Viète's Formula for PI
06-17-2020, 05:06 PM (This post was last modified: 06-17-2020 08:55 PM by pinkman.)
Once again, I had another discussion with my cousin about PI (it's either PI or prime numbers...).
He told me about the beauty of the Viète's formula :
History here: link
This video shows the formula entered in CAS, and yes! I find it beautiful: https://youtu.be/BEYDBl94UpM
Thibault
06-17-2020, 09:37 PM
RE: Viète's Formula for PI
Cool! Really beautiful to see in the CAS the pi approximation in action! :-)
Ramón
Valladolid, Spain
TI-50, Casio fx-180P, HP48GX, HP50g, HP Prime G2
06-18-2020, 12:51 PM (This post was last modified: 06-18-2020 02:49 PM by pinkman.)
And the convergence speed is acceptable : for p(18) we have 10 digits.
p(18) means Σ(x,x,1,18) = 171 iterations.
Compared to Wallis formula (https://www.hpmuseum.org/forum/thread-14...ght=wallis), it's absolutely fast!
06-19-2020, 09:00 PM
very nice, thank you!
tiny tip: in CAS, for algebraic or fractional input, the a.b/c key also runs approx(); one less key-stroke than shift-enter.
Cambridge, UK
41CL/DM41X 12/15C/16C DM15/16 71B 17B/BII/bII+ 28S 42S/DM42 32SII 48GX 50g 35s 30b/WP34S Prime G2
& Casios, Rockwell 18R :)
06-19-2020, 11:12 PM
(06-18-2020 12:51 PM)pinkman Wrote:  Compared to Wallis formula (https://www.hpmuseum.org/forum/thread-14...ght=wallis), it's absolutely fast!
Yes, but it pales in comparison to the Wallis-Wasicki formula :-)
| N |         2*W         |        2*W*C        |
| 2 | 2.84444444444444444 | 3.14385964912280701 |
| 4 | 2.97215419501133786 | 3.14158816337302932 |
| 6 | 3.02317019200136082 | 3.14159266276745771 |
| 8 | 3.05058999605551092 | 3.14159265357083669 |
|10 | 3.06770380664349896 | 3.14159265358983256 |
|12 | 3.07940134316788626 | 3.14159265358979314 |
|14 | 3.08790206983111306 | 3.14159265358979321 |
Only 7 iterations (or 14, depending on how you implement the algorithm) for 18 correct decimal digits
(21697209162666264236130304/6906436179074198667175275 = 3.141592653589793238[633]...).
The Pascal code is available here. It should translate easily into the Prime programming language, but probably no joy with only 12 significant digits...
06-23-2020, 06:39 PM
(06-18-2020 12:51 PM)pinkman Wrote:  And the convergence speed is acceptable : for p(18) we have 10 digits.
For faster convergence, you might want to try this algorithm:
Program  Viete;
Uses Crt;
var         k:  Byte;
            n: LongInt;
            c: Char;
   d, p, t, v: Extended;
begin
  ClrScr;
  WriteLn('+---+----------------------+----------------------+');
  WriteLn('| k |         2*v          |         ~ pi         |');
  v := 1;
  n := 1;
  d := 0;
  for k := 1 to 15 do
    begin
      n := n + n;
      d := Sqrt(d + 2);
      v := v*d;
      t := 6*v*v - 2/3;
      p := 2*n/v*(t + 1)/t;
      WriteLn('|',k:2,' |',2*n/v:21:18,' |',p:21:18,' |')
    end;
  c := ReadKey
end.
| k |         2*v          |         ~ pi         |
| 1 | 2.828427124746190098 | 3.077994223988500989 |
| 2 | 3.061467458920718174 | 3.137427049842311165 |
| 3 | 3.121445152258052286 | 3.141329731135014592 |
| 4 | 3.136548490545939264 | 3.141576182507746574 |
| 5 | 3.140331156954752913 | 3.141591623553754287 |
| 6 | 3.141277250932772868 | 3.141592589203296386 |
| 7 | 3.141513801144301077 | 3.141592649565492850 |
| 8 | 3.141572940367091385 | 3.141592653338272210 |
| 9 | 3.141587725277159701 | 3.141592653574073140 |
|10 | 3.141591421511199975 | 3.141592653588810732 |
|11 | 3.141592345570117743 | 3.141592653589731833 |
|12 | 3.141592576584872667 | 3.141592653589789401 |
|13 | 3.141592634338562990 | 3.141592653589793000 |
|14 | 3.141592648776985670 | 3.141592653589793224 |
|15 | 3.141592652386591346 | 3.141592653589793238 |
06-23-2020, 09:58 PM
Quote:Yes, but it pales in comparison to the Wallis-Wasicki formula :-)
Here is a quick PPL port of your Wallis-Wasicki implementation:
EXPORT WallisWasicki()
LOCAL i, k, m, n;
LOCAL c, d, t, w;
  PRINT("+---+-------------+------------+");
  PRINT("| N |     2*W     |    2*W*C   |");
  FOR k := 1 TO 7 DO
      n := 2*k;
      w := 1;
      c := 0;
      d := 4*n;
      m := n + 1;
      FOR i := 1 TO k DO
          t := i*(16*i - 8);
          w := w*t*t/(t*(t - 2) - 3);
          c := (m - 4)/(d + m/(2 - c));
          m := m - 2
      c := 1 - c;
      PRINT("|" + n + " |" + 2*w + " |" + 2*w*c + " |");
  RETURN 2*w*c;
The terminal output is not well formatted, but still easy to read.
I’m also porting your 314 pi digits algorithm, I had to stop (work...) but it will be ready in a few hours (if I find the time).
06-23-2020, 10:04 PM
Yes! But... I really love to see the CAS in action, even if it reaches its limit in terms of recursivity.
06-23-2020, 10:52 PM (This post was last modified: 06-25-2020 09:08 PM by Gerson W. Barbosa.)
(06-23-2020 06:39 PM)Gerson W. Barbosa Wrote:  ...
The following appears to be better (more tests required) . Only one line has been changed. Anyway, here is it again:
Program  Viete;
Uses Crt;
var         k: Byte;
            n: LongInt;
            c: Char;
begin
  ClrScr;
  v := 1;
  n := 1;
  d := 0;
  for k := 1 to 15 do
    begin
      n := n + n;
      d := Sqrt(d + 2);
      v := v*d;
      t := 6*v*v - 27/10 - 1/(n*n);
    end;
  c := ReadKey
end.
| k |         2*v          |         ~ pi         |
| 1 | 2.828427124746190098 | 3.140960508696045357 |
| 2 | 3.061467458920718174 | 3.141593674140638978 |
| 3 | 3.121445152258052286 | 3.141592707164788547 |
| 4 | 3.136548490545939264 | 3.141592654569488290 |
| 5 | 3.140331156954752913 | 3.141592653605653769 |
| 6 | 3.141277250932772868 | 3.141592653590043215 |
| 7 | 3.141513801144301077 | 3.141592653589797153 |
| 8 | 3.141572940367091385 | 3.141592653589793300 |
| 9 | 3.141587725277159701 | 3.141592653589793240 |
|10 | 3.141591421511199975 | 3.141592653589793239 |
P.S.:
This yields 1.8 digits per iteration, three times as much when compared to the plain Viète's formula.
06-23-2020, 11:00 PM
Thank you very much for the PPL port!
Perhaps it's time I should get myself a Prime. But I think I will wait until a good arbitrary precision package is available, either built-in or third-party.
Gerson.
06-24-2020, 01:15 PM
The port of the 200-314-997 decimals will need the CAS, which has capabilities for manipulating big integers but not arbitrary precision decimal numbers.
I’ll check if I can avoid using decimals by calculating on a base of estimated_pi * 10^200 (or less, depending on CAS limit).
Need a few hours more!
06-29-2020, 05:52 AM
I wish the extremely fast HP Prime had the LongFloat Library integrated.
VP
06-29-2020, 10:54 PM
Me too!
Thibault - not collector but in love with the few HP models I own
06-30-2020, 03:05 PM
There must be some open source LongFloat library, if so Xcas could include it.
