(35S) Backward-Forward Sweep Feeder Voltage And Current Computation
03-19-2018, 08:34 AM (This post was last modified: 07-17-2018 07:18 AM by gerry_in_polo.)
Computes the per-unit node voltages and segment currents of a radial electric primary distribution feeder assuming a typical sectionalizing scheme of two normally-close (sectionalizing) and one normally-open (tying) line switches resulting in three feeder segments/load nodes approximation. The program iteratively computes for the voltages and currents using the Backward-Forward Sweep algorithm.
Attached File(s)
.pdf  Backward-Forward Sweep Loaflow Program (HP-35s, Gerardo V Lozada, 2018-03-18).pdf (Size: 59.64 KB / Downloads: 28)
