FDISP Key & Fractions on 41cx
12-21-2023, 03:45 AM
I am new to the 41cx.
Is there a module and overlay for the 41cx (I'm using the i41cx app) that will function like a 35s or 32sii in regards to entering fractions with a decimal point and converting between the fractions and decimal values with the FDISP key?
I'm in the process of reading documentation on the calculator and the modules but it is a lot to sort through.
I appreciate the guidance.
12-21-2023, 01:40 PM (This post was last modified: 12-21-2023 01:42 PM by Sylvain Cote.)
RE: FDISP Key & Fractions on 41cx
Without doing any research, I do not remember an mcode function that would do that on the HP-41.
The "standard" way would be to use ALPHA mode to enter/display the fraction value and use the stack to enter/display the numerical values.
I do not know if it helps, the following programs are part of the PPC ROM:
  • DF : Decimal to Fraction : PPC ROM Manual, p.124 : This routine will convert a decimal to a fraction which approximates the decimal.
  • FR : Fractions : PPC ROM Manual, p.170 : This program has routines for addition, subtraction, multiplication, division, and reduction of fractions. Setting a flag (10) allows fractional to be displayed in the alpha register.
Sylvain Côté
12-21-2023, 02:19 PM
This is very helpful.
I appreciate it.
12-22-2023, 12:09 AM
The excellent SandMath 4x4 module has D>F, using the same algorithm as the PPC ROM's DF, and a fraction launcher that allows simple addition & multiplication of fractions entered on the 4 stack levels. But not the a.b.c entry method of the 32SII/35S (and WP43).
Cambridge, UK
41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot
Casio, Rockwell 18R
12-22-2023, 12:40 AM
Thank you, I will look at the SandMath modules too.
I tried the PPC module and it worked well enough that I have spent all day looking at functions and modules but only got through a small number of them.
The 41cx is really amazing and the iPhone app has opened up a new calculator world I didn't know about.
