HP Prime Software Library
Threads
- converting between EME2000 and true-of-date coordinates (0 Replies)
- trajectory modeling in the flight path coordinate system (0 Replies)
- conversion from inertial to flight path coordinates (0 Replies)
- computing mean or apparent Greenwich sidereal time (0 Replies)
- computing precession with the HP Prime (0 Replies)
- An HP PPL implementation of the IAU 2000b nutation algorithm (1 Reply)
- An HP PPL implementation of the IAU 1980 nutation algorithm (0 Replies)
- converting between classical and modified equinoctial orbital elements (0 Replies)
- classical orbital elements of a hyperbolic flyby orbit (0 Replies)
- cubic spline "fit" and interpolation of tabular data (0 Replies)
- mean and osculating classical orbital elements (0 Replies)
- predicting perigee and apogee of the Moon (0 Replies)
- converting a state vector to C3, RLA and DLA (0 Replies)
- single impulse deorbit from an elliptical orbit (0 Replies)
- Low-precision ephemeris for the Sun, Moon and planets (0 Replies)
- Osculating orbital elements of the Moon (0 Replies)
- Shadow Conditions of Earth Satellites - Kozai orbit propagation (0 Replies)
- Constant Amount Applied to Principal (0 Replies)
- Runge–Kutta–Fehlberg RKF System of ODEs Working CAS Function (0 Replies)
- computing B plane coordinates (0 Replies)
- Impulsive deorbit from a circular Earth orbit (1 Reply)
- Working Runge–Kutta–Fehlberg RKF for one equation (1 Reply)
- Contour Plots (1 Reply)
- Runge-Kutta 1.1 Please Check If it's Broken or Not (0 Replies)
- SVD - Singular Value Decomposition 14-FEB-2017 (12 Replies)
- Nodal period of an Earth satellite - numerical integration solution (0 Replies)
- Calculating the orbital periods of an Earth satellite (0 Replies)
- calculating the transfer/included angle between two coplanar position vectors (0 Replies)
- Creating a Chebyshev ephemeris of an inner planet (0 Replies)
- Creating a Chebyshev ephemeris of the sun (0 Replies)
