Watch related Part 1 (too many photos for 1 posting)
11-21-2019, 05:00 PM
(This post was last modified: 11-21-2019 05:03 PM by Geoff Quickfall.)
Some of you may know that I also collect and restore watches. Well everyone needs a watch tester and I was lucky enough to pick up a grail of a tester branded Omega but made by Witschi.
It has LEDs and is circa 1986! Enjoy! Also known as a WITSCHI Q TEST 4100. Got this off Ebay for $400 with the displays working but in untested condition. No guarantees on accuracy or if fully functional. Well I love a puzzle and knowing the displays were okay I thought my chances of getting this fully functional would be 50/50. So it arrived well packaged and shipped from Europe. I noticed they writing in places on the main bezel for the supply voltage test section was corroded and missing. Case was very dirty along with the wood case. The wiring was for 220 volts but is switchable to 120 volts and with a European to American plug converter. Plugged it in and noticed the on off switch was hooked up backwards, that is the off was on and the on was off! This told me that someone had been inside the tester other then the makers. When opened I noticed some wires were broken from their soldered positions. The timing display function for 18000 and 26600 mechanical, 32kHz and Accutron tuning fork was displaying correct daily and monthly errors, more on that later. The voltage testing and internal voltage supply for testing were non functional (the side with broken wires). The mirror was loose and foam for the mirror was decomposed and also the white collar was completely missing on the test side of the checker. The white collar reflects light illuminating the under side (display side) of the module under test. Both LED red filters were loose and came off when the case was disassembled. So problem when I received it: 1) wires not connected internally. 2) loose ICs (they are all plug into sockets, amazing). 3) mirror on testing side loose 4) foam underlay for mirror which pushes up and into the large PCA decomposed. 5) collar which surrounds the internal mirrored testing side missing. 6) on off switch hooked up backwards. 7) whether correct or not the electrolytic are all 33 years of age so they may be suspect. 8) NO MANUAL or INSTRUCTIONS (any help here would be appreciated). 9) wood cover stained and finish deteriorated. 10) metal bezel had corrosion on surface as though acid had been leaked onto it. 11) supply voltage writing missing due to the corrosion. 12) red led filters both loose or separated from the upper face plate. 13) missing probes for the test side of the checker. What I did: Electronics 1) disassembled components. 2) replaced all capacitors with like capacitance and 5% tolerance. 3) resoldered broken wires to correct probe locations. 4) upper PCA which contains the LED modules. - Removed LED blocks and cleaned all push button contacts as well as battery knob pot and PCA. 5) main PCA cleaned and all ICs reseated after being treated with detox-it electronic preserver. 6) cleaned the sensor pads being REALLY careful about the wiring under the detector PCA. Case: 1) lightly sanded wood and lacquered with satin finish. 2) cleaned corrosion off the aluminum bezel and cleaned up the engraved supply voltage writing. - Then filled in the writing. - lacquered the metal bezel upper and lower in satin lacquer. 3) polished and reattached the LED red lenses. 4) cleaned mirror and mounted on new foam. 5) found a spray paint cap of the perfect size and colour to replace the missing collar around the mirror. - Cut to size and mounted it. 6) added rubber feet to base. 7) will remake the probes for the test side and already secured test probes. So the BEFORE pictures: As it arrived EXTERNAL: Upper right closeup: Upper center closeup: Upper left closeup: Over view: note the white collar on the right side surrounding the mirror on the testing side is missing. Damage to the aluminum bezel at the supply voltage side of the checker (yellow box): Wood with damaged finish: As it arrived INTERNAL: Capacitor on main PCA (replaced). Other parts of the main PCA with capacitors and dirt on PCA. Continued in part 2 |
11-21-2019, 05:01 PM
RE: Watch related Part 2
Broken wires to testing side of the checker:
Main PCA with shielding for smaller sensor pad PCA; Sensor PCA pads obverse side: Sensor PCA reverse side: Upper display PCA with push buttons all cleaned: Reverse of the upper display: AND NOW THE REVEAL: The overview with lacquered wood and bezel. Supply voltage writing redone. All probe receptacles removed, sanded and polished then reinserted. Three views of the pocket watch (18000bph) with the seconds per day displayed. You will notice the balance wheel button (far left is selected) as is the 60 second sampling button. Also note the green signal led (which beats in relation to the watch beat) as well as the red led indicating seconds per day: Continued in Part 3 |
11-21-2019, 05:02 PM
RE: Watch related
The LCD push button is selected with green signal and red seconds per month now indicated. Sampling time is 5 seconds:
Voltage of a battery under test, the EXT V push button is selected: Internal supply voltage being tested for accuracy. Output is being tested by my multimeters. Note the selector knob is abeam the 1.55 volt indicator, not bad accuracy! Note the SUPPLY V push button is selected: Here the voltage knob is selected to the highest value, almost 3 volts. These two voltages and all between are typical LCD and LED voltage requirements. Here is the accuracy of the voltage measurements: And the capacitors removed: The missing probes, which I will be making later, would connect to the module + and - testing points. The module would be upside down and the display would be visible in the mirror. There is an alarm button as well as a display button, again I need a manual to check these for functionality. So I think I have it working. The tested seconds per day and seconds per month in the above examples check well with the watches actual performance. I also tested a Bulova Accutron, Omega 300 hertz and my 2.4 analog Omega Marine Master all check. The Omega Marine Master clocked in at 1 second per month on the tester and that coincides with its actual rate! The quartz watches are divided into 32kHz, LCD and analog. The analog was used for the Marine Master so I guess it automatically detects the rates. Again I need the manual to determine what is what. Hope you enjoyed the posting, I will do a YouTube video with various aspects of its capabilities demonstrated. Best regards, Geoff |
11-21-2019, 11:59 PM
RE: Watch related Part 1 (too many photos for 1 posting)
Hi Geoff
Good find and another bit of rare equipment back in action, I am sure these time pieces are right up your alley. Goes to show how some people some so called technicians end up butchering things Before you get them. Well done enjoyed the post Ray |
11-22-2019, 01:38 AM
WOW! Fantastic machine! Congratulations for your find and thank you for for share the photos with us!
Cheers JL |
11-22-2019, 01:39 AM
Ray,
I get to Melbourne now. You still there? Geoff |
11-22-2019, 08:02 PM
Very, very nice - thanks for posting and I'm jealous! Looks like it was $1975 back in '86!
Interesting the acoustic sensor will work for 32kHz quartz watches. I sure wish the current crop of low cost timing machines would do that. Really cool! Bob PS No 38.4 kHz setting? :-) |
11-22-2019, 08:12 PM
(This post was last modified: 11-22-2019 08:16 PM by Geoff Quickfall.)
Four modes of detection:
Acoustical, capacitive and magnetic and measurement by means of current drain! I can see why the cost was so high. They list on eBay in sad shape for around 1600 to 2500 USd. Auto detection of frequency of quartz crystal so will auto detect any frequency including HP 01, or HP 55 and etc plus the Omega marine master 2.4mHz. Uses stepping motor or if detectable capacitive on digital. Will set up a count, then compare the detected mode to the count (In the PCA an oven heated cut quartz crystal at 32kHz, yes the crystal is heated to a specified temperature to guarantee its consistent count reliability.). The count is repeated and the off count of the watch under detection is compared, the math is done and voila, a reading! Just received a full PDF manual from the manufacturer for free. Time to have fun, Pun included! |
11-22-2019, 11:03 PM
(11-22-2019 01:39 AM)Geoff Quickfall Wrote: Ray, Hi Geoff, I am in Perth, I was lucky enough to be in Sydney twice on business when you were passing through. I would have prefeed Melbourne. While on the watch subject, I still haven’t got to that HP01 hi key prototype, I was thinking about using one of panamatics new setups. One day I will get motivated and get to it Regards Ray |
11-23-2019, 12:05 AM
(This post was last modified: 11-23-2019 09:06 PM by BobVA.)
(11-22-2019 08:12 PM)Geoff Quickfall Wrote: ...Acoustical, capacitive and magnetic and measurement by means of current drain!.. Current drain, indeed! Very clever! It can sense the hand step signal through that and then work out the timing and any error from there. I did the "cut and try" approach on a Seiko A829 LCD quartz for a couple of weeks and got it pretty well dialed in, but I didn't want to repeat that task for a couple of others in the queue. I wound up using a hack that saved some time, but I expect that would be about ten second job on your newly revived box. Nothing like the right tool for the job! I was puzzled by the lack of amplitude and beat measurements for balance wheel watches but I guess that it's because that mode it was designed mostly for servicing electric mechanicals like the Hamilton 500, rather than conventional escapement movements? And it's got LED's! |
11-24-2019, 07:21 PM
Hello Ray,
Got two of Panamatik’s HP 01 modules running in my 10 HP 01s. They are fantastic! Both his modules reside in the tall keys prototype cases. So all finger press for function, no need for a stylus. To bad we don’t fly to Perth! Best wishes, Geoff |
User(s) browsing this thread:
