01-18-2020, 09:34 PM
(01-17-2020 06:44 PM)Jet1945 Wrote: [ -> ](01-17-2020 06:05 PM)smp Wrote: [ -> ]My HP Connectivity Kit is indicating no updates available.
Is this another time that we have to do everything manually again?
smp
I downloaded the firmware and put the files is Connectivity folder under Firmware in the sub-folder marked PrimeG2.
The connectivity kit looks there for the updates.
Note: Ensure that you also DL the companion Connectivity Kit for the Firmware update (there is also a Virtual Calculator update too).
I apologize up front for my continued dumb-ness in this situation.
I finally jumped through all the Mac OS hoops to get the latest HP Connectivity Kit installed. I am now successfully running with HPCK 2.1.14425 (2020 1 16).
If I use the HPCK to check for updates, it reports that no updates are available.
Based on the advice quoted above, I returned to the HPCalc web site and looked here:
https://www.hpcalc.org/prime/pc/
I see there an entry for HP Prime Firmware 2.1.14425 (2020-01-16) right under the entry for the Mac OS HP Connectivity Kit. However, the contents of that .ZIP file are:
Length Date Time Name
33554432 2020-01-16 07:20 PRIME_APP.DAT
708 2020-01-16 07:20 Prime_FW.md5
4194304 2018-10-04 13:35 PRIME_MASTER.DAT
1048576 2018-10-04 13:35 PRIME_OS.ROM
79276 2020-01-16 12:19 release_info.txt
538 2019-12-17 06:00 release_info_CHS.html
727 2019-12-17 06:00 release_info_DEU.html
597 2019-12-17 06:00 release_info_EN.html
688 2019-12-17 06:00 release_info_ESP.html
780 2019-12-17 06:00 release_info_FRA.html
739 2019-12-17 06:00 release_info_JPN.html
626 2019-12-17 06:00 release_info_NLD.html
669 2019-12-17 06:00 release_info_PTB.html
3 2020-01-16 07:20 version_20200116
38882663 14 files
These files appear to be the files for the Prime G1 calculator. There is no HPPrime_OS.img file, which I believe would be the one for the Prime G2 calculator.
Am I missing something? Is is that the update for the Prime G2 has not yet been posted, or has been removed? Any advice or comments would be very welcome!
smp
