Re: Repair of HP 11C Message #5 Posted by Geoff Quickfall on 14 Mar 2010, 2:33 p.m., in response to message #4 by Dave Shaffer (Arizona)
Dave is correct.
To minimize the need to realign I start with small points of application on the bezel with corresponding points on the case. There is no need to coat the entire bezel and case at all contact points.
Then, with the bezel at a 45' angle to the case (longitudinally) place the bezel on the case starting at one end. Line it up at this point then lower the opposite end confirming the line up, until the bezel is in place.
If after this it is out of alignment, a reaplication of heat on the bezel as described (and as the glue is new) will allow you to remove the bezel and reapply it -or- to remove the bezel, pick off the glue from the case and bezel and reapply it.
Cheers, Geoff
I have used this method for applying Classic labels, Voyager bezels, Pioneer keyboard overlays and have never had to remove them yet (perhaps just lucky)
In any case (pun intended) let us see the results.
