integral bug in xCas or HP PRIME
07-30-2020, 08:14 PM
Hello everyone. I encountered an error calculating this integral:
int(exp(-s*t)*t*ln(t),t):
xCas or HP PRIME:
Ei((-s)*t)/s^2-e^((-s)*t)*ln(t)/s^2-t*e^((-s)*t)*ln(t)/s
Correct result:
Ei((-s)*t)/s^2-e^((-s)*t)*ln(t)/s^2-t*e^((-s)*t)*ln(t)/s-e^((-s)*t)/s^2
Do you think it's an xCas bug or am I doing something wrong?
07-30-2020, 08:33 PM
RE: integral bug in xCas or HP PRIME
Hi, robmio
this look like XCas bug:
XCas> f := exp(-s*t)*t*ln(t)
XCas> simplify(diff(int(f,t),t) - f) → -exp(-s*t)/s
Difference should be 0
07-31-2020, 06:23 AM
Thanks for confirming, Albert Chan. However, apart from this type of bug (which leads to incorrect results in calculating the Laplace transform of functions such as: "t^n*ln(x)", with "n∈N" and "n >= 0"), another limit of xCas, which I hope will be overcome sooner or later, is the calculation of limits of the type: "lim (Ei(i*x), x, +infinity" --> Pi*i, in the context of inverse Laplace transforms.
What do you think about it?
07-31-2020, 11:14 AM
Paradoxically, simple substitution x=s*t eliminated the bug
XCas> g := subst(f, t=x/s) / s    // dt = dx/s ⇒ f dt = g dx
XCas> G := int(g, x)                  // G = (-exp(-x)+ln(x/s)*exp(-x)*(-x-1)+Ei(-x))/s^2
XCas> F := subst(G, x=t*s)       // F = (-exp(-s*t)+ln(t)*exp(-s*t)*(-s*t-1)+Ei(-s*t))/s^2
XCas> simplify(diff(F,t) - f)        // 0 ⇒ F = ∫ f dt
07-31-2020, 11:43 AM
Great tip!
Paradoxically the integral is calculated correctly also with "ibpdv(exp(-s*t)*t*ln(t),-exp (-s*t)/s,t)"
--> (-t)*exp((-s)*t)*ln(t)/s+int((exp((-s)*t)*ln(t)+exp((-s)*t))/s,t).
I hope the various bugs will be corrected with the next firmware.
Sincerely, Roberto.
07-31-2020, 02:42 PM
(07-31-2020 11:43 AM)robmio Wrote:  Paradoxically the integral is calculated correctly also with "ibpdv(exp(-s*t)*t*ln(t),-exp (-s*t)/s,t)"
I did not know XCas had build-in integration by parts. Thanks !
d(uv) = u dv + v du     → ∫u dv = uv - ∫v du
Note: ibpu()/ibpdv() result had the minus sign *inside* integral, ∫u dv = uv + ∫-v du
Instead of v = exp(-s*t), you can also let dv = exp(-s*t), and let CAS handle scaling.
Or, even better, let u = t*ln(t), and let CAS figure out v.
XCas> m := ibpu(f, t*ln(t),t)          // [-t*ln(t)*exp(-s*t)/s , (exp(-s*t)+ln(t)*exp(-s*t))/s]
XCas> F := m[0] + int(m[1],t)       // note the + sign
07-31-2020, 04:25 PM
Great tip! Indeed, the HP PRIME calculator is really valid, despite some bugs, which, I hope, will be eliminated with the next firmware...
Best regards, Roberto.
Yesterday, 07:41 PM
This is indeed a bug in Xcas, now fixed, thank you!
User(s) browsing this thread: Edwin, teerasak, 4 Guest(s)
