(HP71B) Newton's method
10-01-2023, 03:59 PM
Inspired by Csaba Tizedes videos about Newton's method
(09-23-2023 05:19 PM)Csaba Tizedes Wrote: https://www.youtube.com/shorts/1R3IMq227dM (09-23-2023 05:21 PM)Csaba Tizedes Wrote: Same, without d/dx() f'(x) ≈ (f(x+ε) - f(x-ε)) / (2ε) → f/f' needed 3 function calls per iteration. We may reduce this to about 2 calls per iteration. Redo same example in HP71B, for full convergence. Quote:1 DESTROY ALL @ C=0 >RUN Guess, Accuracy = 10, 1e-6 10 7.85714477037 6.29727032561 5.20041359757 4.4911553721 4.12133235435 4.00984649554 4.00007201239 4.00000000386 4 FNF calls = 19 For comparison, this is using video's formula for Newton's correction. There is no gain in rate of convergence ... just more function calls. >50 D = FNF(X)*R >60 C = C+3 >RUN Guess, Accuracy = 10, 1e-6 10 7.8571447704 6.29727032563 5.20041359761 4.49115522316 4.12133220071 4.00984642245 4.0000719974 4.00000000388 4 FNF calls = 27 |
10-01-2023, 04:34 PM
RE: (HP71B) Newton's method
Previous HP71B code had a hard-coded absolute epsilon. (line 20)
It may be safer to use relative epsilon instead, in case x±ε round back to x >20 E=(ABS(X)+(X==0))*1E-3 Let's try example from thread, Namir, Byte and REXX, which also does 3 calls per iteration. (09-10-2018 01:26 PM)Massimo Gnerucci Wrote: D:\ReginaREXX391w64>regina.exe root.rex >2 DEF FNF(X)=2*X^2+3*X-12 >RUN Guess, Accuracy = 5, 1e-6 5 2.69565 1.92511161178 1.81413944914 1.81173817456 1.81173769148 FNF calls = 11 True root = (sqrt(105)-3)/4 = 1.8117376914898995958... |
10-01-2023, 09:47 PM
(This post was last modified: 10-02-2023 02:59 PM by Albert Chan.)
(09-23-2023 09:46 AM)carey Wrote: The simple looking transcendental equation, e^-x = x, is unsolvable in closed form (try it!) Newton form of x = f(x): 0 = (f - x) x = x - (f - x) / (f' - 1) = (x*f' - f) / (f' - 1) = (x - f/f') / (1 - 1/f') W(b=1) example, newton iteration formula: x = (x + 1) / (1 + e^x/b) This setup is nice, with denominator > 0, if b > -1/e = -0.36787944... Even crazy guess work. For W(b=1): ∞ --> 0 --> 0.5 --> 0.5663 --> ... > 2 B=1 @ DEF FNF(X)=B*EXP(-X)-X ! root = W(B) > RUN Guess, Accuracy = B, 1E-6 1 .537882997929 .566987045872 .567143290413 .56714329041 FNF calls = 10 Interestingly, crazy guess of 1e499 cost only 1 extra FNF call. Note: this work only with previous post relative epsilon patch. |
10-02-2023, 04:04 PM
(This post was last modified: 10-03-2023 12:29 AM by Albert Chan.)
(10-01-2023 09:47 PM)Albert Chan Wrote: W(b=1) example, newton iteration formula: x = (x + 1) / (1 + e^x/b) Because of e^x term in denominator, this setup is not good for W(huge b) Convegence is slow and inaccurate, even with good guess. >2 B=1E10 @ DEF FNF(X)=B*EXP(-X)-X ! root = W(B) >RUN Guess, Accuracy = LN(B), RES*1E-6 23.0258509299 12.0135445721 13.0133779957 14.0128061672 15.0110431755 16.005828047 16.9907276945 17.9478731089 18.8306249224 19.5363990109 19.9283981583 20.0242147693 20.0286862103 20.0286854427 FNF calls = 28 >X*EXP(X) ! expected to be close to B 10000000308.6 It is better is to setup Newton formula with less curvy f (e^-x is as bad as e^x) x * e^x = b ln(x) + x = ln(b) x = f(x) → f = ln(b) - ln(x) → f' = -1/x Newton: x = (x - f/f') / (1 - 1/f') = (1 + ln(b/x)) / (1 + 1/x) >2 B=1E10 @ DEF FNF(X)=LN(X/B)+X ! root = W(B) >RUN Guess, Accuracy = LN(B), RES*1E-6 23.0258509299 20.0197856819 20.0286854133 20.0286854133 FNF calls = 8 >X*EXP(X) ! very close to B. no other 12-digits X can get closer! 9999999999.95 |
