HP49-50G Geodesic distance calculator
06-22-2020, 09:10 PM
For HP49-HP50, programs to calculate exact distances (error less than 0.5 mm) on the earth surface.
Copy the file-directory ending by .doc. Inside are two programs: 1) P1P2—> (indirect method/problem) 2) P1—>P2 (direct method/problem) Both programs give very accurate answers, for example the calculated distance is exact to 0.5 mm. Let's assume you have two points P1 and P2 on the earth geoid. 1) To get the shortest distance between them, enter the following known 4 "objects" in the stack: lat1 and lon1 in the stack, for the 1st point P1, then for the 2nd point P2 lat2 and lon2 again in the stack, all of them in the format DD.mmsssss (be careful, not decimal degrees or radians). Then press P1P2—> After a few seconds you get the distance s, the forward azimuth alpha12 (initial bearing) and the backward azimuth alpha21. 2) The direct method/problem: you enter the coordinates of P1 in then stack, i. e. lat1 and lon2, then enter the chosen distance s in meters and the forward azimuth alpha12 (initial bearing) in DD.mmsssss. Then press P1—>P2. After a few seconds you get the coordinates of the new point P2, i.e. lat2 and lon2, as well as the backward azimuth alpha 21. Iterations are made according to Vincenty's formulae. Be careful: in this version of the indirect method/problem, the program P1P2—> might not find a solution for (near) antipodal points P1/P2; but those are special, rare cases. You can change the radius a and b according to your preferred geoid; just modify the values in both programs P1P2—> and P1—>P2 and choose always meters (and not km or other units). All "degrees" results are given in DD.mmssss, so that you can check the results of one program directly entering those found values for the other program. Remarks are welcome. Gil |
06-23-2020, 11:43 AM
RE: HP49-50G Geodesic distance calculator
A little more info, please: what format/font is the DOC file?
SlideRule |
06-23-2020, 08:41 PM
You can't read it without a HP49-50G calculator.
You just have to copy the doc/file/repertory (ending by doc) included in my first post into your computer, let us say in path "... document". Then you use the EMU48 on your phone and execute "... load object". And retrieve the "object" from your computer located in "path". And there you are, with the programs written in RPN and algebraic mode. Regards, Gil |
06-23-2020, 09:02 PM
Here are the full codes of both programs included in the file/directory "... doc".
P1P2—> \<< "lat1 lon1 lat2 lon2 in D.mmss S < 0 W < 0 Vincenty fails for nearly antipode pts " DROP 'lon2' STO 'lat2' STO 'lon1' STO 'lat1' STO lat1 "lat1 D.mmss" \->TAG lon1 "lon1 D.mmss" \->TAG lat2 "lat2 D.mmss" \->TAG lon2 "lon2 D.mmss" \->TAG RAD 6378137 6356752.3142 'b' STO 'a' STO lat1 D\->RAD 'lat1' STO lat2 D\->RAD 'lat2' STO lon1 D\->RAD 'lon1' STO lon2 D\->RAD 'lon2' STO a b - a / 'f' STO lon2 lon1 - DUP '\Gl' STO 'l' STO 2 \pi * \->NUM '\Gl\180' STO 'ATAN((1-f)*TAN(lat1))' \->NUM 'u1' STO 'ATAN((1-f)*TAN(lat2))' \->NUM 'u2' STO WHILE \Gl \Gl\180 - ABS .000000000001 > REPEAT '\v/((COS(u2)*SIN(\Gl))^2+(COS(u1)*SIN(u2)-SIN(u1)*COS(u2)*COS(\Gl))^2)' \->NUM 'SIN.\Gs' STO 'SIN(u1)*SIN(u2)+COS(u1)*COS(u2)*COS(\Gl)' \->NUM 'COS.\Gs' STO SIN.\Gs COS.\Gs ATAN2 '\Gs' STO 'COS(u1)*COS(u2)*SIN(\Gl)/SIN(\Gs)' EVAL 'SIN.\Ga' STO 1 SIN.\Ga SQ - 'COS\178.\Ga' STO IF COS\178.\Ga 0 \=/ THEN 'COS.\Gs-2*SIN(u1)*SIN(u2)/COS\178.\Ga' EVAL ELSE 0 END 'COS.2\Gsm' STO 'f/16*COS\178.\Ga*(4+f*(4-3*COS\178.\Ga))' \->NUM 'C' STO \Gl '\Gl\180' STO 'l+(1-C)*f*SIN.\Ga*(\Gs+C*SIN.\Gs*(COS.2\Gsm+C*COS.\Gs*(-1+2*SQ(COS.2\Gsm))))' \->NUM '\Gl' STO END 'COS\178.\Ga*(a^2-b^2)/b^2' EVAL 'u\178' STO '1+u\178/16384*(4096+u\178*(-768+u\178*(320-175*u\178)))' \->NUM 'A' STO 'u\178/1024*(256+u\178*(-128+u\178*(74-47*u\178)))' \->NUM 'B' STO 'B*SIN.\Gs*(COS.2\Gsm+B/4*(COS.\Gs*(-1+2*COS.2\Gsm^2)-B/6*COS.2\Gsm*(-3+4*SIN.\Gs^2)*(-3+4*COS.2\Gsm^2)))' \->NUM '\GD\Gs' STO 'b*A*(\Gs-\GD\Gs)' \->NUM 's' STO s 1000 / "km" \->TAG 'COS(u2)*SIN(\Gl)' \->NUM 'COS(u1)*SIN(u2)-SIN(u1)*COS(u2)*COS(\Gl)' \->NUM ATAN2 \->NUM RAD\->D HMS\-> 360 MOD 360 MOD \->HMS DUP '\Ga1' STO "\Ga12 D.mmss\166 \|^\-> +90" \->TAG 'COS(u1)*SIN(\Gl)' \->NUM '-SIN(u1)*COS(u2)+COS(u1)*SIN(u2)*COS(\Gl)' \->NUM ATAN2 \pi + \->NUM RAD\->D HMS\-> 360 MOD 360 MOD \->HMS DUP '\Ga2' STO "\Ga21 D.mmss\166 \|^\-> +90" \->TAG { \GD\Gs B A u\178 C COS.2\Gsm COS\178.\Ga SIN.\Ga \Gs COS.\Gs SIN.\Gs u2 u1 \Gl\180 l \Gl } PURGE lat1 RAD\->D 'lat1' STO lon1 RAD\->D 'lon1' STO lat2 RAD\->D 'lat2' STO lon2 RAD\->D 'lon2' STO \>> P1—>P2 \<< "lat1 lon1 s \Ga1 lat1 lon1 \Ga1 \166\|^\->90 in D.mmss S < 0 W < 0 dist s in m " DROP RAD '\Ga1' STO 's' STO 'lon1' STO 'lat1' STO lat1 "lat1 D.mmss" \->TAG lon1 "lon1 D.mmss" \->TAG s "s [m]" \->TAG \Ga1 "\Ga12 D.mmss\166 \|^\-> +90" \->TAG 6378137 'a' STO 6356752.3142 'b' STO lat1 D\->RAD 'lat1' STO lon1 D\->RAD 'lon1' STO \Ga1 D\->RAD '\Ga1' STO a b - a / 'f' STO '(1-f)*TAN(lat1)' \->NUM 'TAN.u1' STO '1/\v/(1+TAN.u1^2)' \->NUM 'COS.u1' STO 'TAN.u1*COS.u1' \->NUM 'SIN.u1' STO TAN.u1 \Ga1 COS ATAN2 '\Gs1' STO 'COS.u1*SIN(\Ga1)' 'SIN.\Ga' STO 1 SIN.\Ga SQ - 'COS\178.\Ga' STO 'COS\178.\Ga*(a^2-b^2)/b^2' \->NUM 'u\178' STO '1+u\178/16384*(4096+u\178*(-768+u\178*(320-175*u\178)))' 'A' STO 'u\178/1024*(256+u\178*(-128+u\178*(74-47*u\178)))' \->NUM 'B' STO 's/(b*A)' \->NUM '\Gs' STO \Gs .01 - '\Gs\180' STO WHILE \Gs \Gs\180 - ABS .000000000001 > REPEAT 'COS(2*\Gs1+\Gs)' EVAL 'COS2.\Gsm' STO 'B*SIN(\Gs)*(COS2.\Gsm+B/4*(COS(\Gs)*(-1+2*COS2.\Gsm^2.)-B/6*COS2.\Gsm*(-3+4*SIN(\Gs)^2)*(-3+4*COS2.\Gsm^2)))' EVAL '\GD\Gs' STO \Gs '\Gs\180' STO 's/(b*A)+\GD\Gs' EVAL '\Gs' STO END 'SIN.u1*COS(\Gs)+COS.u1*SIN(\Gs)*COS(\Ga1)' \->NUM '(1-f)*\v/(SIN.\Ga^2+(SIN.u1*SIN(\Gs)-COS.u1*COS(\Gs)*COS(\Ga1))^2)' \->NUM ATAN2 RAD\->D 'lat2' STO lat2 "lat2 D.mmss" \->TAG 'SIN(\Gs)*SIN(\Ga1)' \->NUM 'COS.u1*COS(\Gs)-SIN.u1*SIN(\Gs)*COS(\Ga1)' \->NUM ATAN2 '\Gl' STO 'f/16*COS\178.\Ga*(4+f*(4-3*COS\178.\Ga))' \->NUM 'C' STO '\Gl-(1-C)*f*SIN.\Ga*(\Gs+C*SIN(\Gs)*(COS2.\Gsm+C*COS(\Gs)*(-1+2*COS2.\Gsm^2)))' \->NUM 'l' STO lon1 l + RAD\->D 'lon2' STO lon2 "lon2 D.mmss" \->TAG SIN.\Ga '-SIN.u1*SIN(\Gs)+COS.u1*COS(\Gs)*COS(\Ga1)' \->NUM ATAN2 \pi + \->NUM RAD\->D HMS\-> 360 MOD \->HMS '\Ga2' STO \Ga2 "\Ga21 D.mmss\166 \|^\-> +90" \->TAG { \Gs\180 COS2.\Gsm \GD\Gs B A u\178 COS\178.\Ga SIN.\Ga \Gs1 SIN.u1 COS.u1 TAN.u1 l C \Gl \Gs } PURGE lat1 RAD\->D 'lat1' STO lon1 RAD\->D 'lon1' STO \Ga1 RAD\->D '\Ga1' STO \>> And the two subprograms : RAD—>D \<< 180 * \pi / \->NUM \->HMS \>> D—>RAD \<< HMS\-> \pi * 180 / \->NUM \>> Regards, Gil |
06-23-2020, 09:33 PM
Thanks all, most helpful!
SlideRule |
06-23-2020, 10:02 PM
Two more points
A) Iin the previous transcription (given by the program inout): Gs stands for "Greek s", i. e. "sigma"; Ga stands for "Greek a", i. e. "alpha" ; Gl stands for "Greek l", i. e. "lambda". B) To work, when entering the four values in the "stack", the calculator should be in RPN mode. Regards, Gil |
06-23-2020, 10:39 PM
I forgot to include
the subprogram ATAN2, whose location is the utmost parent directory HOME : ATAN2 \<< \-> y x \<< CASE x 0 > THEN '2*ATAN(y/(\v/(x^2+y^2)+x))' END x 0 \<= y 0 \=/ AND THEN '2*ATAN((\v/(x^2+y^2)-x)/y)' END x 0 < y 0 == AND THEN '4*ATAN(1)' END x 0 == y 0 == AND THEN "Undef" END END \->NUM \>> \>> You might choose the alternative formula and program: ATAN2 \<< \-> y x \<< CASE x 0 > THEN y x / ATAN END x 0 < y 0 \>= AND THEN y x / ATAN -17 FS? IF THEN \pi ELSE 180 END + END x 0 < y 0 < AND THEN y x / ATAN -17 FS? IF THEN \pi ELSE 180 END - END x 0 == y 0 > AND THEN -17 FS? IF THEN \pi 2 / ELSE 90 END END x 0 == y 0 < AND THEN -17 FS? IF THEN \pi NEG 2 / ELSE -90 END END "Undef" END \->NUM \>> \>> Note \v/ stands for square root. Regards, Gil |
06-23-2020, 11:41 PM
Shorter version for
ATAN2 \<< \-> y x \<< CASE x 0 > THEN '2*ATAN(y/(\v/(x^2+y^2)+x))' END x 0 \<= y 0 \=/ AND THEN '2*ATAN((\v/(x^2+y^2)-x)/y)' END x 0 < y 0 == AND THEN '4*ATAN(1)' END "Undef" END \->NUM \>> \>> And for the alternative formula, taking into account the three possible "formats of angles", i. e. DEG/RAD/GRAD: ATAN2 \<< \-> y x \<< CASE x 0 > THEN y x / ATAN END x 0 < y 0 \>= AND THEN y x / ATAN -17 FS? IF THEN \pi ELSE IF -18 FC? THEN 180 ELSE 200 END END + END x 0 < y 0 < AND THEN y x / ATAN -17 FS? IF THEN \pi ELSE IF -18 FC? THEN 180 ELSE 200 END END - END x 0 == y 0 > AND THEN -17 FS? IF THEN \pi 2 / ELSE IF -18 FC? THEN 90 ELSE 100 END END END x 0 == y 0 < AND THEN -17 FS? IF THEN \pi NEG 2 / ELSE IF -18 FC? THEN -90 ELSE -100 END END END "Undef" END \->NUM \>> \>> Regards, Gil |
06-24-2020, 04:26 AM
atan2 is available as the built-in command ARG.
06-24-2020, 10:11 PM
I did not know... and was surprised not to find that useful "function".
Thanks for your observation. I think that I will adapt the program accordingly. Regards, Gil |
06-25-2020, 08:40 AM
Version 2 Added in this new version 2 the possibility to introduce the data relative to two points under the form of two complex numbers (lat1, lon1) (lat2, lon2), instead of only (in the first version) lat1 lon1 lat2 lon2. Furthermore, it is now possible to calculate in one single step a journey between several points that you must have created and saved previously. Suppose you want to calculate the distance between New York, Chicago and Berlin : 1) go to Directory DATA.DIST inside the current distance directory; 2) create there the three points in question (latitude first and longitude after latitude, both in DD.mmssss, minus sign for South-Latitude or for West-Longitude, R—>C to transform th lat_i lon_i into one point/complex number) 40.4651 -73.5838 R—>C 'N.York' STO 41.5255 -87.3723 R—>C 'Chicago' STO 52.3112 13.2418 R—>C 'Berlin' STO; 3) then select the three (less or more) points with {} and the way points names inside {N.York Chicago Berlin}; 4) then run/execute the program on the left screen P1..PN—>Σs. As explained above, the DATA.DIST directory contains your way points A1, A2,... An, a way point Ai having the form (lat_i, lon_i), lat_i and lon_i in DD.mmssss, and the program P1..PN—>Σs to calculate the separate tracks/distances. P1.. PN—>Sigma_s \<< DUPDUP SIZE { } \-> l0 siz l.s \<< l0 EVAL siz \->LIST 'l0' STO { } 'l.s' STO 1 siz 1 - FOR i l0 i GET l0 i 1 + GET UPDIR P1P2\->D DATA.DIST 7 DROPN l.s s + 'l.s' STO NEXT l.s DUP IF siz 2 > THEN \GSLIST END "Total [m]" \->TAG 0 FIX \>> \>> Used, as suggested by SammysHP, instead of my cumbersome and slow y x ATAN2 instructions (ATAN2 being a program to be created), the instructions (x y) ARC, as ARC as already built-in function in the calculator being about 30 times faster than the ATAN2 to be created in inserted. The new codes are the following: P1P2—>D \<< STD "lat1 lon1 lat2 lon2 in D.mmss S < 0 W < 0 Vincenty fails for nearly antipode pts " DROP DUP TYPE 1 == IF THEN OBJ\-> END 'lon2' STO 'lat2' STO DUP TYPE 1 == IF THEN OBJ\-> END 'lon1' STO 'lat1' STO lat1 "lat1 D.mmss" \->TAG lon1 "lon1 D.mmss" \->TAG lat2 "lat2 D.mmss" \->TAG lon2 "lon2 D.mmss" \->TAG RAD 6378137 6356752.3142 'b' STO 'a' STO lat1 D\->RAD 'lat1' STO lat2 D\->RAD 'lat2' STO lon1 D\->RAD 'lon1' STO lon2 D\->RAD 'lon2' STO a b - a / 'f' STO lon2 lon1 - DUP '\Gl' STO 'l' STO 2 \pi * \->NUM '\Gl\180' STO 'ATAN((1-f)*TAN(lat1))' \->NUM 'u1' STO 'ATAN((1-f)*TAN(lat2))' \->NUM 'u2' STO WHILE \Gl \Gl\180 - ABS .000000000001 > REPEAT '\v/((COS(u2)*SIN(\Gl))^2+(COS(u1)*SIN(u2)-SIN(u1)*COS(u2)*COS(\Gl))^2)' \->NUM 'SIN.\Gs' STO 'SIN(u1)*SIN(u2)+COS(u1)*COS(u2)*COS(\Gl)' \->NUM 'COS.\Gs' STO COS.\Gs SIN.\Gs R\->C ARG '\Gs' STO 'COS(u1)*COS(u2)*SIN(\Gl)/SIN(\Gs)' EVAL 'SIN.\Ga' STO 1 SIN.\Ga SQ - 'COS\178.\Ga' STO IF COS\178.\Ga 0 \=/ THEN 'COS.\Gs-2*SIN(u1)*SIN(u2)/COS\178.\Ga' EVAL ELSE 0 END 'COS.2\Gsm' STO 'f/16*COS\178.\Ga*(4+f*(4-3*COS\178.\Ga))' \->NUM 'C' STO \Gl '\Gl\180' STO 'l+(1-C)*f*SIN.\Ga*(\Gs+C*SIN.\Gs*(COS.2\Gsm+C*COS.\Gs*(-1+2*SQ(COS.2\Gsm))))' \->NUM '\Gl' STO END 'COS\178.\Ga*(a^2-b^2)/b^2' EVAL 'u\178' STO '1+u\178/16384*(4096+u\178*(-768+u\178*(320-175*u\178)))' \->NUM 'A' STO 'u\178/1024*(256+u\178*(-128+u\178*(74-47*u\178)))' \->NUM 'B' STO 'B*SIN.\Gs*(COS.2\Gsm+B/4*(COS.\Gs*(-1+2*COS.2\Gsm^2)-B/6*COS.2\Gsm*(-3+4*SIN.\Gs^2)*(-3+4*COS.2\Gsm^2)))' \->NUM '\GD\Gs' STO 'b*A*(\Gs-\GD\Gs)' \->NUM 's' STO s 1000 / "km" \->TAG 'COS(u1)*SIN(u2)-SIN(u1)*COS(u2)*COS(\Gl)' \->NUM 'COS(u2)*SIN(\Gl)' \->NUM R\->C ARG \->NUM RAD\->D HMS\-> 360 MOD 360 MOD \->HMS DUP '\Ga1' STO "\Ga12 D.mmss\166 \|^\-> +90" \->TAG '-SIN(u1)*COS(u2)+COS(u1)*SIN(u2)*COS(\Gl)' \->NUM 'COS(u1)*SIN(\Gl)' \->NUM R\->C ARG \pi + \->NUM RAD\->D HMS\-> 360 MOD 360 MOD \->HMS DUP '\Ga2' STO "\Ga21 D.mmss\166 \|^\-> +90" \->TAG { \GD\Gs B A u\178 C COS.2\Gsm COS\178.\Ga SIN.\Ga \Gs COS.\Gs SIN.\Gs u2 u1 \Gl\180 l \Gl } PURGE lat1 RAD\->D 'lat1' STO lon1 RAD\->D 'lon1' STO lat2 RAD\->D 'lat2' STO lon2 RAD\->D 'lon2' STO \>> P1—>P2 \<< STD "lat1 lon1 s \Ga1 lat1 lon1 \Ga1 \166\|^\->90 in D.mmss S < 0 W < 0 dist s in m " DROP RAD '\Ga1' STO 's' STO 'lon1' STO 'lat1' STO lat1 "lat1 D.mmss" \->TAG lon1 "lon1 D.mmss" \->TAG s "s [m]" \->TAG \Ga1 "\Ga12 D.mmss\166 \|^\-> +90" \->TAG 6378137 'a' STO 6356752.3142 'b' STO lat1 D\->RAD 'lat1' STO lon1 D\->RAD 'lon1' STO \Ga1 D\->RAD '\Ga1' STO a b - a / 'f' STO '(1-f)*TAN(lat1)' \->NUM 'TAN.u1' STO '1/\v/(1+TAN.u1^2)' \->NUM 'COS.u1' STO 'TAN.u1*COS.u1' \->NUM 'SIN.u1' STO \Ga1 COS TAN.u1 R\->C ARG '\Gs1' STO 'COS.u1*SIN(\Ga1)' \->NUM 'SIN.\Ga' STO 1 SIN.\Ga SQ - 'COS\178.\Ga' STO 'COS\178.\Ga*(a^2-b^2)/b^2' \->NUM 'u\178' STO '1+u\178/16384*(4096+u\178*(-768+u\178*(320-175*u\178)))' 'A' STO 'u\178/1024*(256+u\178*(-128+u\178*(74-47*u\178)))' \->NUM 'B' STO 's/(b*A)' \->NUM '\Gs' STO \Gs .01 - '\Gs\180' STO WHILE \Gs \Gs\180 - ABS .000000000001 > REPEAT 'COS(2*\Gs1+\Gs)' EVAL 'COS2.\Gsm' STO 'B*SIN(\Gs)*(COS2.\Gsm+B/4*(COS(\Gs)*(-1+2*COS2.\Gsm^2.)-B/6*COS2.\Gsm*(-3+4*SIN(\Gs)^2)*(-3+4*COS2.\Gsm^2)))' EVAL '\GD\Gs' STO \Gs '\Gs\180' STO 's/(b*A)+\GD\Gs' EVAL '\Gs' STO END '(1-f)*\v/(SIN.\Ga^2+(SIN.u1*SIN(\Gs)-COS.u1*COS(\Gs)*COS(\Ga1))^2)' \->NUM 'SIN.u1*COS(\Gs)+COS.u1*SIN(\Gs)*COS(\Ga1)' \->NUM R\->C ARG RAD\->D 'lat2' STO lat2 "lat2 D.mmss" \->TAG 'COS.u1*COS(\Gs)-SIN.u1*SIN(\Gs)*COS(\Ga1)' \->NUM 'SIN(\Gs)*SIN(\Ga1)' \->NUM R\->C ARG '\Gl' STO 'f/16*COS\178.\Ga*(4+f*(4-3*COS\178.\Ga))' \->NUM 'C' STO '\Gl-(1-C)*f*SIN.\Ga*(\Gs+C*SIN(\Gs)*(COS2.\Gsm+C*COS(\Gs)*(-1+2*COS2.\Gsm^2)))' \->NUM 'l' STO lon1 l + RAD\->D 'lon2' STO lon2 "lon2 D.mmss" \->TAG '-SIN.u1*SIN(\Gs)+COS.u1*COS(\Gs)*COS(\Ga1)' \->NUM SIN.\Ga R\->C ARG \pi + \->NUM RAD\->D HMS\-> 360 MOD \->HMS '\Ga2' STO \Ga2 "\Ga21 D.mmss\166 \|^\-> +90" \->TAG { \Gs\180 COS2.\Gsm \GD\Gs B A u\178 COS\178.\Ga SIN.\Ga \Gs1 SIN.u1 COS.u1 TAN.u1 l C \Gl \Gs } PURGE lat1 RAD\->D 'lat1' STO lon1 RAD\->D 'lon1' STO \Ga1 RAD\->D '\Ga1' STO \>> Besides, in that file/directory dist a new program lat—>R has been created to determinate the Earth Radius and the Earth circumference in function of the latitude: lat—>R \<< DEG DUP 'lat' STO HMS\-> \-> la \<< '\v/(((a^2*COS(la))^2+(b^2*SIN(la))^2)/((a*COS(la))^2+(b*SIN(la))^2))' \->NUM "R Earth(" lat + ")" + \->TAG DUP la COS * 2 * \pi * \->NUM "Circumf(" lat + ")" + \->TAG \>> \>> Nothing changed in RAD—>D \<< 180 * \pi / \->NUM \->HMS \>> D—>RAD \<< HMS\-> \pi * 180 / \->NUM \>> Notes All the latitudes, longitudes and angles have, as defore, always to be in DD.mmssss. And programs are to be used/run in RPN mode. Remarks welcome. Regards, Gil |
07-02-2020, 11:21 PM
RE: HP49-50G Geodesic distance calculator, Version 2.2
Just added explanations for the arguments to be entered.
07-07-2020, 03:23 PM
New version 2.3
As the circumference calculation (lat—>R) on a constant latitude was done with the wrong formula. Now it matches when checking with Visenty's formula. Regards |
