HP-41 / DM-41X / HP-41CL -> Page 6 and Page 7 friendly rom summary thread
06-08-2022, 10:43 PM
(This post was last modified: 06-09-2022 11:06 AM by Gene.)
If a thread for this already exists, point it out and I'll remove this one. Glad to summarize any posts below into this first post. My list below is ** not ** meant to be remotely complete.
Help me make this more complete. Page 6 friendly ROMs ----------------------- HP41 Printer and IR printer PowerCL OSX-BS4 Hepax (all versions) Page 7 friendly ROMs ----------------------- HP-IL Y-Functions OSX-BS4 Warp PowerCL Hepax (all versions) |
06-09-2022, 07:41 AM
(This post was last modified: 06-09-2022 07:42 AM by Ángel Martin.)
RE: HP-41 / DM-41X / HP-41CL -> Page 6 and Page 7 friendly rom summary thread
(06-08-2022 10:43 PM)Gene Wrote: Page 6 friendly ROMs Good topic/ My inputs are: Add HEPAX (all versions) to both page#6 and page#7 Add PowerCL to Page #7 "To live or die by your own sword one must first learn to wield it aptly." |
06-09-2022, 04:26 PM
Is it worth noting what may be obvious…?
i.e. that the printer/IR printer module will be p6 if used, and HP-IL p7 if used, so don't put the other modules above in those ports if you want to use printing or HP-IL? Or perhaps that is too obvious, if so please ignore? It would not have been obvious to me, once Cambridge, UK 41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot Casio, Rockwell 18R |
06-09-2022, 05:09 PM
(06-09-2022 04:26 PM)cdmackay Wrote: Is it worth noting what may be obvious…? P7, on the DM41X, comes for free. For now? Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
06-09-2022, 05:14 PM
If I remember correct almost any ROM is page 7 safe. As far as I know there are no fixed entries used by the HP41 OS, which is the case for the P6 printer functions. I have plugged loads of things in P7 without any issue.
And do not forget that a disabled HP-IL printer is not friendly to anything that is in page 4 (LIB 4 specifically). Regards, Meindert |
06-09-2022, 06:01 PM
(06-09-2022 05:14 PM)MeindertKuipers Wrote: If I remember correct almost any ROM is page 7 safe. As far as I know there are no fixed entries used by the HP41 OS, which is the case for the P6 printer functions. I have plugged loads of things in P7 without any issue. I agree, but for most platforms and modules, there is no way to load them into Page-7, so listing them there would likely lead to confusion and lots of questions from non-power users... e.g. "It says I can load any module I want into Page-7; how do I do that, since all the others are full?" --Bob Prosperi |
06-09-2022, 10:08 PM
I ** think ** P7 is completely free and available for a non-bank-switched (?) rom on the DM-41X.
P7 is also completely free on the 41CL ** if ** no HP-IL is going to be used. P6 is free if no printer is going to be used. Can P6 use bank-switched roms if available and no printer is in the picture? Can P7 use bank switched roms if available and no IL is in the picture? Example: I suspect Sandmath is no something to pop into P6 or P7 even if no printer or IL is going to be used... or can it ? |
06-09-2022, 11:07 PM
RE: HP-41 / DM-41X / HP-41CL -> Page 6 and Page 7 friendly rom summary thread | |||
06-10-2022, 02:12 PM
(This post was last modified: 06-10-2022 02:14 PM by Chr Yoko.)
Nice subject !
=> P7 is used by the HP-IL ROM. But if i use/plug an HP-IL Printer , is the P6 will still be free ? |
06-10-2022, 03:35 PM
(06-10-2022 02:12 PM)Chr Yoko Wrote: Nice subject ! If you plug the physical HP-IL module then P6 is automatically used by the HP-IL printer module. If you disable the HP-IL printer (the little switch on the HP-IL module) then the printer module is moved to P4. But P6 can then only be used by P6 friendly modules, and P4 cannot be used by Library 4 (in case of an HP41CL for example) and that means that you cannot use OSX-BS4. Regards, Meindert |
06-10-2022, 09:38 PM
As a decidedly non-power-user Warp is my P7 pick on my DM41x.
06-11-2022, 02:45 PM
Request to pin this thread.
06-11-2022, 05:34 PM
(06-10-2022 03:35 PM)MeindertKuipers Wrote:(06-10-2022 02:12 PM)Chr Yoko Wrote: Nice subject ! Thanks for the detailled answer ! On my 41CL P4 i have at the moment the LIB4, and i would like to keep that wonderfull HP-IL connection , so that is confirming that P6 & P7 can't be used on my usual configuration. |
