05-10-2023, 01:53 PM
05-10-2023, 04:56 PM
I just noticed that in the home view, if the textbook input method is selected, there are two new soft buttons Save and Load, I read about them in the help of the calculator. Question - are these functions possible in the RPN entry variant?
05-10-2023, 05:07 PM
(05-10-2023 01:53 PM)Arno K Wrote: [ -> ]Vou may get the Connectivity Kit from https://www.hpcalc.org/details/8938 and install it, then connect your calculator.
Arno
What about the stability on that model? I have read about boot loops and several errors.. like the loss of the touchscreen
05-10-2023, 07:12 PM
(05-10-2023 05:07 PM)CT82716 Wrote: [ -> ]I haven't noticed. I updated G2 calculator on Windows 10 PC without any problems. I had a problem with the G1 calculator, it does not work with CK on W10 PC, it works on W11 PC.(05-10-2023 01:53 PM)Arno K Wrote: [ -> ]Vou may get the Connectivity Kit from https://www.hpcalc.org/details/8938 and install it, then connect your calculator.
Arno
05-10-2023, 07:15 PM
(05-10-2023 07:12 PM)Voldemar Wrote: [ -> ](05-10-2023 05:07 PM)CT82716 Wrote: [ -> ]What about the stability on that model? I have read about boot loops and several errors.. like the loss of the touchscreenI haven't noticed. I updated G2 calculator on Windows 10 PC without any problems. I had a problem with the G1 calculator, it does not work with CK on W10 PC, it works on W11 PC.
Okay, when the calculator arrives I will try to see instructions to update it via the .img file.
05-10-2023, 07:53 PM
(05-10-2023 12:24 PM)CT82716 Wrote: [ -> ]Hi all,
I recently bought a HP Prime G2 Rev D calculator. Is this update stable for my calculator? if so where can i download it?
i'm new to this world and i don't know how to possibly update my calculator. I can recover a machine with windows 10 if needed.
Thank you so much, I hope someone is kind enough to help me.
Yes, it is reported safe and a good improvement for G2 machines.
To update the firmware:
1. Got to the link in the top post in this thread
2. Download and install the ConnKit for your PC type (Win-10/11 or Mac)
3. Connect your Prime
4. The CK should offer to download and install the latest f/w, let it do so. As part of the process, it will offer to backup your Prime - if you have stuff you don't want to risk losing, do the backup.
You should be all set. Please report your results once you've had a chance to try it.
05-10-2023, 07:57 PM
(05-10-2023 07:53 PM)rprosperi Wrote: [ -> ]Yes, it is reported safe and a good improved for G2 machines.
Thank you very much, absolutely I will share the result of my operations.
Let's hope for the best!!
05-11-2023, 06:45 PM
(05-10-2023 04:56 PM)Voldemar Wrote: [ -> ]I just noticed that in the home view, if the textbook input method is selected, there are two new soft buttons Save and Load, I read about them in the help of the calculator. Question - are these functions possible in the RPN entry variant?
The Save and Load do not appear to be available in RPN mode. You can accomplish something similar by Shift-Up Arrow, then tap the Stack menu and select ->List. This will create a list which you can then save like another other object. The tricky part is restoring the list to the stack. Someone recently posted such a solution. See https://www.hpmuseum.org/forum/thread-19...#pid169782
Just a word of warning on the Textbook/Algebraic Save and Load options. It's a great idea, but I have found these options to be unstable, even with the recent firmware. They don't always work correctly and frequently cause reboots. Use with caution.
05-11-2023, 07:31 PM
(05-11-2023 06:45 PM)Wes Loewer Wrote: [ -> ](05-10-2023 04:56 PM)Voldemar Wrote: [ -> ]I just noticed that in the home view, if the textbook input method is selected, there are two new soft buttons Save and Load, I read about them in the help of the calculator. Question - are these functions possible in the RPN entry variant?
I'd add that RPN mode on the Prime is severly crippled, so it's best avoided.
But in reality, it's algebraic toolset works so well, you soon learn to live without RPN on the Prime. I couln't live without RPN on my 50g but with the Prime I rarely consider it's MIA satus.
05-11-2023, 09:53 PM
(05-11-2023 07:31 PM)jonmoore Wrote: [ -> ]I'd add that RPN mode on the Prime is severly crippled, so it's best avoided.I will not say so. It's good to have RPN mode on Prime.
True, you should not use Prime as the RPN only calculator, it is not intended for that.
05-14-2023, 12:52 PM
CK and HP Prime G1 calculator (HW version A, CAS v. 1.5.0 & OS v. V0.050.640) updated to the latest version 22.1.14730 (023 04 13). The CK sees G1 calculator connected via USB cable. When I click on calculator name in CK to display all calc. items, the calculator reboots immediately. The same response on W10 and W11; Firewall disabled. No such issue with updated PC HP Prime or Android HP Prime Pro (2.1.14594 (2021 05 14)). Hope next SW release fix this issue (connectivity to HP Prime G1, HW v. A under W10 & W11) soon. Thank you.
Pavel
Pavel
05-18-2023, 06:30 PM
(05-10-2023 07:53 PM)rprosperi Wrote: [ -> ](05-10-2023 12:24 PM)CT82716 Wrote: [ -> ]Hi all,
Heyy, I have some news! I received the calculator and I was able to update its firmware and install some applications in the hpappdir format. Yee! Thank you for the instructions.
Now I'm trying to figure out if there are any apps that are not in the hpappdir format, and if so how to install them.. anyway thank you
05-18-2023, 07:31 PM
(05-18-2023 06:30 PM)CT82716 Wrote: [ -> ]Now I'm trying to figure out if there are any apps that are not in the hpappdir format, and if so how to install them.. anyway thank you
My notes say:
• app/zip may be dragged onto the calculator, or to the applications folder
• same for an hpappdir directory/folder
• an hpprgm file may be dragged to the Programs directory/folder
not sure if that help…
05-18-2023, 08:31 PM
(05-18-2023 07:31 PM)cdmackay Wrote: [ -> ](05-18-2023 06:30 PM)CT82716 Wrote: [ -> ]Now I'm trying to figure out if there are any apps that are not in the hpappdir format, and if so how to install them.. anyway thank you
My notes say:
Yes, anything can help me. I'm getting more familiar with the calculator.
TY
06-03-2023, 04:59 PM
(05-10-2023 07:53 PM)rprosperi Wrote: [ -> ]You should be all set. Please report your results once you've had a chance to try it.
Hi! so i think i have a problem.
I installed some programs and applications, so far so good. but if I leave the calculator off for a few days, the calculator has nothing installed when it starts up!
the calculator has the basic programs and the system settings too, but no trace of the applications that i installed on my own. Is it intentional or is it a mistake?
06-08-2023, 10:11 AM
Any news on the Mac version? :-)
06-08-2023, 08:42 PM
(06-08-2023 10:11 AM)Luix Wrote: [ -> ]Any news on the Mac version? :-)
Yes, I'm very keen to know too, please. No Win boxes here.
07-16-2023, 09:06 PM
(05-01-2023 11:18 AM)KlaasKuperus Wrote: [ -> ]Already?(04-30-2023 01:12 PM)Dirk.nl Wrote: [ -> ]Klaas,
Thank you very much for this update.
The Prime software is in good hands with Moravia!
This is very reassuring for us as users. Hopefully your focus is on solving any errors in a timely manner.
Thanks again!
Greetings.
Thanks for the nice words! We're now focusing on the next steps and target towards a new update during the summer. We'll keep Prime alive for sure!
If you encounter any issues, best is to email me at klaas.kuperus@moravia-consulting.com. Please make sure to mention your serial code, revision number and date of purchase and a detailed description of the problem you're having. I will make sure you get a timely response and help you to fix it.
Thanks for keeping the suggestions coming as well, we read them all.
07-17-2023, 09:04 AM
Nice to hear some will be getting an update.
Will that new update reinstate the HP Prime App on Android that is currently missing from Google Play (except on old Androids)?
07-17-2023, 05:33 PM
(07-17-2023 09:04 AM)StephenG1CMZ Wrote: [ -> ]Will that new update reinstate the HP Prime App on Android that is currently missing from Google Play (except on old Androids)?
I surely hope that we will receive an update for the Android Pro app soon. Would be interested to see how Python works on this platform, and some of the other "new" features, which are not yet present on the latest version.
For me, it does not seem to be missing in the store for a recent Android device. I have a Pixel 7 with latest Android 13 monthly update, and it is showing in PlayStore for me when searching for "HP Prime". Maybe they have set a strange list of device specifications or devices, so it is not showing up for you.
