Emulators / Simulators available as a library?
06-06-2019, 03:08 AM
Are any of the HP calculator emulators/simulators available in C or C++ library form - so that the core functionality (minus UI) could be easily invoked from another application?
I am experimenting with a general purpose system for program synthesis from examples and was thinking it would be fun to experiment with automatically generating programs for classic HP calculators (since I'm a fan). To minimize the work on my part (because I am lazy and have a real job) the easiest path to such an experiment would be to find an HP calculator "vm" in library form that I could adapt to provide the set of available operators to the program synthesis system.
Thanks in advance for any useful pointers.
06-06-2019, 07:23 PM
RE: Emulators / Simulators available as a library?
Maybe you could readapt the free42 and newRPL code. I am not sure they are meant as library so it is not a free lunch.
It i unlikely that you can access the code from the emulate ROM files as library, unless you go rewrite the emulator as interface for another program. Again, no free lunch.
06-06-2019, 08:09 PM
(06-06-2019 07:23 PM)pier4r Wrote:  Maybe you could readapt the free42 and newRPL code. I am not sure they are meant as library so it is not a free lunch.
Free42 isn't meant as a library, but all the "outside world" stuff goes through a bunch of "shell" functions implemented by whatever interface is being used.
— Ian Abbott
