Idea: new keyword OPERATOR
06-11-2015, 12:02 PM (This post was last modified: 06-11-2015 05:00 PM by compsystems.)
Hello, sorry for my bad English, my multilingual chip is damaged =(
I want to create a new library of functions, but using operator notation, nonfunctional
functions are currently defined as follows
functionname (arg1, arg2)
Begin
End;
I think, should add a new keyword Operator
Operator arg1 functionname arg2;
Begin
End;
Operator arg1 ⊗ arg2;
Begin
End;
Operator arg1 ⊕ arg2;
Begin
End;
Operator arg1 ⊂ arg2;
Begin
End;
Good idea?
+1 or -1
The hp48 allowed to define functions as operators
10-12-2015, 07:03 PM
RE: Idea: new keyword OPERATOR
Having the option to use infix notation when you are used to it can certainly be clearer, but your syntax looks like you would only use the infix notation for the functions you define.
I would suggest instead a syntax more like that used in POP-2:
Definition:
EXPORT matrixmultiply(a,b)
Begin
End -> "***"; //map this procedure to infix symbol ***
Call either as now:
Matrixmuliply(a,b); //useful if you don't know the infix symbol
Or in infix if you like:
A *** b; //more readable
(In fact, in POP-2 you could just use a single "*", and it could work out which multiply you needed based on parameter types:
two reals => internal multiply,
Two matrices => use defined matrix multiply procedure etc.)
Stephen Lewkowicz (G1CMZ)
The word "set" has the most definitions in the OED
