Re: 33E repair Message #7 Posted by Karl Schneider on 28 Dec 2002, 2:04 a.m., in response to message #6 by Katie Wasserman
I had taken a similar, but cruder, approach to Katie's when repairing the battery terminals of one of my "old" units. I bought the thinnest strip of brass I could find from a hobby shop, cut it into the approximate size and shape of a terminal, bent it to form a contact, punched a hole in the upper part large enough to surround the rivet, filed the backside down, then soldered it to the broken terminal.
A soldering iron will heat the board and strip quickly, but they seem to be able to take it.
The repair worked, but the metal strip was too thick (20 mil?); it doesn't give.
I now have a "new" unit that needs both terminals repaired. For that job, I then got pieces of "shim stock" from a machine shop. It's available in brass or steel in various thciknesses from 3 mil to 15+ mil. (Katie recommended 0.01" = 10 mil).
BTW, I discovered and use a good, safe, and easy way to separate the case halves of Spice units. I'll dig up the link where I described the method. Sometime, I'll prepare the description with pictures I took.
