fix card reader Message #1 Posted by Jeff Glass on 6 Aug 2002, 3:18 p.m.
Hello:
I have a card reader for the HP-41 that has the age old symptom of depositing sticky crud on program cards that I try to read. I then took it apart and cleaned it up and replaced the gummy glob with O-rings. Now, the cards run through there just fine. The first two cards I ran through, it read the programs into memory and they ran fine. Now the problem is, whatever card I run through, I get a checksum error. This reader seems to be writing to the cards because they can be read on a good reader. I know the cards I have are good because they read fine on a known-good reader.
I'm a pretty good bench tech and I fix things for a living. I've never fixed a card reader before, and I need some help and advice. If you know of someone that could fix this thing, please let me know that, too.
I'm new to this forum so I do not know for sure how to receive responses to this messsage. Please email me directly.
Thank you very much,
Jeff Glass, BSEE
xmitters@aol.com
