Re: Is this from an HP-97s? Message #7 Posted by Eric Smith on 8 Feb 2013, 10:06 p.m., in response to message #6 by aj04062
Sure, if you build a clone of the external box. It contained two boards full of SSI/MSI chips.
Or, using modern technology, you could probably do it using a PIC microcontroller, but the trick would be to write the firmware.
