Early HP35 again: Let's play "spot the difference"
11-18-2016, 04:13 PM (This post was last modified: 11-18-2016 07:30 PM by Harald.)
This is a display PCB as I know it:
[Image: key17ls6e.jpg]
And this one is an early one that surprises me:
[Image: key22xsfi.jpg]
Can you spot the difference?
Ok, yes, the left one is missing a anode drive, I know Smile.
But it is also missing an inductor for the clock generator!
It has 380pF from pin 9 of the anode driver to ground.
Ususally there is a 150pF in series with 330┬ÁH from pin 9 to ground.
However the clock is working fine.
Does anyone know if the anode driver initially had a different design?
Cheers,
Harald
11-18-2016, 11:44 PM
RE: Early HP35 again: Let's play "spot the difference"
Interesting.
I checked my archived HP-35 photos and what i have from pin 9 is a 330uH inductor in series with a 150pF to ground.
It seems the machine on your second picture (the one missing the inductor) have the 150pF cap disconnected. Was the machine modified on the PCB bottom side to wire the cap to ground?
11-19-2016, 05:50 AM
(11-18-2016 04:13 PM)Harald Wrote:  This is a display PCB as I know it:
The PCB design is a bit different below pin 1 of the chip so might have some bearing on the change.
cheers
Tony
11-19-2016, 08:31 AM (This post was last modified: 11-19-2016 08:32 AM by PANAMATIK.)
(11-19-2016 05:50 AM)teenix Wrote:  The PCB design is a bit different below pin 1 of the chip ....
I can see only assembly differences. There were small assembly modifications also in the woodstock boards. Perhaps they learned they could remove some parts after having units in the market.
Bernhard
11-19-2016, 11:25 AM
(11-19-2016 08:31 AM)PANAMATIK Wrote:  I can see only assembly differences. There were small assembly modifications also in the woodstock boards. Perhaps they learned they could remove some parts after having units in the market.
Bernhard
Bit tricky to spot, there are also other track differences above the led display.
cheers
Tony
11-19-2016, 11:46 AM (This post was last modified: 11-19-2016 11:49 AM by Harald.)
There is a slight modification in the PCB. The point where inductor and capacitor can be connected has moved a little and the trace going around it has moved as well. That allows a slightly longer inductor to be installed, but electrically it is the same.
On the first board the 380pF goes from pin 9 to ground. The ground plane on the bottom side is a bit larger than on the top. But the capacitor is connected to it.
The Anode driver has a fault, but the clock was still working. So I am sure this anode driver (1820-0853) does not require an inductor for the oscillator.
I have now inatalled 330uH and 150pF in order to install a new anode driver. I don't have a 0853 available as a replacement
11-19-2016, 01:51 PM
(11-19-2016 11:46 AM)Harald Wrote:  There is a slight modification in the PCB...
Very tricky to spot indeed.
The electrically identical modifications can be understood, when you know, that the layout was "painted" manually by slim black tape strips on a transparent film. During mass production the film had to be reused several times and some lines could have moved and had to be repaired or readjusted. Just an assumption.
Bernhard
