integration problem
03-30-2017, 09:00 AM (This post was last modified: 03-30-2017 09:12 AM by leprechaun.)
integration problem
I have a simple question about doing calculations. I suppose it is a simple one, or to be more precise two questions.
Question one.
If I use the "x t phi n" KEY on the android app of the prime it gives an x. If I do so on the virtual prime it says n.The physical prime is on the x side again. Can someone explain the n on the virtual prime to me? I tried deleting the cas vars.
Question two.
If I want to build a table like int(sin(x), start, pi/2) == factor*int(sin(x),0,pi/2), where factor is in the range from 0..1.
How would I do that best? Hope the task is clear: a table of start angles resulting in an equidistant, increasing area under the sin-curve.
Thanks a lot
P.S.
even more problems.
integral(SIN(x)dx,0,pi) = approx(-180*COS(pi)/pi + 180/pi) a b/c -> 86.11E-3 on the physical prime (!)
integral(SIN(n)dn,0,pi) = 2 on the virtual prime (n because of question 1)
integral(SIN(x)dx,0,pi) = 2 on the android app
What is happening on the physical prime??
03-30-2017, 09:38 AM
RE: integration problem
Quote:integral(SIN(x)dx,0,pi) = approx(-180*COS(pi)/pi + 180/pi) a b/c -> 86.11E-3 on the physical prime (!)
because your angle mode is set to degrees instead of radians which you should use for calculus tasks.
Quote:integral(SIN(n)dn,0,pi) = 2 on the virtual prime (n because of question 1)
because your active application is Sequence, this x...key changes its behaviour according to that.
Your table can easily be made using makelist :MAKELIST(int(sin(x),x,0,t),t,0,PI,pi/5).
Arno
03-30-2017, 11:01 AM
(03-30-2017 09:00 AM)leprechaun Wrote:  Question one.
Is the active App on the physical Prime the same as on the Android Prime? Have a look at what's in the title bar at the top of the display.
The character actually typed by the "x t theta n" key depends on the active app.
03-30-2017, 11:10 AM
great answers. Thank you very much!
