HP-65/67/97 Software Library
Threads
- (HP-67) Two stock-assessment programs (0 Replies)
- (HP-65) A Simple Iterative Solution to the Catch Equation (0 Replies)
- (HP-65) Weapons Effects Analyses (1 Reply)
- (HP-97S) Atomic-Absorption Programmes (0 Replies)
- (HP-67) Calculation of Bond Angles, Lengths & Dihedral (5 Replies)
- (HP-67) Breakeven Calculations (0 Replies)
- (HP-67) Thermodynamic programs (0 Replies)
- (HP-67) Design Calculations for Passive-Solar Buildings (0 Replies)
- (HP-65) The destructive bond pull test (1 Reply)
- (HP-67) Statistical Energy Response Prediction Methods for Structural Systems (0 Replies)
- (HP-67) Cryptography (1 Reply)
- (HP-97) Linear Regression Analysis Using a Programable Pocket Calculator (1 Reply)
- (HP-97) Calculation of the Two-Way Analysis of Variance (ANOVA) (0 Replies)
- (HP-97) Calculation of Multiple Regression with Three Independent Variables (0 Replies)
- (HP-97) Calculation of the Two-Way Analysis of Variance (ANOVA) with Subsampling (1 Reply)
- (HP-65) A Program For Blackbody Radiation Calculations (6 Replies)
- (HP-97) Estimating Moose Population Parameters from Aerial Surveys (3 Replies)
- (HP-97) Field Procedures & Data Reduction Methods (sensitivity surveys) (0 Replies)
- (HP-97) Reducing Alidade or Transit Stadia Traverse Data (0 Replies)
- (HP-97) An Evaluation System to Rate Feedlot Pollution Potential (0 Replies)
- (HP-65) Air Pollution Measurement Studies: Stationary Sources (0 Replies)
- (HP-97) Stability Design of Grass-Lined Open Channels (0 Replies)
- (HP-67) Soil Horizon Depth Correction Based on Slope Gradient (0 Replies)
- (HP-97) Estimating Water Requirements for Corn with a Pocket Calculator (0 Replies)
- (HP-67) Epidemiologic Analysis with a Programmable Calculator (0 Replies)
- (HP-97) A Closed-Form Solution for Noise Contours (0 Replies)
- (HP-65) Field Computation of Winds-Aloft Velocities (1 Reply)
- (HP-67) Bicycle-Safe Grate Inlets Design (0 Replies)
- (HP-67) Predicting the Payload Capability of Cable Logging Systems (2 Replies)
- (HP-67) Exploration Geophysics Calculator Programs: (0 Replies)
