Exact Fractions in Matrices
02-01-2019, 02:39 PM
Can matrices only display decimal approximations on the HP Prime?
Say I have the matrix [ [ 0.5, 0.6 ], [ 0.7, 0.8 ] ] and I want to display the matrix in the program as [ [ 1/2, 3/5 ], [ 7/10, 4/5 ] ]. A friend asked me how can we do this? QPI turns matrices into lists when converting to exact values. The command exact is ignored in Home Mode. I had no success with propfrac or partfrac. Is there a command that works like the [ a b/c ] key? Any help will be appreciated. Thank you. |
02-01-2019, 04:47 PM
(This post was last modified: 02-01-2019 04:58 PM by grsbanks.)
RE: Exact Fractions in Matrices | |||
02-01-2019, 06:20 PM
It works in CAS with no probs.
02-02-2019, 04:19 AM
This is awkward but it works in Home:
CAS("string(exact(M1))") <0|ɸ|0> -Joe- |
02-02-2019, 04:21 PM
Hi!, Eddie :
Try by creating any algorithm with p/q Form, as ... |
02-02-2019, 11:21 PM
02-03-2019, 11:37 PM
(02-02-2019 11:21 PM)Eddie W. Shore Wrote: I'm surprised that QPI does not make all the entries of a matrices in exact fraction form. It does, but it also converts the matrix into a list of lists, because Home does not support symbolic matrices, only matrices of reals. So if you want a symbolic matrix, you'll either have to do it in CAS (or a CAS program), or convert the symbolic matrix into a form that Home can tolerate, such as a list of lists or a string. I personally like the QPI solution, even though its accuracy cannot be tuned as finely as the 'exact' function can. Disclaimer: I *think* the above is correct, but I've almost entirely given up trying to learn how to use the HP Prime. Attempting to wrap one's brain around a constantly-moving target which is also a shape-shifter surrounded by an intermittent cloaking device is painful. <0|ɸ|0> -Joe- |
02-04-2019, 02:20 AM
(02-03-2019 11:37 PM)Joe Horn Wrote: Disclaimer: I *think* the above is correct, but I've almost entirely given up trying to learn how to use the HP Prime. Attempting to wrap one's brain around a constantly-moving target which is also a shape-shifter surrounded by an intermittent cloaking device is painful. Yikes! But there is good news here, as this is almost certainly the first time I discovered something about an HP machine before Joe did... --Bob Prosperi |
02-04-2019, 02:04 PM
I would love to have a program command that works like the [a b/c] key.
02-04-2019, 02:40 PM
Is it my imagination or is QPI() not documented anywhere (other than in the Toolbox Catlg)? I can't find it in the User Guide.
Cambridge, UK 41CL 12/15C DM15/16 71B 17B/BII/bII+ 28S 42S/DM42 48GX 50g 35s 30b/WP34S Prime G2 & Casios, Rockwell 18R :) |
02-05-2019, 02:13 AM
(02-04-2019 02:40 PM)cdmackay Wrote: Is it my imagination or is QPI() not documented anywhere (other than in the Toolbox Catlg)? I can't find it in the User Guide. Correct. Like many other recently-added functions (including my favorites, dfc and dfc2f), QPI has not yet been added to the User Guide. <0|ɸ|0> -Joe- |
02-05-2019, 03:26 PM
(02-05-2019 02:13 AM)Joe Horn Wrote:(02-04-2019 02:40 PM)cdmackay Wrote: Is it my imagination or is QPI() not documented anywhere (other than in the Toolbox Catlg)? I can't find it in the User Guide. <scrambles to look those up…> thanks Joe. Some time ago someone posted a nice HTML version of the help file, which I downloaded. Sadly I can't remember whence it came, but it's the only doc I have that mentions QPI, and it's a lot easier to search than the one on the calc, even with the emulator. Cambridge, UK 41CL 12/15C DM15/16 71B 17B/BII/bII+ 28S 42S/DM42 48GX 50g 35s 30b/WP34S Prime G2 & Casios, Rockwell 18R :) |
02-06-2019, 05:35 AM
(02-05-2019 03:26 PM)cdmackay Wrote: Some time ago someone posted a nice HTML version of the help file, which I downloaded. Sadly I can't remember whence it came... Did you mean this thread? Geocaching Coords Solver, Number of triangles Puzzle |
02-06-2019, 02:39 PM
(This post was last modified: 02-06-2019 02:40 PM by cdmackay.)
(02-06-2019 05:35 AM)chromos Wrote:(02-05-2019 03:26 PM)cdmackay Wrote: Some time ago someone posted a nice HTML version of the help file, which I downloaded. Sadly I can't remember whence it came... oh! It was TimW, how embarrassing for me to forget. Yes, that was it, thanks very much indeed. edit: and your version too, thanks! ![]() Cambridge, UK 41CL 12/15C DM15/16 71B 17B/BII/bII+ 28S 42S/DM42 48GX 50g 35s 30b/WP34S Prime G2 & Casios, Rockwell 18R :) |
