Sort Lists API: A collection of sort functions
09-08-2018, 09:06 PM (This post was last modified: 09-15-2018 10:56 PM by StephenG1CMZ.)
A collection of Sort(List) functions (including some from the forum).
If you are looking for classic sorts (e.g. Bubble sort), look elsewhere (for now).
Stephen Lewkowicz (G1CMZ)
ANDROID HP Prime App broken offline on some mobiles
09-08-2018, 09:10 PM (This post was last modified: 09-27-2018 08:27 PM by StephenG1CMZ.)
RE: Sorts API: A collection of sort functions
Version 0.1 collects together the Sort functions previously contained in my List program (including Sortn from the forum), with minor implementation changes.
http://www.hpmuseum.org/forum/thread-9411.html
Requires List which should be compiled first.
Code
 LOCAL CRID:="Sorts API V0.1 © 2018 StephenG1CMZ";
 LOCAL MORETEXT:="A collection of sort routines brought to you by StephenG1CMZ,\n with some from the forum.";
 LOCAL MN:="Sorts.";//Name
 //IMPORT({List}); //Required
 LOCAL TYPELST:=TYPE({});
 LOCAL TYPEFLOAT:=TYPE(3.1);
 LOCAL TYPEINT:=TYPE(#3);
 LOCAL TYPESTR:=TYPE(" ");
 //Customise
 EXPORT SortableTypes:={TYPEFLOAT,TYPEINT,TYPESTR};
 LOCAL UNK0:=0;//EMPTY IS UNKNOWN,DEFAULT FALSE
 LOCAL UNK1:=1;//EMPTY IS UNKNOWN,DEFAULT TRUE
 //LOCAL SL:=1;
 //NB To test: sort >1 item
 //End
 //Forward
 IsSortablePortable(LST);
 SortL(LST);
 SortN(LST,NN);
 LOCAL NL:="\n";
 LOCAL ListANS;//OUTPUT LIST(WHEN NOT RETURNED)
 //ERR
 LOCAL ListErrK:=1;
 LOCAL PyErrK:=3;
 EXPORT ListLastError:=0;
 LOCAL ERRKIND:={"","Error","","Py Error"};
 EXPORT EL:={
  "(/0) DivideBy0",
  "IndexOutofBoundsException",
  "ListIsEmptyError",
  "ListIsFullError",
  "ListSortError",
  "ListStatisticsError",
  "ItemNotFoundError",
  "ValueError"
 //ERRNO IS ARBITRARY:INDEXES ERRLST
 EXPORT DivBy0Error:=1;
 LOCAL IndexOutOfBoundsException:=2;//List J
 EXPORT ListIsEmptyError:=3;
 LOCAL ListIsFullError:=4;//UNUSED YET
 LOCAL SortError:=5;
 EXPORT ListStatisticsError:=6;
 EXPORT ItemNotFoundError:=7;//List Py
 EXPORT ValueError:=8; // Py
 EXPORT ABOUT()
  MSGBOX(CRID);
  MSGBOX(MORETEXT);
 TBD()
  MSGBOX(MN+"TBD");
 EXPORT IsSortable(LST)
 //For now use Portable
 //Later: as SORT
  RETURN IsSortablePortable(LST);
 EXPORT IsSortablePortable(LST)
 //0.Is parameter a list
 //1.Is TYPE of contents OF ORDERABLE DATA
 //2.Is SORTL implemented on that type yet
 //NOTE:
 //IsSORTABLE({Real})=1 AND IsSORTABLE({INT})=1 AND IsSORTABLE({string})=1 but
 //do not assume SORT({mixed}) will deliver your expectations
 //NB The current algorithm reports {1,"4"} as sortable
 //But native sort wont
 //The Portable variant assumes strings and numerics are sortable.
  IF TYPE(LST)==TYPELST THEN
   IF SIZE(LST) THEN
    RETURN ListIsTYPE(LST,SortableTypes);
   RETURN UNK0;//EMPTY
  RETURN 0;//NOT LIST:CANNOT BE SORTED
 EXPORT IsSortedEQ(LST)
 //Tells whether a list is sorted...inefficiently
 //By sorting it and checking equality
 //(Useful for testing)
  ListANS:=SortL(LST);
  RETURN EQ(ListANS,LST);
 EXPORT IsSorted(LST)
 //Looping until 1st descending will/may be quicker TBD
  RETURN IsSortedEQ(LST);
 EXPORT SortByKey(SORTS,KeyNum)
 //Sort lists by list number KeyNum (with some input guards)
  IF 0<KeyNum≤SIZE(SORTS) THEN
   IF SIZE(SORTS)>1 AND SORTS(1)≠{} AND SORTS(2)≠{} THEN
    RETURN SortN(SORTS,KeyNum);
  ELSE
   //Potential:not all checked
   //List small, not containing lists, key out of range, key list unsortable
   RAISE(MN+"SortByKey",EL,SortError,KeyNum,ListErrK);
  RETURN SORTS;
 EXPORT SortByOccurrences(LST)
 //Returns {LSTV,LSTF} sorted by frequency of occurrence
 //reverse so most popular is 1st and index is approx rank
  TBD();
  //ListANS:=ListOCCURRENCES(LST);
  RETURN REVERSE(SortByKey(ListANS,2));
 EXPORT SortL(LST)
 //This implementation uses native SORT
  IF TYPE(LST)≠TYPELST THEN
   RAISE(MN+"SortL",EL,SortError,"",ListErrK);
  RETURN SORT(LST);
 EXPORT SortN(list,n)
 // From http://www.hpmuseum.org/forum/thread-6179.html?highlight=sort+two+lists
 //Call via ListSORTBYKEY to guard parameters...or call directly with good inputs
  LOCAL li,ma;
  ma:=list2mat(list) ;
  li:=SORT(MAKELIST(mat2list(col(ma,I)),I,1,colDim(ma)),n);
  RETURN MAKELIST(mat2list(col(list2mat(li),I)),I,1,rowDim(ma));
 //For example:
 //SORTN({{3,2,1},{15,20,18}},1);// -> {{1,2,3},{18,20,15}}
 //SORTN({{3,2,1},{15,20,18},{32,35,27}},1);// -> {{1,2,3},{18,20,15},{27,35,32}}
 EXPORT SortsVERSION()
  RETURN CRID;
 EXPORT Pyreverse(LST)
 //Python analogue
  RETURN REVERSE(LST);
EXPORT Pysort(LST,KeyFunc,RReverse)
 //Python analogue SORT
 //TBD: KeyFunc: Selects sort key from item
  IF TYPE(KeyFunc)==TYPEFLOAT AND KeyFunc==0 THEN
   //0=None=NO FUNC
  ELSE
   TBD();
   RAISE(MN+"Pysort",EL,ValueError,"",1);//TBD
  RETURN IFTE(RReverse,SORT(Pyreverse(LST)),SORT(LST));
EXPORT ListPuzzles()
 //SEE http://www.hpmuseum.org/forum/thread-8209.html?highlight=challenge
  LOCAL VR;
  LOCAL LST:=MAKELIST("",VR,1,5);//40
  LST(2):="31. ListOCCURRENCESWITHSORT";
  CHOOSE(VR,MN+"Puzzles (See thread)",LST);
EXPORT SortSeeAlso ()
  LOCAL KK;
  LOCAL CatFuns:={
   "REVERSE",
   "reverse",
   "revlist",
   "SORT",
   "sort"
  //Just Listed as a reminder:not Selectable
  CHOOSE(KK,MN+" Relevant Cat Functions",CatFuns)
 EXPORT SortsExamples()
 //In real use, use XXX:=Sort...()
  LOCAL LL:={1,2,3,4,5,6,7,8,9};
  PRINT();
  PRINT(SortsVERSION);
  PRINT("Is");
  PRINT(IsSortable(0));
  PRINT(IsSortable({}));
  PRINT(IsSortable(LL));
  //PRINT(IsSortable(LL+{3.1}));
  PRINT(IsSorted(LL));
  //PRINT(ListIsTYPE({3.4},1-1));
  PRINT("Sort");
  //SortByABS
  //SortByKey
  //SortByOccurrences
  //TBD PRINT(SortByOccurrences({1,2,2,3,3,3}));
  //SortL
  PRINT(SortL(LL));
  //SortN
  PRINT(SortN({{3,2,1},{15,20,18}},1));// -> {{1,2,3},{18,20,15}}
  PRINT(SortN({{3,2,1},{15,20,18},{32,35,27}},1));// -> {{1,2,3},{18,20,15},{27,35,32}}
  PRINT("Exampled");
  //RETURN 0;
 EXPORT SORTS()
  ABOUT();
  //SortExamples();
Version 0.2 is reworked to minimise the need for my "List" program.
I had hoped it would now only be needed for error handling, but in fact there is still a dependency on ListIsTYPE too..
New routines ReverseLOL, SortByCount, SortByABS.
 LOCAL CRID:="Sorts API V0.2 © 2018 StephenG1CMZ";
 //Also includes REVERSE functions
 //IMPORT({List}); //for error handling
 //Customise
 //LOCAL SL:=1;
 //End
 //Forward
 SortByKeyTBD(SORTS,Keynum);
 SortL(LST);
 SortN(LST,NN);
 LOCAL NL:="\n";
 //ERR
 LOCAL ListErrK:=1;
 LOCAL PyErrK:=3;
 EXPORT EL:={
  "(/0) DivideBy0",
  "ListIsEmptyError",
  "ListIsFullError",
  "ListSortError",
  "ValueError"
 LOCAL SortError:=5;
 EXPORT ABOUT()
  MSGBOX(CRID);
  MSGBOX(MORETEXT);
 TBD()
  MSGBOX(MN+"TBD");
 //Later: as native SORT
 //NOTE:
   IF SIZE(LST) THEN
   RETURN UNK0;//EMPTY
 EXPORT ReverseLOL(LSTS)
 //Reverse a list of lists
 //EG {{1,2},{3,4}} -> {{2,1},{4,3}}
 //NONRECURSIVE:TOP LISTS ONLY
 //ALL LISTS MUST BE REVERSIBLE
  LOCAL II;
  ListANS:={};
  IF SIZE(LSTS) THEN
   //REVERSE EACH LST
   FOR II FROM 1 TO SIZE(LSTS) DO
    ListANS(II):=REVERSE(LSTS(II));
   END;//FOR
  RETURN ListANS;
 EXPORT SortByABS(LST)
  LOCAL TMP:={};
  IF SIZE(LST) THEN
   TMP:=SortN({ABS(LST),SIGN(LST)},1);
   RETURN TMP(1)*TMP(2);
  RETURN {};
 EXPORT SortByCount(LSTS,Keynum)
 //LSTS is {LSTV,LSTF} as returned by
 //ListOCCURRENCES(LST);
 //but additional fields are allowed
 //EG {{1,2,3},{10,30,20}} -> {{2,3,1},{10,20,30}}
   IF SIZE(LSTS)≥Keynum THEN
    IF SIZE(LSTS(1))>1 AND SIZE(LSTS(Keynum))>1 THEN
     RETURN SortN(LSTS,K);
  RETURN {};
  //To reverse sequence call ReverseLOLS()
 //These routines are similar
 //Why does one fail TBD
 EXPORT SortByKeyTBD(LSTS,KeyNum)
 //Hint: If this gives a data type error call SORTN directly (WHY?)
  IF 0<KeyNum≤SIZE(LSTS) AND SIZE(LSTS)>1 THEN
   IF LSTS(1)≠{} AND LSTS(2)≠{} THEN
    RETURN SortN(LSTS,KeyNum);
  ELSE
  RETURN {};
 EXPORT SortL(LST)
  RETURN SORT(LST);
  LOCAL li,ma;
 //For example:
  RETURN CRID;
 //Python analogue
   //0=None=NO FUNC
  ELSE
   TBD();
  LOCAL VR;
  LOCAL KK;
  LOCAL CatFuns:={
   "REVERSE",
   "reverse",
   "revlist (slower)",
   "SORT",
   "sort"
  PRINT();
  PRINT("Is");
  PRINT(IsSortablePortable(LL));
  PRINT(IsSortedEQ(LL));
  PRINT("Reverse");
  PRINT(ReverseLOL({{1,2},{3,4},{5,6}}));
  PRINT("Sort");
  //SortByABS
  PRINT(SortByABS({1,2,3,−2})); // -> {1,2,−2,3}
  //SortByCount
  PRINT(SortByCount({{1,2,3},{10,30,20}},2)); // -> {{2,3,1},{10,20,30}}
  //SortByKey
  //SortL
  PRINT(SortL(LL));
  //SortN
  //SortByOccurrences
  PRINT(SortByCount({{1,2,3},{1,22,3}},2));
  PRINT(ReverseLOL(SortByCount({{1,2,3},{1,22,3}},2)));
  PRINT("Py");
  PRINT(Pyreverse({1,2,3}));
  PRINT(Pysort({1,22,3},0,0));
  PRINT("Exampled");
  //RETURN 0;
 EXPORT SORTS()
  ABOUT();
  //SortExamples();
09-15-2018, 10:52 PM (This post was last modified: 09-15-2018 10:55 PM by StephenG1CMZ.)
RE: Sort Lists API: A collection of sort functions
Version 0.3 now implements Pysort and fixes some bugs.
 LOCAL CRID:="SortL API V0.3 © 2018 StephenG1CMZ";
 LOCAL MORETEXT:="A collection of Sort(List) routines brought to you by StephenG1CMZ,\n with some from the forum.";
 LOCAL MN:="SortL.";//Name
 //Customise
 //LOCAL SL:=1;
 //End
 //Forward
 SortByKey(SORTL,Keynum);
 SortByKeyTBD(SORTL,Keynum);
 SortLST(LST);
 SortN(LST,NN);
 LOCAL NL:="\n";
 //ERR
 LOCAL ListErrK:=1;
 LOCAL PyErrK:=3;
 EXPORT EL:={
  "(/0) DivideBy0",
  "ListIsEmptyError",
  "ListIsFullError",
  "ListSortError",
  "ValueError"
 LOCAL SortError:=5;
 EXPORT ABOUT()
  MSGBOX(CRID);
  MSGBOX(MORETEXT);
 TBD()
  MSGBOX(MN+"TBD");
EXPORT RAISE(MN,ERRLST,ERR,CULPRIT,SEVERITY)
 //NOTE:
   IF SIZE(LST) THEN
   RETURN UNK0;//EMPTY
  ListANS:=SortLST(LST);
 //NONRECURSIVE:2ND LEVEL LISTS ONLY
  LOCAL II;
  ListANS:={};
  IF SIZE(LSTS) THEN
   //REVERSE EACH LST
   END;//FOR
  RETURN ListANS;
  LOCAL TMP:={};
  IF SIZE(LST) THEN
  RETURN {};
 //The following could return just the valuesO
 //or Values and counts in 2 lists
 //Whichis preferred?
 EXPORT SortByCounts(LST)
  ListANS:=ListCOUNTS(LST);//To omit this step, use SortByKey directly
  RETURN SortByKey(ListANS,2);
 EXPORT SortByKey(LSTS,Keynum)
 //ListCOUNTS(LST);
  RETURN {};
  ELSE
  RETURN {};
 EXPORT SortLST(LST)
  RETURN SORT(LST);
  LOCAL li,ma;
 //For example:
  RETURN CRID;
 //Python analogue
 //PyOpt KeyFunc: STRING EG "ABS" (NULL=NONE)
 //PyOpt PRReverse BOOL
  LOCAL TMP;
  IF KeyFunc=="" THEN
   ListANS:=SORT(LST);
   RETURN IFTE(RReverse,Pyreverse(ListANS),ListANS);
  TMP:=EXPR(KeyFunc+"(LST)");
  ListANS:=SortN({LST,TMP},2);
  RETURN IFTE(RReverse,Pyreverse(ListANS(1)),ListANS(1));
  LOCAL VR;
  LOCAL KK;
  LOCAL CatFuns:={
   "REVERSE",
   "reverse",
   "revlist (slower)",
   "SORT",
   "sort"
  PRINT();
  PRINT("Is");
  PRINT("Reverse");
  PRINT("Sort");
  //SortByABS
  //SortByCounts
  PRINT(SortByCounts({1,2,3,2,3,3})); // -> {{1,2,3},{1,2,3}}
  //SortByKey
  PRINT(SortByKey({{1,2,3},{10,30,20}},2)); //-> {{1,3,2},{10,20,30}}
  PRINT(SortByKey({{1,2,3},{1,22,3}},2));
  PRINT(ReverseLOL(SortByKey({{1,2,3},{1,22,3}},2)));
  //SortL
  PRINT(SortLST(LL));
  //SortN
  PRINT("Py");
  PRINT(Pysort({1,22,3},"",0));
  PRINT(Pysort({1,22,3},"ABS",0));
  PRINT("Exampled");
  //RETURN 0;
 EXPORT SORTL()
  ABOUT();
  //SortExamples();
09-27-2018, 09:19 PM (This post was last modified: 09-27-2018 09:25 PM by StephenG1CMZ.)
Version 0.4C implements IsSortableNative to track the functionality of the native SORT.
Some functions are unexported to minimise global effects.
(0.4C Corrects minor errors in 0.4,0.4A and 0.4B)
LOCAL CRID:="SortL API V0.4C © 2018 StephenG1CMZ";
 //NB REVERSE REVERSES A LIST (WHICH MIGHT HAVE BEEN SORTED)
 //(IT DOES NOT OF ITSELF REVERSE-SORT DESPITE BEING IN THIS SORTL PROGRAM)
 //Some exportables (ex) omitted to minimise global impact
 //Customise
 EXPORT SortableNumericTypes:={TYPEFLOAT,TYPEINT};
 //LOCAL SL:=1;
 //End
 //Forward
 SortLST(LST);
 SortN(LST,NN);
 LOCAL NL:="\n";
 //ERR
 LOCAL ListErrK:=1;
 LOCAL PyErrK:=3;
 EXPORT EL:={
  "(/0) DivideBy0",
  "ListIsEmptyError",
  "ListIsFullError",
  "ListSortError",
  "ValueError"
 LOCAL SortError:=5;
 EXPORT ABOUT()
  MSGBOX(CRID);
  MSGBOX(MORETEXT);
 TBD()
  MSGBOX(MN+"TBD");
 IsSortable(LST) //ex
 EXPORT IsSortableNative(LST)
 //Checks whether the contents of LST are natively sortable
 //Returns 1 TYPESTR only
 //Returns 1 SortableNumeric
 //NB Lists and keys can be sorted but lists alone no
  LOCAL TP;
  IF SIZE(LST) THEN
   TP:=TYPE(LST(1));
   CASE
    IF TP==TYPESTR THEN
     RETURN ListIsTYPE(LST,TYPESTR);
    IF POS(SortableNumericTypes,TP) THEN
     RETURN ListIsTYPE(LST,SortableNumericTypes);
    DEFAULT
     RETURN 0;//UNSORTABLE
   END;//CASE
  RETURN 1;//EMPTY INDETERMINATE
 //NOTE:
  LOCAL SortableTypes:=CONCAT(SortableNumericTypes,TYPESTR);
   IF SIZE(LST) THEN
   RETURN UNK0;//EMPTY
 IsSortedEQ(LST) //EX
  LOCAL II;
  ListANS:={};
  IF SIZE(LSTS) THEN
   //REVERSE EACH LST
   END;//FOR
  RETURN ListANS;
 //Return SORTEDL
 //Note that integers return floats
  LOCAL TMP:={};
  IF SIZE(LST) THEN
  RETURN {};
 //Return {SORTEDL,SORTEDCOUNTS}
 EXPORT SortByKeyLST(LST,KEYLST)
 //Sort LST using KEYLST
 //LST must be sortable. LOL will fail.
 //Return {SORTEDL,SORTEDKEYLST}
  IF SIZE(LST) AND SIZE(KEYLST) THEN
   RETURN SortN({LST,KEYLST},2);
  RETURN {};
 EXPORT SortByKeyNUM(LSTS,Keynum)
 //ListCOUNTS(LST);
 //Returns {SORTED,LSTF} sorted by sort key criteria
 //BUG:ONLY SORTS TWO LISTS,
 //BUT CALLING SortN direcLy works
     RETURN SortN(LSTS,Keynum);
  RETURN {};
  ELSE
  RETURN {};
 EXPORT SortLST(LST) //ex
 //It is convenient to export when comparing with other sorts
  RETURN SORT(LST);
  LOCAL li,ma;
 //For example:
 SortsVERSION() //ex
  RETURN CRID;
 Pyreverse(LST) //ex
 //Python analogue
  LOCAL TMP;
  IF KeyFunc=="" THEN
   ListANS:=SORT(LST);
 ListPuzzles() //EX
  LOCAL VR;
EXPORT SortSeeAlso () //ex
  LOCAL KK;
  LOCAL CatFuns:={
   "REVERSE",
   "reverse",
   "revlist (slower)",
   "SORT",
   "sort"
 EXPORT SortsExamples() //ex
  PRINT();
  PRINT("Is");
  PRINT("Reverse");
  PRINT("Sort");
  //SortByABS
  //SortByCounts
  //SortByKey
  PRINT(SortByKeyNUM({{1,2,3},{10,30,20}},2)); //-> {{1,3,2},{10,20,30}}
  PRINT(SortByKeyNUM({{1,2,3},{1,22,3}},2));
  PRINT(ReverseLOL(SortByKeyNUM({{1,2,3},{1,22,3}},2)));
  //SortL
  PRINT(SortLST(LL));
  //SortN
  PRINT("Py");
  PRINT("Exampled");
  //RETURN 0;
 EXPORT SORTL()
  LOCAL LST:={};
  ABOUT();
  //SortExamples();
12-03-2019, 11:42 PM (This post was last modified: 12-03-2019 11:47 PM by StephenG1CMZ.)
Version 0.5 implements SortByFun in response to
https://www.hpmuseum.org/forum/thread-6179.html
LOCAL CRID:="SortL API V0.5 © 2019 StephenG1CMZ";
 //IMPORT({PPLX});
 //Customise
 EXPORT SortableNumericTypes:={TYPEREAL,TYPEINT};
 //LOCAL SL:=1;
 //End
 //Forward
 SortLST(LST);
 SortN(LST,NN);
 LOCAL NL:="\n";
 //ERR
 LOCAL ListErrK:=1;
 LOCAL PyErrK:=3;
 EXPORT EL:={
  "(/0) DivideBy0",
  "ListIsEmptyError",
  "ListIsFullError",
  "ListSortError",
  "ValueError"
 LOCAL SortError:=5;
 EXPORT ABOUT()
  MSGBOX(CRID);
  MSGBOX(MORETEXT);
 TBD()
  MSGBOX(MN+"TBD");
  LOCAL TP;
  IF SIZE(LST) THEN
   TP:=TYPE(LST(1));
   CASE
    IF TP==TYPESTR THEN
    DEFAULT
   END;//CASE
  RETURN UNK1;//EMPTY INDETERMINATE
 //NOTE:
   IF SIZE(LST) THEN
   RETURN UNK0;//EMPTY
  LOCAL II;
  ListANS:={};
  IF SIZE(LSTS) THEN
   //REVERSE EACH LST
   END;//FOR
  RETURN ListANS;
 //Return LST SORTED BY ABS VALUE
 //Note that #integers return floats
 //ALT: USE SortByFun(LST,ABS(LST))
 //SortByABS is quicker
  LOCAL TMP:={};
  IF SIZE(LST) THEN
  RETURN {};
 EXPORT SortByFun(LST,SortFun)
 //Sort using SortFun as your sort function
 //EG SortByFun(LST,ABS(LST)) //BUT SortByABS is faster (Again #integers return floats)
 //EG SortByFun(LST,MYSORTFUN(LST[,ITEM]))
 //Note: The function name alone is not sufficient
 //See https://www.hpmuseum.org/forum/thread-6179.html for alternative CAS syntaxes
 //ALT: Use Pysort("fun")
  LOCAL SORTORDER;
  LOCAL SORTED:={{},{}};//GUARD EMPTY LIST
  IF SIZE(LST) THEN
   SORTORDER:=SortFun;
   SORTED:=Sortn({LST,SORTORDER},2);
  RETURN SORTED(1); //TO SEE THE SORT ORDER INSTEAD:2
  RETURN {};
 //ListCOUNTS(LST);
  RETURN {};
  ELSE
  RETURN {};
  RETURN SORT(LST);
  LOCAL li,ma;
 //For example:
 SortsVERSION() //ex
  RETURN CRID;
 Pyreverse(LST) //ex
 //Python analogue
 //ALT: Use SortByFun(LST,Fun(LST...))
 //Note: The Py syntax is optional fun without strings
 //Using strings here allows optional null string to be handled
 //The alt SortByFun avoids strings but requires a function
  LOCAL TMP;
  IF KeyFunc=="" THEN
   ListANS:=SORT(LST);
 ListPuzzles() //EX
  LOCAL VR;
  LOCAL KK;
  LOCAL CatFuns:={
   "REVERSE",
   "reverse",
   "revlist (slower)",
   "SORT",
   "sort"
  PRINT();
  PRINT("Is");
  PRINT("Reverse");
  PRINT("Sort");
  //SortByABS
  //SortByCounts
  //SortByKey
  //SortL
  PRINT(SortLST(LL));
  //SortN
  PRINT("Py");
  PRINT("Exampled");
  //RETURN 0;
 EXPORT SORTL()
  LOCAL LST:={};
  ABOUT();
  //SortExamples();
12-06-2019, 12:21 AM (This post was last modified: 12-06-2019 12:25 AM by StephenG1CMZ.)
Version 0.6 implements
SortFromItem: Sort by sort distance from an item
and
SortFromItems: Sort by minimum sort distance from a list of items.
The sort distance is a simple ABS(LST-MIN(Items)).
 LOCAL CRID:="SortL API V0.6 © 2019 StephenG1CMZ";
 //Dictionary
 //ITEM: an element of a list (or a value which could be in a list)
 //ITEMS: a list of 0..n ITEMs
 //LOL or LSTS: List Of lists EG {{1,2},{3,4}}
 //REVERSE: reverses a list (i.e. to reverse-Sort do REVERSE(SORT()) )
 //All lists may be empty (except: SortN)
 //IMPORT({PPLX}); //TYPE
 //Customise
 //LOCAL SL:=1;
 //End Custom
 //Forward
 SortLST(LST);
 SortN(LST,NN);
 LOCAL NL:="\n";
 //ERR
 LOCAL ListErrK:=1;
 LOCAL PyErrK:=3;
 EXPORT EL:={
  "(/0) DivideBy0",
  "ListIsEmptyError",
  "ListIsFullError",
  "ListSortError",
  "ValueError"
 LOCAL SortError:=5;
 EXPORT ABOUT()
  MSGBOX(CRID);
  MSGBOX(MORETEXT);
 TBD()
  MSGBOX(MN+"TBD");
  LOCAL TP;
  IF SIZE(LST) THEN
   TP:=TYPE(LST(1));
   CASE
    IF TP==TYPESTR THEN
    DEFAULT
   END;//CASE
 //NOTE:
   IF SIZE(LST) THEN
   RETURN UNK0;//EMPTY
  LOCAL II;
  ListANS:={};
  IF SIZE(LSTS) THEN
   //REVERSE EACH LST
   END;//FOR
  RETURN ListANS;
  LOCAL TMP:={};
  IF SIZE(LST) THEN
  RETURN {};
  LOCAL SORTORDER;
  IF SIZE(LST) THEN
   SORTORDER:=SortFun;
  RETURN {};
 //ListCOUNTS(LST);
  RETURN {};
  ELSE
  RETURN {};
 EXPORT SortFromItem(LST,ITEM)
  //Return simple sort distance
  //Return LST SORTED BY NUMERICAL ABS VALUE FROM ITEM
  //=SortFromItems(LST,{ITEM})
  //ALT: USE SortByFun(LST,MYSORTFUN(LST...))
  LOCAL TMP:={};
  IF SIZE(LST) THEN
   TMP:=SortByFun(LST,ABS(LST-ITEM));
  RETURN TMP;
 EXPORT SortFromItems(LST,ITEMS)
 //Sort by min sort distance from a list of items
 //#integers return floats
 //EMPTY LISTS: RETURN EMPTY LIST
 // (or: perhaps empty ITEMS should simply SORT(LST)?)
  LOCAL DX:={};
  LOCAL TMP:={{},{}};
  LOCAL II;
  IF SIZE(LST) AND SIZE(ITEMS) THEN
   //IF SIZE(ITEMS)==1 THEN //OPTIONAL OPTIMISE
   // RETURN SortFromItem(LST,ITEMS(1));
   //END;
   //DX:=sort distance from nearest ITEM
   DX:=MAKELIST(MIN(ABS(LST(II)-ITEMS)),II,1,SIZE(LST));
   TMP:=SortN({LST,DX},2);
  //PRINT(TMP);
  RETURN TMP(1);
  RETURN SORT(LST);
  LOCAL li,ma;
 //For example:
 SortsVERSION() //ex
  RETURN CRID;
 Pyreverse(LST) //ex
 //Python analogue
  LOCAL TMP;
  IF KeyFunc=="" THEN
   ListANS:=SORT(LST);
 ListPuzzles() //EX
  LOCAL VR;
  LOCAL KK;
  LOCAL CatFuns:={
   "REVERSE",
   "reverse",
   "revlist (slower)",
   "SORT",
   "sort"
 EXAMPLESORTFROM()
 //EG DISTANCE FROM FIRST AID POSTS AT 5 mile intervals along a half marathon
  LOCAL ITEMS:={0,5,10};//FIRST AID POSTS
  //LOCAL LST:={10,5,−20,−5,20,−10};
  LOCAL LST:={1,2,3,4,5,6,7,8,9,10,11,12,13};
  LOCAL OUTLST;
  PRINT();
  PRINT(OUTLST:=SortFromItems(LST,ITEMS));//CLOSEST LISTED FIRST
  PRINT();
  PRINT("Is");
  PRINT("Reverse");
  PRINT("Sort");
  //SortByABS
  //SortByCounts
  //SortByKey
  //SortL
  PRINT(SortLST(LL));
  //SortN
  PRINT("Py");
  PRINT("Exampled");
  //RETURN 0;
 EXPORT SORTL()
  LOCAL LST:={};
  ABOUT();
  //SortExamples();
12-11-2019, 07:24 PM (This post was last modified: 12-11-2019 07:26 PM by StephenG1CMZ.)
Version 0.7
SortByKey functions rewritten
SortByIndex implemented
 LOCAL CRID:="SortL API V0.7 © 2019 StephenG1CMZ";
 //Dictionary
 //KEYLST: sorting this sorts your other list(s)
 //LST: a list
 //LOL or LSTS: List Of lists EG {{1,2},{3,4}} (just {{1,2}} may be OK)
 //Customise
 //LOCAL SL:=1;
 //End Custom
 //Forward
 SortLST(LST);
 SortN(LST,NN);
 LOCAL NL:="\n";
 //ERR
 LOCAL ListErrK:=1;
 LOCAL PyErrK:=3;
 EXPORT EL:={
  "(/0) DivideBy0",
  "ListIsEmptyError",
  "ListIsFullError",
  "ListSortError",
  "ValueError"
 LOCAL SortError:=5;
 EXPORT ABOUT()
  MSGBOX(CRID);
  MSGBOX(MORETEXT);
 TBD()
  MSGBOX(MN+"TBD");
  LOCAL TP;
  IF SIZE(LST) THEN
   TP:=TYPE(LST(1));
   CASE
    IF TP==TYPESTR THEN
    DEFAULT
   END;//CASE
 //NOTE:
   IF SIZE(LST) THEN
   RETURN UNK0;//EMPTY
  LOCAL II;
  ListANS:={};
  IF SIZE(LSTS) THEN
   //REVERSE EACH LST
   END;//FOR
  RETURN ListANS;
  LOCAL TMP:={};
  IF SIZE(LST) THEN
  RETURN {};
  LOCAL SORTORDER;
  IF SIZE(LST) THEN
   SORTORDER:=SortFun;
   SORTED:=SortN({LST,SORTORDER},2);
 EXPORT SortByIndex(LST,XLST)
 //Return the indexes from LST specified by XLST
 //A partial list is valid, as are repetitions
 //An entry in XLST > SIZE(LST) could be checked 1st
  LOCAL II;
  LOCAL TMP:={0};
  IF SIZE(LST) AND SIZE(XLST) THEN
   //To improve speed omit test
   //Hint: Check this 1st before calling this routine multiple times
   // when you have several similar lists
   //TMP:=MAKELIST((XLST(II)>SIZE(LST)),II,1,SIZE(XLST));//OPTIONAL TEST
   //IF ΣLIST(TMP)THEN
   // RAISE(MN+"SortByIndex",EL,SortError,ΣLIST(TMP),ListErrK);
   //ELSE
    RETURN MAKELIST(LST(XLST(II)),II,1,SIZE(XLST));
   //END;
  RETURN {};
 //Sort 1 LST using KEYLST.
 //KEYLST will be sorted to determine how to sort LST
 //Cf: SortByKey({LST},KEYLST)
  LOCAL TMP;
   TMP:=SortN({LST,KEYLST},2);
   //Make Customisable?
   //One will match SortByKey({LST},KEYLST)
   RETURN TMP;    // {SORTEDLST,SORTEDKEYLST}
   RETURN TMP(1); // SORTEDLST
  RETURN {};
 SortByKeyLSTS(LSTS,KEYLST)
 //Sort LSTS using KEYLST to order.
 //Return: SORTEDLSTS
 //If KEYLST exists within LSTS use: SortByKeyNUM(LSTS,N)
  LOCAL TMP;
  IF SIZE(LSTS) AND SIZE(KEYLST) THEN
   LSTS(0):=KEYLST;
   TMP:= SortN(LSTS,SIZE(LSTS));
   RETURN ListBEFORE(TMP,SIZE(TMP));
  RETURN {};
 //ListCOUNTS(LST);
 //Returns {SORTED LSTS} sorted by sort key criteria
 //EG ({{1,2,3},{10,30,20}},2) -> {{2,3,1},{10,20,30}}
   IF 0<Keynum≤SIZE(LSTS) THEN
    IF SIZE(LSTS(1)) AND SIZE(LSTS(Keynum)) THEN
     //Strictly all are lists of same size
   //Potential errors:not all checked
   RAISE(MN+"SortByKey",EL,SortError,Keynum,ListErrK);
   RETURN {};
 EXPORT SortByKey(LSTS,KEY)
 //Sort LSTS by KEY
 //EG (LSTS,2) OR (LSTS,{6,5}) WHERE LSTS={{1,2},{3,4}}
  CASE
   IF TYPE(KEY)==TYPELST THEN SortByKeyLSTS(LSTS,KEY) END;
   DEFAULT //numeric KEY param
    SortByKeyNUM(LSTS,KEY);
  LOCAL TMP:={};
  IF SIZE(LST) THEN
  RETURN TMP;
  LOCAL DX:={};
  LOCAL TMP:={{},{}};
  LOCAL II;
   //END;
  RETURN TMP(1);
 SortLST(LST) //ex
   RAISE(MN+"SortLST",EL,SortError,"",ListErrK);
   RETURN {};
  RETURN SORT(LST);
  LOCAL li,ma;
 //For example:
 SortsVERSION() //ex
  RETURN CRID;
 Pyreverse(LST) //ex
 //Python analogue
  LOCAL TMP;
  IF KeyFunc=="" THEN
   ListANS:=SORT(LST);
 ListPuzzles() //EX
  LOCAL VR;
  LOCAL KK;
  LOCAL CatFuns:={
   "REVERSE",
   "reverse",
   "revlist (slower)",
   "SORT",
   "sort"
 EXAMPLESORTFROM()
  LOCAL OUTLST;
  PRINT();
  PRINT();
  PRINT("Is");
  PRINT("Reverse");
  PRINT("Sort");
  //SortByABS
  //SortByCounts
  //SortByKey
  //SortL
  PRINT(SortLST(LL));
  //SortN
  PRINT("Py");
  PRINT("Exampled");
  //RETURN 0;
 EXPORT SORTL()
  LOCAL LST:={};
  ABOUT();
  //SortExamples();
