(11C) Three Solvers
07-30-2019, 01:10 PM (This post was last modified: 11-01-2021 07:47 AM by Gamo.)
(11C) Three Solvers
Program use for Equation Solving solution of f(x)=0
This program can be use for three type of solvers
[A] Bisection Method use Two Guess X1 [ENTER] X2
[B] Secant Method use Two Guess X1 [ENTER] X2
[C] Newton Method Use One Guess
The accuracy result is based on you decimal setting. FIX 0 - 9
Program is credit to J T Patterson who make this possible.
More information at his page at: http://www.jepspectro.com/htmDoc/BisecnewtP.htm
Example:
To solve for X^X = 12345
Put f(x) = 0 routine at [LBL] E
LN
LSTx
x
RCL 6 // use Storage Register 6 for 12345
LN
RTN
Steps to run solver: USER mode and FIX 5
12345 STO 6
4 ENTER 6 [A] display 5.51659
Answer: X = 5.51659 using guess X1_4 and X2_6
Program:
LBL A  // Bisection
STO 0
Rv
STO 1
LBL 1
SF1
RCL 0
GSB E
STO 3
RCL 1
RCL 0
2
STO 2
GSB E
STO 4
RCL 3
x
X<0
GSB 3
F1
GSB 2
RCL 4
RND
X≠0
GTO 1
RCL 2
RTN
LBL2
RCL 2
STO 0
RTN
LBL 3
RCL 2
STO 1
CF1
RTN
LBL B  // Secant
STO 0
Rv
STO 1
RAN#
STO 3
LBL 4
RCL 0
RCL 1
STO 2
RCL 1
GSB E
STO 4
RCL 1
RCL 4
RCL 2
x
RCL 3
RCL 4
X=0
RAN#
STO 5
RCL 1
STO 0
RCL 4
STO 3
RCL 5
STO 1
RCL 4
RND
X≠0
GTO 4
RCL 1
RTN
LBL C  // Newton
STO 1
LBL 5
RCL 1
GSB E
STO 4
RCL 1
X=0
e^x
EEX
4
STO 2
RCL 1
GSB E
RCL 4
RCL 2
RCL 4
X<>Y
STO-1  // Store Arithmetic Subtraction
RCL 4
RND
X≠0
GTO 5
RCL 1
RTN
LBL D  // Result Answer
RCL 1
RTN
LBL E  // f(x)
RTN
Gamo
06-22-2020, 04:54 AM (This post was last modified: 06-22-2020 08:14 AM by Gamo.)
RE: (11C) Three Solvers
This solver is good to run on HP-11C, it run fast by depending on
your FIX accuracy value and user who not good at stacks manipulation.
This solver use Register 1 for the unknow X in the equation simply use
R1 for all X in your equations as shown in the example below.
Enter your equations with your X on R1
Enter educated guess and press [A]
Example: [USER] [FIX 4]
Find X with this equation: 55X^3 + 21X^2 - 11X - 1111 = 0
Enter f(x) equation to Lable [E]
[GTO] [E] g [P/R] this steps direct to f(x) routine
RCL 1
3
Y^X
55
x
RCL 1
X^2
21
x
RCL 1
11
x
1111
RTN
g [P/R]
Enter Guess: 4 [A] took about 20 second answer X=2.6253
Program:
LBL A
STO 1
1
STO 2
GSB E
STO 3
LBL 1
RCL 2
STO+1
RND
X=0
GTO 0
GSB E
RCL 3
X<>Y
STO 3
STO÷2
RCL 3
STOx2
GTO 1
LBL 0
RCL 1
RTN
LBL E
.// Use R1 for you unknow X
RTN
Gamo 6/22/2020
