Newbie to HP PPL
09-01-2023, 05:34 AM
Newbie to HP PPL
Hi Everyone,
I've taken formal Computer Languages courses, however, finding HP PPL quite difficult to find basic examples on the web. I'm trying to do the following pseudo code below:
Local A, B, C, D;
"Sin Θ = OPP/HYP";
"Enter 0 for Unknown"
"Sin Θ"? -->A;
"OPP"? --> B;
"HYP"?-->C;
If A=0;
Then B/C -->D;
"B/C=" D;
"Θ =" Sin^-1(D) --> E;
Basically, baby steps before I get into Functions with arguments.
Any assistance is greatly appreciated. Thank you.
09-01-2023, 12:54 PM (This post was last modified: 09-02-2023 02:43 PM by Insoft.)
RE: Newbie to HP PPL
You need to look at the tread HP-Prime: Documentation & Tutorials it has links to all stuff relating to what you’re looking for.
Other sites
https://www.hpcalc.org
https://en.hpprime.club
http://www.wiki4hp.com
To do Python within PPL
#PYTHON name
from hpprime import *
from micropython import *
#your python code here [/quote]
#end
You will want to write in PPL + Python, mainly python.
09-01-2023, 01:50 PM (This post was last modified: 09-01-2023 01:52 PM by gehakte_bits.)
Here are some examples in PPL [/code]...
// 2023.0901 pretty-prime v0.3b
#pragma mode(separator(.,;) integer(h32))
EXPORT prog()                               // most literally
LOCAL a,b,c,d,e;
  PRINT();
  PRINT("Enter zero for unknown");WAIT(1);
  PRINT("Sin Θ = OPP/HYP");
  INPUT(a,"Sin Θ");
  INPUT(b,"OPP");
  INPUT(c,"HYP");
  IF a=0 THEN
    d:=b/c;
    e:=ASIN(d);
    PRINT("B/C = "+d);
    PRINT("Θ ="+e);
EXPORT prog1()                              // fancier input
LOCAL x,a,b,c,d,e;
  x:=INPUT({{a,[0],{30,30,1}},
            {b,[0],{30,30,2}},
            {c,[0],{30,30,3}}},
           "Sin Θ = OPP/HYP",
           {"Sin Θ ","OPP ","HYP "},{},{},{0,10,10});
  IF x=1 THEN
    d:=b/c;
    e:=ASIN(d);
    PRINT();
    PRINT("B/C = "+d);
    PRINT("Θ ="+e);
//============= one of many solve solutions...(FNROOT,ROOT,fsolve...)
EXPORT hypp,opp,sinΘ;                       // must use externals with Solve
EXPORT prog2()                              // use solver
  E1:='SIN(sinΘ)=opp/hypp';
  FOR X:=0 TO 9 DO
    Solve.UNCHECK(X);
  Solve.CHECK(1);                           // select E1
  STARTAPP("Solve");
  STARTVIEW(2);
  DelHVars(sinΘ);
[code]
09-01-2023, 02:41 PM
INSOFT, Thank you, I'm mostly old school, Basic, Assembly Language, Fortran, C++, Pascal,
and Cobol. I will need to take a Python Class, before trying this. Thank you for your advice and I will definately be trying this in the future.
(09-01-2023 12:54 PM)Insoft Wrote:  You need to look at the tread HP-Prime: Documentation & Tutorials it has links to all stuff relating to what you’re looking for.
Other sites
#PYTHON name
#end
09-01-2023, 02:47 PM
gehakte_bits, Super thank you for the great examples. This will definately get me up and running for my pseudo code.
(09-01-2023 01:50 PM)gehakte_bits Wrote:  Here are some examples in PPL [/code]...
LOCAL a,b,c,d,e;
  PRINT();
  INPUT(a,"Sin Θ");
  INPUT(b,"OPP");
  INPUT(c,"HYP");
  IF a=0 THEN
    d:=b/c;
    e:=ASIN(d);
    PRINT("B/C = "+d);
    PRINT("Θ ="+e);
LOCAL x,a,b,c,d,e;
            {b,[0],{30,30,2}},
            {c,[0],{30,30,3}}},
           "Sin Θ = OPP/HYP",
  IF x=1 THEN
    d:=b/c;
    e:=ASIN(d);
    PRINT();
    PRINT("B/C = "+d);
    PRINT("Θ ="+e);
  FOR X:=0 TO 9 DO
    Solve.UNCHECK(X);
  STARTAPP("Solve");
  STARTVIEW(2);
  DelHVars(sinΘ);
[code]
09-02-2023, 04:32 AM
Thanks to all! Code is up and running. I will definately, learn some Python.
