Multi-Dimensional Matrices
04-12-2017, 05:48 PM
The code below checks OK but doesn't run. Is it possible to have n-dimensional tables? If so, how do you access them?
Tom L
PHP Code:
EXPORT mattest()
local a
:=[[[1,2,3],[2,3,4],[19,20,21]],[[4,5,6],[7,8,9],[-1,-2,-3]],[[10,11,12],[13,14,15],[-5,-6,-7]]];
print(
a(2,1,1));
END
Tom L
...other than that, Mrs. Lincoln, what did you think of the play?
04-12-2017, 06:31 PM
RE: Multi-Dimensional Matrices
The hp-prime supports only up to 2D,
In a next firmware the compiler should detect the validity of an array (maximum 2D)
You can work with n-dimensional arrays as a list
PHP Code:
EXPORT mattest()
    L1
:= { {{1,2,3},{2,3,4},{19,20,21}}, {{4,5,6},{7,8,9},{-1,-2,-3}}, {{10,11,12},{13,14,15},{-5,-6,-7}}};
    print(
L1(2,1,3)); // 6
END
04-12-2017, 06:42 PM
You can either use lists for non-CAS programs, or you can create a CAS program that will do what you want if you specifically want to use the [ ] delimiters for your data.
Graph 3D | QPI | SolveSys
04-12-2017, 06:43 PM (This post was last modified: 04-12-2017 06:47 PM by toml_12953.)
(04-12-2017 06:31 PM)compsystems Wrote:  The hp-prime supports only up to 2D,
PHP Code:
EXPORT mattest()
    L1
    print(
L1(2,1,3)); // 6
END
Thanks! Now if only MAKELIST was extended to create multi-dimensional lists, it'd be great! Creating a 20x10x30 list will be a challenge the way it is now.
Tom L
Tom L
04-12-2017, 06:45 PM
(04-12-2017 06:43 PM)toml_12953 Wrote:  Thanks! Now if only MAKELIST was extended to create multi-dimensional lists, it'd be great!
Tom L
Create a program that outputs the desired contents of a list, and have MAKELIST call that program.
08-31-2017, 04:44 AM
I'm surprised it's limited at 2D. Tensor analysis is used in a lot of engineering applications (especially mechanical engineering)....so being able to get the inverse, multiplication, etc, etc...of multidimensional arrays shouldn't be that difficult to add to the firmware...
08-31-2017, 05:22 AM
Actually, I take that back....multidimensional array operations can get very complex and are dependent on what you want to do. Classical matrix algebra doesn't go beyond 2D anyways.
