Zeta Function
01-19-2016, 09:57 PM (This post was last modified: 01-19-2016 09:58 PM by Namir.)
Zeta Function
Here is a program that calculates the Zeta function. The program prompts you for s, the argument for the function, and for the tolerance value (recommend 1e-8). The function places the function's value in the X stack register,
1    LBL "ZETA"
2    LBL A
3    S?
4    PROMPT
5    STO 0
6    TOLER?
7    PROMPT
8    STO 07        # store tolerance
9    1
10    STO 04        # n=1
11    STO 08        # n! = 1
12    2
13    /
14    STO 01        # OutSum = 1/2
15    LBL 00        #--------------------------- start of outer loop
16    RCL 04        # View n
17    PSE
18    STO 11        # I = n
19    STO* 08        # update n!
20    RCL 08
21    STO 10        # init (n-k)!
22    1
23    STO 03        # k = 1
24    STO 09        # k! =1
25    STO 02        # InSum = 1
26    STO 06        # CHS=1
27    LBL 01        # --------------------------- start of inner loop
28    -1
29    STO* 06        # CHS=-CHS
30    RCL 03
31    STO* 09        # update k!
32    RCL 11
33    X=0?
34    GTO 02
35    STO/ 10        # update (n-k)!
36    1
37    RCL 10
38    X=0?
39    +
40    STO 10
41    1
42    STO- 11        # I = I - 1
43    LBL 02
44    RCL 08
45    RCL 09
46    /
47    RCL 10
48    /
49    RCL 06
50    *
51    RCL 03
52    1
53    +
54    STO 03        # k = k + 1
55    RCL 00
56    Y^X
57    /
58    STO+ 02        # InSum = InSum + ...
59    RCL 04
60    RCL 03
61    X<=Y?        # k<=n?
62    GTO 01        # --------------------------- End of Inner loop
63    RCL 02
64    2
65    RCL 04
66    1
67    +
68    STO 04        # n = n + 1
69    +
70    Y^X
71    /
72    STO+ 01        # OutSum = OutSum + Term
73    ABS
74    RCL 07
75    X<=Y?        # Tolerance <= Term?
76    GTO 00        # --------------------------- End of Outer loop
77    2
78    1
79    RCL 00
80    -
81    Y^X
82    CHS
83    1
84    +        # calculate 1 - 2^(1-s)
85    1/X
86    RCL 01
87    *
88    RTN
The memory map for the program is:
R00 = s
R01 = Outer Sun, Outer Sum
R02 = Inner Sum, Inner Sum
R03 = k
R04 = n
R05 = Term
R06 = CHS
R07 = Toler
R08 = n!
R09 = k!
R10 = (n-k)!
R11 = I
The function uses a fast converging series (see Wikipedia) and can give results for small arguments of s such as Zeta(1.1).
Namir
PS: I am aware that Jean-Marie Baillard has a Zeta function implemented in the HP-41C Software Library. His program is shorter than mine and uses just two registers. However, I tried to calculate Zeta(1.1) using his version and I had to stop after the HP-41CX emulator went on and on and on!
01-24-2016, 09:25 AM (This post was last modified: 01-24-2016 09:26 AM by Ángel Martin.)
RE: Zeta Function
(01-19-2016 09:57 PM)Namir Wrote:  PS: I am aware that Jean-Marie Baillard has a Zeta function implemented in the HP-41C Software Library. His program is shorter than mine and uses just two registers. However, I tried to calculate Zeta(1.1) using his version and I had to stop after the HP-41CX emulator went on and on and on!
Hi Namir, I guess you must have something wrong in your V41 setup - or a bad transcription of the program code. I just ran the case x=1.1 using ZETAX in the SandMath (which implements Jean-Marc's Borwein algorithm) and it took 13.48 seconds to return the result 10.58444847. I also ran it for x=1.001, which returned 1,000.577289 in approximately the same time. Both examples done at the default speed, i.e. NOT in TURBO mode.
Cheers,
'AM
