07-17-2023, 06:18 PM
07-18-2023, 10:15 AM
I have many problems with this update!
08-06-2023, 01:35 PM
AFilesB crashes for reading more than 10000 bytes if the file is large enough. This causes a reboot instead of displaying "Insufficient memory" or something similar (tested on G1).
For example:
AFilesB("bigfile",0,10001);
For example:
09-15-2023, 12:28 PM
Hi Klaas,
It's been a while now and was just wondering if you have an ETA for the Mac update?
Even a rough ETA (eg this year or 1st half next year).
TIA, dmh
TIA, dmh
(04-24-2023 07:02 AM)KlaasKuperus Wrote: [ -> ]Hi all,
The new Connectivity Kit and automatic update of Prime G2 have been released and posted on https://hpcalcs.com/download/. This update is now for Windows only + the Virtual Calculator, we're getting the MAC version ready as we speak, as well as the IOS and Android.
09-24-2023, 10:10 AM
(05-01-2023 11:18 AM)KlaasKuperus Wrote: [ -> ](04-30-2023 01:12 PM)Dirk.nl Wrote: [ -> ]Klaas,
Thank you very much for this update.
The Prime software is in good hands with Moravia!
This is very reassuring for us as users. Hopefully your focus is on solving any errors in a timely manner.
Thanks again!
Greetings.
Thanks for the nice words! We're now focusing on the next steps and target towards a new update during the summer. We'll keep Prime alive for sure!
If you encounter any issues, best is to email me at klaas.kuperus@moravia-consulting.com. Please make sure to mention your serial code, revision number and date of purchase and a detailed description of the problem you're having. I will make sure you get a timely response and help you to fix it.
Thanks for keeping the suggestions coming as well, we read them all.
I know that anticipated dates can slip, and "summer" was just a target...
But as my calendar tells me summer is now over, I wonder when we can now look forward to an update (or did I miss an announcement?)
(I'm interested in the Android app in addition to the actual calculator - Hoping an update is still planned)
09-24-2023, 09:08 PM
(08-06-2023 01:35 PM)komame Wrote: [ -> ]AFilesB crashes for reading more than 10000 bytes if the file is large enough. This causes a reboot instead of displaying "Insufficient memory" or something similar (tested on G1).
For example:
Piotr, thanks for posting — and for filing a bug report on the bug tracking site I’ve set up. The bug got fixed!
09-25-2023, 01:56 PM
(09-24-2023 09:08 PM)jte Wrote: [ -> ](08-06-2023 01:35 PM)komame Wrote: [ -> ]AFilesB crashes for reading more than 10000 bytes if the file is large enough. This causes a reboot instead of displaying "Insufficient memory" or something similar (tested on G1).
For example:
Thanks! So it's time to fill up the bug tracker with new bugs!
P.
10-31-2023, 02:12 AM
(05-14-2023 12:52 PM)Pavel OK1DNZ Wrote: [ -> ]CK and HP Prime G1 calculator (HW version A, CAS v. 1.5.0 & OS v. V0.050.640) updated to the latest version 22.1.14730 (023 04 13). The CK sees G1 calculator connected via USB cable. When I click on calculator name in CK to display all calc. items, the calculator reboots immediately. The same response on W10 and W11; Firewall disabled. No such issue with updated PC HP Prime or Android HP Prime Pro (2.1.14594 (2021 05 14)). Hope next SW release fix this issue (connectivity to HP Prime G1, HW v. A under W10 & W11) soon. Thank you.
Pavel
I get this same behaviour (same calculator, same versions), physical calculator reboots when I open it in CK. I reset my calculator completely and it works fine in CK (I can open it). Then (in CK) I simply copied the spreadsheet and added a few very simple formulas into the new sheet, saved it to write it to the calculator, and backed up the calculator. After disconnecting & reconnecting, this reboot behaviour started happening and also the backup option is missing from the right-click menu.
I reset the calculator again, and this time copied and populated the (copied) spreadsheet on the physical calculator, and I can now disconnect/reconnect and open my calculator within CK. Now though I'm unable to connect the app to CK where it was connecting before, and the app can still see the server name for CK.
I don't know how reproduceable all this is, I think last time I got the app to connect after I uninstalled/reinstalled CK and updated it. That did *not* fix the calc rebooting when you open it in CK though.
It's the first time in a while that I picked up the calculator, started from a blank slate and had all these issues in minutes, I don't think the dev team would have to take much time to try to reproduce...
01-10-2024, 05:43 PM
I've noticed recurring problems that arise when I first start CK, then VC, and only after that do I connect G1 via USB cable. In such a scenario, it happens that G1 is detected after a very long time, even 20-30 seconds (but it eventually appears). After launching CK, if I connect G1 first (without starting VC), it appears without any delays. I've never observed these delays when connecting G2.
As for the missing "Backup" option in the context menu, you need to expand the item in the tree for the given device, and then after a moment the "Backup" option appears.
Piotr
(10-31-2023 02:12 AM)ebswift Wrote: [ -> ][...] and also the backup option is missing from the right-click menu. [...]
Piotr
01-11-2024, 05:59 AM
Bonjour
Encore une fausse joie, à chaque fois que ce post ressurgit, pendant un court instant je crois à une nouvelle mise à jour
Hello
Another false joy, every time this post resurfaces, for a brief moment I think it's a new update
Hello
01-11-2024, 03:29 PM
Same!
01-11-2024, 09:04 PM
Who should produce an update? The current licensee?
uuh, what timeline?
I want these drugs too.
uuh, what timeline?
01-12-2024, 08:12 AM
(04-24-2023 07:02 AM)KlaasKuperus Wrote: [ -> ]This update is now for Windows only + the Virtual Calculator, we're getting the MAC version ready as we speak
Any news on the Mac version?
01-12-2024, 12:55 PM
(01-11-2024 05:59 AM)Tyann Wrote: [ -> ]Bonjour
Hello
A new version announcement would be at the start of a new thread with the version number in it. Any additions to this thread are just old comments (like this one!)
