that cause the HP48 series calculators' clock speed to vary, although I believe the variation to be small and on the order of ±20kHz ( ie. it's not so variable that the clock speed would be off by ~360kHz ![]() ![]() In summary, I think that the value stored at "=CSPEED" is not the most reliable indicator of the true clock speed, although I may be wrong though if the HP-28C hardware and its equivalent to the HP48 series "=clkspd" routine differ in some certain crucial aspects ![]() Quote:(05-03-2014 01:57 AM)Mark Hardman Wrote: HP-48GX Well, this is not quite 100% accurate. On the HP48 series, taking the HP48G/G+/GX as an example, the clock speed is derived from the aforementioned HFO divided by 2. AFAIK, the nominal clock speed is around either ~3.93MHz or ~3.67MHz, but, due to reasons I've already mentioned, can vary to a non-negligible degree. I have several HP48GXs that have ~3.9MHz+ clock speeds, and, it seems to me that the "nominal" clock speed is around a little below ~4MHz for these. Also, these calculators are *not* "very early" models ![]() ![]() Regards, Jonathan ( NOTE : Edited this post to fix typos : "Hz" -> "kHz") Aeternitas modo est. Longa non est, paene nil. |
06-21-2020, 09:55 PM
Please note that I was quoting specifications from Craig Finseth's HPDATAbase. If there are any corrections, please let Craig know.
(05-03-2014 01:57 AM)Mark Hardman Wrote:(05-02-2014 09:23 PM)John W Kercheval Wrote: Does anyone have a raw chip speed comparison between the 71B and the 48GX? Ceci n'est pas une signature. |
06-22-2020, 04:48 AM
(This post was last modified: 06-22-2020 04:50 AM by RMollov.)
(06-21-2020 04:45 PM)Jonathan Busby Wrote: Well, this is not quite 100% accurate. On the HP48 series, taking the HP48G/G+/GX as an example, the clock speed is derived from the aforementioned HFO divided by 2. AFAIK, the nominal clock speed is around either ~3.93MHz or ~3.67MHz, but, due to reasons I've already mentioned, can vary to a non-negligible degree. I have several HP48GXs that have ~3.9MHz+ clock speeds, and, it seems to me that the "nominal" clock speed is around a little below ~4MHz for these. Also, these calculators are *not* "very early" models I can confirm that, my HP-48GX is from the latest ones, SN ID30700327 and always reports abt 3.933MHz Cheers, |
06-28-2020, 02:11 AM
To my knowledge, there was a second instruction added to the 1LK7, namely RSI (Reset Interrupt System) with an opcode of 80810.
Maybe Jean-François Garnier could enlighten us as to how a late-production HP-71B equipped with the 1LK7 would react to the issuance of that instruction, and how, on the other hand, the 1LF2 in a standard HP-71B would internally decode the corresponding opcode? |
06-28-2020, 07:35 AM
(06-28-2020 02:11 AM)Giuseppe Donnini Wrote: To my knowledge, there was a second instruction added to the 1LK7, namely RSI (Reset Interrupt System) with an opcode of 80810. It's has always been a mystery for me why the RSI is opcode 80810 and not just 8081. Maybe this additional fetched nibble gave more time for the RSI execution? I would be glad to get the opinion of people more expert than me in the Saturn chipsets. Due to this trailing 0, an attempt to execute RSI on a 1LF2 will probably put the CPU out of sync with the next opcodes. As for the effect of RSI on a HP-71 with 1LK7, I don't know. Actually I'm not sure of the exact effect of RSI on the 28C. The SASM doc says: "This instruction causes CPU to consider any input line (ie input register bits) presently high as a new interrupt. If the CPU is presently in the interrupt routine it will wait for an RTI before vectoring, otherwise the CPU will vector immediately following the RSI instruction. For a complete discussion on the interrupt system see the CPU Hardware Specification (A-1LK7-9005-1). This instruction is not available on the 1LF2 version of the Saturn CPU." This description is not fully clear for me, and unfortunately, I don't have access to the 1LK7 CPU Hardware Specification. J-F |
07-29-2020, 08:40 PM
(This post was last modified: 07-29-2020 10:26 PM by Jonathan Busby.)
(06-28-2020 07:35 AM)J-F Garnier Wrote:(06-28-2020 02:11 AM)Giuseppe Donnini Wrote: To my knowledge, there was a second instruction added to the 1LK7, namely RSI (Reset Interrupt System) with an opcode of 80810. Well, it seems you have found one of the many Saturn "opcode holes" ![]() Anyway, I don't know about the HP-71B 1LF2 or 1LK7 CPUs, but on the Yorke Saturn it seems that invalid opcodes are just ignored. For example, the following code contains the invalid opcode 0x80811 . I̵f̵ ̵I̵ ̵a̵p̵p̵e̵n̵d̵ ̵a̵ ̵0̵x̵0̵4̵ ̵t̵o̵ ̵t̵h̵e̵ ̵o̵p̵c̵o̵d̵e̵ ̵t̵h̵e̵n̵ ̵t̵h̵e̵ ̵R̵4̵=̵A̵ ̵i̵n̵s̵t̵r̵u̵c̵t̵i̵o̵n̵ ̵i̵s̵ ̵e̵x̵e̵c̵u̵t̵e̵d̵ -- EDIT : Actually, I made an oopsie ![]() Code: ASSEMBLE I've attached an HP48G-R compatible compiled binary of the above code to this message. ( NOTE : The on-calc checksum is # F393h ) Regards, Jonathan Aeternitas modo est. Longa non est, paene nil. |
